Old 8th November 2011, 15:04   #451
Thanked: 86 Times
Default re: Figo TDCi: Dies occasionally while downshifting! Solved: Updated firmware by Ford
Originally Posted by anilisanil View Post
Are ford engineers there? If they are not, they cannot test anything on a moving vehicle. AFAIK Ford does not give any service center tools that could test the car while running.
Hello Anil,
The ford customer care guy and the dealer said that the technical team from Ford Chennai and the dealership people will work in co ordination (maybe on video conference or phone) to solve this issue.
I would also like to know were you made to pay anything from your pocket for this change or everything was covered under warranty? If the cost was nil, then any idea as to how much would the ecu and firmware update cost if the car is not in warranty?
Diesel lover is offline   Reply With Quote
Old 8th November 2011, 15:36   #452
anilisanil's Avatar
Thanked: 288 Times
Originally Posted by Diesel lover View Post
Hello Anil,
I did not pay anything.
ECU should cost upward of 35K, I was informed.
Not too sure how much firmware upgrade should cost, must be limited to labor, but not sure.
anilisanil is offline   Reply With Quote
Old 8th November 2011, 15:50   #453
Samurai's Avatar
Thanked: 14,542 Times
I had similar problem with Grand Vitara, and I too suspected the ECM. Finally throttle body cleaning eliminated the problem.
Samurai is offline   (1) Thanks Reply With Quote
Old 9th November 2011, 13:23   #454
Thanked: 86 Times
Car given to Bhagat Ford Chandigarh for installing the new firmware which they confirmed as firmware version 75. Will be collecting the car in the evening and will update what all changes are felt (drive ability, engine noise, etc).
Old 9th November 2011, 13:40   #455
anilisanil's Avatar
Thanked: 288 Times
Update: Perceivable increase in engine noise observed. People who upgraded their firmware, kindly confirm.
Old 9th November 2011, 17:25   #456
figo_mba's Avatar
Thanked: 208 Times
Increase in engine noise ???
I thought the firmware upgrade was also to reduce the engine noise. Already the figo noise is on the higher side, increase in engine noise is a deal breaker. I am going to take delivery of my car today evening. Will update after that.
figo_mba is offline   Reply With Quote
Old 9th November 2011, 23:25   #457
Thanked: 86 Times
Software updated to version 75. Will update as soon as I find any change in the behavior of the car.
Old 10th November 2011, 00:09   #458
figo_mba's Avatar
Thanked: 208 Times
It is basically a PCM calibration that I was given. I hope it is the same as the firmware upgrade that you guys are mentioning.
It is claimed that it is the solution for the engine stalling and also engine noise reduction.
I did not feel any noise reduction(also no increase) but stalling is gone for now. Touch wood. I tried a lot of the things and places that usually gives me an engine stall. NOTHING!! No Issues No stalling just like any other car. I know it is too early to comment but I am slowly regaining the confidence on the Figo.
Anyways, I am doing a long drive over this weekend (around a 1000+kms) so I will update after I come back.
Weekend!! where are you ?
Old 10th November 2011, 09:17   #459
anilisanil's Avatar
Thanked: 288 Times
Yes it is the same thing. I am definitely getting more engine noise, I need to look for other reasons then, any other things that come to your mind guys?
Old 10th November 2011, 21:29   #460
Thanked: 86 Times
Indeed it went well. The ECU was changed and software version 75, which indeed would be updated for all the Figos, was installed.
Just noticed that after the software upgrade to version 75, the 'water in fuel' light does not light up at all while the key is on position II (before cranking). Will check for the same in the coming days if it lights up or not. Can you guys please confirm?
Thanks.
Old 10th November 2011, 22:21   #461
gemithomas's Avatar
Thanked: 136 Times
i am "supposed to have got" the updated version during my 40K service. But i dont see any difference. In fact even my stereo settings and trip meter settings remained unchanged when i wet to collect the car back. My logic says that the trip meter settings should be reset if the software was updated.
Need to wait for the next 'stall' i guess!!!
Old 10th November 2011, 22:38   #462
Vid6639's Avatar
Thanked: 19,600 Times
Must say that Ford are prompt to respond to FB complaints. I got a call the next day of putting up the stalling issue on FB.
I have an appointment on Saturday for the ECU update as well gearshift issue for second and third. Hopefully there's some improvement after this upgrade.
Will update on Saturday.
Old 11th November 2011, 00:53   #463
Thanked: 313 Times
You two and other guys - can you post your comments on whether anything happened to the FE after the upgrade.
Also keep us posted on the engine noise.
I haven't had the stalling problem (except once) so not sure whether to just go and get it done.
vina is offline   Reply With Quote
Old 11th November 2011, 09:56   #464
anilisanil's Avatar
Thanked: 288 Times
Trip meter and odometer are independent of ECU firmware. They are a separate unit, I even got my ECU hardware changed, but my trip meter reading was intact. If your firmware version is 75 then it is the latest.
@vina: FE seems to be unaffected, but will have to wait until the next refuel. I was running low on fuel and filled from a reputed but non-coco pump and hence the engine noise is my presumption, since others have not reported any such thing. It was known issue for me with BP pumps.
Old 12th November 2011, 12:28   #465
Vid6639's Avatar
Guys I think 75 is the Ids software version that ford uses for ecu programming and not the actual firmware. I just got it done and the ecu firmware had a part number as61 something which I was told is the new firmware. All along the software showed version 75.04 on the laptop.
Ford SYNC: Firmware upgrade made easy for cars too! bejoy The International Automotive Scene 5 12th December 2014 17:20
My Linea jerks while downshifting the car DownTheLine Technical Stuff 38 24th November 2009 22:31
Judder while downshifting (Safari 2.2) rb2399 Technical Stuff 8 15th May 2008 00:44
My Accent ECU "hangs" occasionally Rehaan Technical Stuff 37 1st September 2004 09:03
