Old 18th January 2006, 20:14   #16
Rehaan's Avatar
Thanked: 25,043 Times
Hey Shan,
Non circular (ie oval/figure8/butterfly) steering wheels are pretty common, but as far as an offcenter axis of rotation; i have never heard of it in a production car, and i dont think it is the case in the noble...
cya
R
Old 20th January 2006, 14:01   #17
hey need a little help in regards to a steering problem , i have a lancer slxi 2000 and in the last few days i have had to put in a little more of an effort to turn the car the steering seems a little tighter ...i check the fluid , earlier it was full right to the cap but has come down by a 4 centimeter due to the cap not closed tightly ..took it to the mech he said that there was some dirt etc.. but its not helped car seems to be same any suggestions?
thanks
ancer is offline   Reply With Quote
Old 20th January 2006, 16:05   #18
Deeps's Avatar
Thanked: 68 Times
Originally Posted by Rehaan
Hey Shan,
cya
R
The wheel on the Noble looks to be vertically oval where as on most cars it is horizontally oval, right? (Hope you understand what i am saying )
Deeps is offline   Reply With Quote
Old 21st January 2006, 05:00   #19
Rehaan's Avatar
I know what you are saying, but i think its just the angle of that pic.
cya
R
Old 25th January 2006, 23:49   #20
jat
thanks
Could be air trapped inside. Ask your authorised service center to vent it.
RK
jat is offline   Reply With Quote
Custom designs on your Steering Wheel - Ovion (Bangalore) automobilophile Bangalore 3 21st March 2014 14:53
Loose Steering (Too much play in the steering) mithun Technical Stuff 5 23rd October 2012 12:35
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
All wheel steering vs front wheel steering SamtheLeo Technical Stuff 17 28th July 2009 20:11
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
