View Poll Results: Which gear do you use to move from rest?
1st gear 141 97.92%
2nd gear 3 2.08%
Voters: 144. You may not vote on this poll
Old 2nd June 2006, 16:59   #46
hellspawn's Avatar
Infractions: 0/1 (10)
Originally Posted by iraghava
And just to settle all debate I am a VERY GOOD driver I keep the car in excellent shape, don't over-rev her, drive her gently, no skids or screeches are done by me and generally I take very good, gentle care of her!!!
WTF!!!!dont over -rev her,no screeches......am i talkin to ishan.....gentle care.....hello,did somebody forget the fight with the tractor trailer.
hellspawn is offline   Reply With Quote
Old 2nd June 2006, 20:15   #47
I normally start in first gear, but when in slow moving traffic, i start in second. When i move from a signal, i start from first, dont want my car to stop in a signal, then move to 2nd gear..
prakash2757 is offline   Reply With Quote
Old 4th June 2006, 03:29   #48
Fuelled's Avatar
.... And just to settle all debate I am a VERY GOOD driver I keep the car in excellent shape, don't over-rev her...
Yeah man. This i'll agree too. U dont go over the rev limiter .
Peace.
Fuelled is offline   Reply With Quote
Old 10th June 2006, 22:37   #49
Thanked: 9 Times
Originally Posted by panky12345
Ist to start, then immediately on 2nd, I think Ist was made for this!
If you want to feel the real Torque of your machine then its got to be 1st gear Frist. The vehicle tends to shudder a little bit when you take off on 2nd gear and this could seriously damage the entire body mounting over a period of time ultimately leading to unwanted rattles.
So long....
varunroy is offline   Reply With Quote
Old 11th June 2006, 10:40   #50
rks
rks's Avatar
My Santro ZipDrive (1 lit) doesn't even pull in 2nd gear at speeds below about 10 kph with A/C and slightly less without A/C. Actually this is quite irritating, to have to shift to 1st even when the car is moving (sometimes the car jerks if the clutch release is done hastily). So I have no option but to start on 1st. In Ambassador and Fiat (60's vintage) one can even start the car in 2nd, but I didn't follow this practice. In Maruti 800 (1995, no A/C) you can always use 2nd while the car is moving; I used 1st to start from dead stop, but the car might pull in 2nd too with slightly favourable slope.
Regards, rks
Old 11th June 2006, 11:23   #51
theMAG's Avatar
Thanked: 1,574 Times
Originally Posted by sbasak
Though it is advisable to always start from first gear when moving from standstill, I've seen many people start from second gear (especially when waiting in traffice light).
For modern engines with high torque it is often possible to start in 2nd gear.
So, what do you do and what is your opinion on this?
If there's even a slight descent I use the 2nd gear on my Swift. 1st gear is used when there's some ascent. After all, my aim's to get to 5th gear as soon as possible and keep the engine in the lower rpm band in city traffic.
Old 11th June 2006, 11:29   #52
nitrous's Avatar
Thanked: 285 Times
Bro, u'll definitely be riding ur clutch. Its not healthy for the car and its a bad habit.
Try quitting it.
Old 11th June 2006, 12:15   #53
DCEite's Avatar
Thanked: 607 Times
I remember climbing a 45 degree slope (maybe even more than 45 degree!) in one of the underground parkings.. and my car stalled mid way.. the reason? i was trying to climb the slope in 2nd gear with a/c on and 2 ppl onboard.
with great difficulty and wheel spins and handbrake usage i manged to climb up from the mid way.. this time in 1st gear.
DCEite is offline   Reply With Quote
Old 11th June 2006, 23:18   #54
turbo_c's Avatar
Thanked: 7 Times
Ummm... this is actually a "no-brainer" ...
Start in first always...
2nd for 60 - 120Kmph!
- T u r b o C -
turbo_c is offline   Reply With Quote
Old 12th June 2006, 13:14   #55
2fast4u's Avatar
95% of the times in Reverse (always a car in front of mine)
2fast4u is offline   Reply With Quote
Old 12th June 2006, 13:34   #56
garvit2002's Avatar
most of the times i use 1st gear but i used 2nd gear to move on in my mahindra armada
garvit2002 is online now   Reply With Quote
Old 12th June 2006, 16:22   #57
I've just started driving.. As per my logic n understanding, it's always the first gear to start off and immediately after getting the initial torque shift to the second gear.
rtoslynx is offline   Reply With Quote
Old 12th June 2006, 16:34   #58
rareone's Avatar
Thanked: 11 Times
Originally Posted by sushrutha
Always first Gear to move from standstill
on this coz i use the same method...
rareone is offline   Reply With Quote
Do you insist on genuine spare parts always? rahul_intlad The Indian Car Scene 80 4th December 2014 14:29
You always remember your first time - Ahmedabad's first mini-OTR AVR 4x4 Excursions 25 28th August 2010 21:55
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Always have a reserve of min 10 Litres in your tank if you drive a diesel. fash_1 Street Experiences 17 6th August 2008 12:32
Something Big You always wanted..... nikibusa The International Automotive Scene 13 25th June 2004 03:52
