View Poll Results: Which gear do you use to move from rest?
1st gear 141 97.92%
2nd gear 3 2.08%
Voters: 144. You may not vote on this poll
Old 12th January 2006, 16:48   #16
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by Zappo
I. All of a sudden I find that if I try to shift to the 1st gear at any speed above 5kmph the lever simply refuses to budge!! I do not know what has happened. Maybe some trick they incorporated to prolong the clutch life?! I don't know.
i think thats beacuse first and reverse are constant mesh and the others are synchromesh ...it is to avoid accidental shifting into 1st or reverse ....this was what i was told by maruti
speedsatya is offline   Reply With Quote
Old 12th January 2006, 17:44   #17
DCEite's Avatar
Thanked: 607 Times
But my wagonR reverse gear still sucks you know...refuses to be engaged at times.. i am going to get it replaced
DCEite is offline   Reply With Quote
Old 12th January 2006, 17:52   #18
Zappo's Avatar
Thanked: 2,079 Times
Hey hey hey... About the reverse gear there is a thing. Unlike other gears when you want to engage reverse the suggested way is to come to a standstill. Then once you declutch hold it for 5 seconds... and then take the reverse. You will find it engages so much more easily buddy
Zappo is offline   Reply With Quote
Old 12th January 2006, 17:59   #19
Zappo's Avatar
Hmm... Satya bhai Indica has that documented for the reverse gear (no direct 5th->rev). However earlier on 1st I used to be able to move directly to. Typically whenever I reach a standstill for a brief while I directly shift over to the 1st (from 4th or 3rd) and then brake. This way it aids in quicker take off once the traffic moves. However all of a sudden after my car came back from its 1st service it has stopped happening. Hence the query...
Old 13th January 2006, 04:03   #20
I ususally use the first gear, that way I can accelerate faster as well..... using 2nd gear means have to let go off the clutch a bit slower...However, in slow traffic my dad just uses the second gear..... he just feels lazy to change gears..lol :d
vinod is offline   Reply With Quote
Old 13th January 2006, 05:01   #21
ambylimo's Avatar
yh pickikn up from 1st gear enables faster acceleration and doesnt exert unwanted pressure to ur engine....and reduces capacity as well...burns out more fuel and leaves wear and tear
ambylimo is offline   Reply With Quote
Old 13th January 2006, 07:31   #22
Rudra Sen's Avatar
Thanked: 4,288 Times
Satya buddy, I'm under serious impression that all modern cars now with all synchromesh forward gears..
When did you check this with Maruti?
Old 13th January 2006, 10:22   #23
speedsatya's Avatar
Thanked: 712 Times
Talking
when i was facing problems with my first and reverse gear ...i was told that all maruti cars from m800 to the baleno had this...there was no Swift at that time...
Old 13th January 2006, 10:39   #24
Rudra Sen's Avatar
Baleno sure comes with all forward synchromesh...Swift is only modern in terms of looks and time. Please check your Zen manual. Don't listen to your dealers/ service people blindly.
Old 13th January 2006, 11:58   #25
speedsatya's Avatar
Thanked: 712 Times
ohhh ..will it be mentioned in the manual ???????wait ..letme write to maruti ...
but i thonk 3 dealers had told the same answer ...still will check
Old 13th January 2006, 17:51   #26
I always start from first. Except in our Mahindra Maxx, in which I start from 2nd without half clutching. There is hardly any difference in the first and second gears of the Maxx and Commander.
5u3zEr0 is offline   Reply With Quote
Old 13th January 2006, 18:11   #27
Thanked: 66 Times
hey in he city i normall start in the first gear only cause frankly i absolutly love this gear but if im in any of the landrovers then always use second....also when off roading and ur in low its more appropriate too start with either the second or even the third gear...
xtreme power is offline   Reply With Quote
Old 13th January 2006, 18:19   #28
Thanked: 9 Times
Always in 1st gear from stand-still (start). But sometimes I do it from 2nd (rarely) when I am too lazy to shift from 2nd in a traffic jam and crawling and have to stop for a bit and then move off again.
Abhay is offline   Reply With Quote
Old 28th January 2006, 01:02   #29
Gtea's Avatar
1st gear mostly but sometimes, when in traffic I start with 2nd gear because it gets quite tiresome to change to 1st and then 2nd even though there's about 5secs gap from changing from 1st to 2nd.
(Oh! BTW, I do this mostly in Stop - Go traffic conditions)
Gtea is offline   Reply With Quote
Old 28th January 2006, 03:17   #30
hellspawn's Avatar
Infractions: 0/1 (10)
i always use the first gear to start.....and i guess i was good at not riding the clutch cos the clutch lasted till 57000kms.the workshop engineers were suprised wen they got to know this.
hellspawn is offline   Reply With Quote
Do you insist on genuine spare parts always? rahul_intlad The Indian Car Scene 80 4th December 2014 14:29
You always remember your first time - Ahmedabad's first mini-OTR AVR 4x4 Excursions 25 28th August 2010 21:55
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Always have a reserve of min 10 Litres in your tank if you drive a diesel. fash_1 Street Experiences 17 6th August 2008 12:32
Something Big You always wanted..... nikibusa The International Automotive Scene 13 25th June 2004 03:52
