Old 10th January 2006, 21:55   #1
prince85's Avatar
Thanked: 84 Times
Default How to clean headlamps??
Hello people,
Well this may sound funny here but i am really confused about how to keep the clear lens headlamps on my dad's optra clean? I mean i just love the optra's diamond effect like clear headlamps but over a period of some time, there are tiny spots on it which are visible only when the headlamps are on. Any remedies as to how to keep it spotless clean? I have tried using carwash shampoo to clean the spots but to no avail. I know that the mods may think of this thread as useless but guys i really need help as i did not get any information on this topic when i tried to use the search function. Plz help
prince85 is offline   Reply With Quote
Old 10th January 2006, 22:38   #2
Thanked: 9,744 Times
Alas, those spots are "gravel rash" , pit marks due to grit, tiny stones hitting the headlights. Only way around it i getting clear plastic covers fitted.
These covers are very popular in australia
Old 11th January 2006, 22:14   #3
revharder's Avatar
Thanked: 47 Times
if the spots are from inside of sealed beam, then you cannot do much.
just remove the bulb holder etc. & throw some pressurised air to remove loose dirt if any.
donot try to open the sealed beam!
revharder is offline   Reply With Quote
Old 11th January 2006, 22:48   #4
prince85's Avatar
Thanked: 84 Times
nope, the spots are on the outside as i can feel it in my palm when i slowly brush my hand over the headlamp
Old 11th January 2006, 23:06   #5
revharder's Avatar
Thanked: 47 Times
i am afraid if the spots are from outside & are not removed even after using shampoo and all, you cannot remove them easily. sorry for not being able to help you over this.
Old 12th January 2006, 13:10   #6
Some of these links may be helpful:
Scratches can be buffed from glass if light enough
http://www.signonsandiego.com/uniont...s8heresho.html
Cerium Oxide Glass Polish
http://www.deltakits.com/dki-catalog/co1.html
Glass Polishing:
http://yarchive.net/metal/glass_polishing.html
giri is offline   Reply With Quote
Old 12th January 2006, 13:26   #7
Jaggu's Avatar
Thanked: 7,478 Times
if its is tar and insect hits, those can be removed using some diesel and thoruogh cleaning using a good car shampoo but if its stone chips nothing much can be done.
Old 20th August 2017, 17:05   #8
Thanked: 17 Times
Default Re: How to clean headlamps??
There are many ways the headlamp can become gloomy after a certain amount of time. According to the portion damaged, there is different ways to correct it and make the headlight nearly shiny as new.
1. If the headlamp outer glass has marks or spots in it or has a yellow layer on it,use a fine sand paper to scratch ii off and coat a couple of layers of Headlamp coating spray.
2. If it is the inside area, you will have to open up the headlamp assemble. For that, use a heating equipment and carefully remove the reflector. Then do the same steps as mentioned in the first method.
3.If it is the reflector that has damage, there is nothing much you can do other than try cleaning it. No product is out there that can have a coating similar to the chrome shade that you get on that reflector.
Note : Nothing gives a shiny effect like a new headlamp assembly. If you can afford it,you can go for it and you will never be regretting the decision. Even I have brought a new headlight assembly for my Karizma and I really loved the fresh look I get from it.
JozfGT is offline   Reply With Quote
For All Car Lovers - Keeping Your Car Clean Rudra Sen Technical Stuff 561 31st March 2016 16:03
Honda Unveils Ultra-Clean diesel system. Thil The International Automotive Scene 6 30th May 2009 08:17
Rs.200 to clean my K&N filter!! OK? stevie Technical Stuff 39 26th March 2007 00:14
Wanted clean bike till 2.5lac rakesh Shifting gears 1 22nd July 2006 00:32
My next job in this weekend clean turn signal ECM Modifications & Accessories 2 6th June 2006 23:06
