| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Dec 2005 Location: Chennai
| I have a major problem with Indica wiper. during rains it doesnt clean the windscreen properly. it leaves a small layer of water which reflects the lights of other vehicles so badly that i will be forced to stop the car some times. i changed the wiper and now also the same problem is continuing. one of my friend told me that this is a common problem with all Indica's. is it so? What can be the remedy for this? ![]() |
| | #2 (permalink) |
| Team-BHP Support ![]() | The blade needs to be replaced only in case of rubber going bad, and that translates to every year. If the problem continues its adjustment problem. If your wiper is jumping on the glass it means too tight, if its leaving water that means too loose. If it leaves a thin line of water means rubber is damaged at that point. Quality of indica wipers is bad no doubt but a new wiper will do a good job for atleast a year or so if kept properly adjustted
__________________ Reclaiming.....! |
| | #4 (permalink) |
| Team-BHP Support ![]() | Adjustment problem them. Adjustment means holding the wiper stalk and bending in desired direction. Dont try this at home if you are not confident. I use this solution after I saw the workshop guys do the same thing
| | #6 (permalink) |
| BHPian | Not too many problems with my wipers except that the wash/wipe function won't spray the water on the windscream uniformly (a nozzle issue) and the wiper starts wiping immediately than wait a moment for the water to settle.
__________________ 2005 Tata Indica LGi |
| | #7 (permalink) | |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| Quote:
Is there a solution to this problem? Is there a pump that sprays the water (I believe there has to be something that drives the water)? Can it be replaced with a more powerful one that can give a more forceful jet of water? | |
| | #8 (permalink) |
| Team-BHP Support ![]() | Its adequately powerful. Change the direction of nozzle using a pin to direct the war to center of the windscreen. If you just tap the water spray for a moment and dont keep it depressed wiper wont start. So you go tap tap, get some water on windscreen and then keep it pressed.
| | #9 (permalink) | |
| Quote:
Gotta check this out. However, one thing I do know is that even a mere tap on the push-button on the wiper control stalk makes the wiper go zap-zoop... i have tried everything and am convinced that the wiper starts moving immediately. I need to check this with the service people. May be it is some problem on my vehicle only.And since we are at it, Tanveer buddy here is another poser for you. The Indica guidebook says replace engine oil every 10000km or 6 months. What with this 6 months thing? Is it really necessary? I mean, as per the service advisor even if you have not driven the car more than a couple of thousand kms since last change but 6 months have passed you should change the oil. Why? | |
| | #11 (permalink) |
| BHPian Join Date: Mar 2005 Location: goa
| This is nothing but traffic grime, an oily film that gets formed on the glass. Wipe the outside of the windscreen with a strong solution of Surf Excel, wash off with clean water. The problem should go away for a week or so at least.
__________________ Hyundai Getz 05 Baleno Vxi 05 |
| Thread Tools | |
Similar Threads | ||||
| Wiper problem in Santro | subhojitb | Technical Stuff | 7 | 20th July 2008 00:56 |
| Indica AC problem....Please help! | panky12345 | Technical Stuff | 12 | 14th May 2007 18:43 |
| Starting problem in INDICA... | hianooo | Technical Stuff | 29 | 17th April 2007 18:15 |
| Indica problem | netarchie | Technical Stuff | 10 | 6th April 2006 15:58 |
| problem with Indica V2 | msk_kapoor | Technical Stuff | 6 | 31st January 2006 13:41 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
