| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| View Poll Results: Which gear do you use to move from rest? | |||
| 1st gear | | 130 | 98.48% |
| 2nd gear | | 2 | 1.52% |
| Voters: 132. You may not vote on this poll | |||
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Though it is advisable to always start from first gear when moving from standstill, I've seen many people start from second gear (especially when waiting in traffice light). For modern engines with high torque it is often possible to start in 2nd gear. So, what do you do and what is your opinion on this?
__________________ Life is a math which you need to solve without knowing the answer! |
| | #2 (permalink) |
| BHPian | I normally start in first gear, but when in slow moving traffic, i start in second. When i move from a signal, i start from first, dont want my car to stall in a signal, and everyone behind me to honk like mad at me.
__________________ For Sale: Parachute. Only used once, never opened, small stain. |
| | #4 (permalink) |
| Senior - BHPian | from rest I ALWAYS START IN FIRST. thats what first gear is made for !! and the moment i start rolling say at about 7-10 Km/hr i shift to second.and while inching in traffic it depends if its reall really slow moving then its first gear but if its at a slow pace but still over 5 km/hr i stay in second and half clutch at times.i know its bad but it doesn make sence shifting to first and then again after 3-4 seconds shifting to second. but i have noticed one thing.when i drive in the nights when the signals are normally off i slow down just before the intersection.at this point of time i have almost stopped so my speed is really low but still at times its difficult to shift to first.the gear just doesnt slot in easily...the speed at this time is beween 5-15 km/hr but still it doesn.any reason why ?? Rev
__________________ Revin Beyond Limits !! |
| | #5 (permalink) |
| BANNED | its always first gear to start from rest ...even when its speed breakers ...i stop thecar and then use first gear to go over ...can be done using 2nd ,3rd ,4th ,5th or watever gears ....but then u have to ride the clutch ...clutch shud be used only when changing gears or when starting fron rest |
| | #6 (permalink) | |
| Distinguished - BHPian ![]() Join Date: Apr 2005 Location: Pune
| Firs gear for almost 99% of times just 1% for those idiotic days Quote:
don't forget that when wheelspining ![]() | |
| | #7 (permalink) | |
| BHPian | Quote:
I am inquisitive about the half-clutch thing. Is it that it's completely possible to avoid half clutch (even in bad roads) using better driving and/or powerful car - or it is inevitable in Indian roads? Its not always the case that moving in 2nd gear puts wear on engine. It all depends on torque. If the engine can produce enough torque to pull the car on level ground (and gear ratio between 1st & 2nd is not much), moving on 2nd gear should be fine. But majority of A/B segment Indian cars don't produce such high torque at low RPM.
__________________ Life is a math which you need to solve without knowing the answer! | |
| | #8 (permalink) | |
| Newbie Join Date: Jan 2006 Location: Michigan
| Quote:
With the modern MPFI engines you dont need to use the cluch even when you are crawling. I regularly use the brake with no accelerator on my wagon-r lxi in traffic , uless of course coming to a stop !!! The processor will take care tha you do not stall.. no need to use the clutch at all... | |
| | #9 (permalink) |
| BANNED | also at lower speeds ,say 20 kph its possible to go in 5th or 4th gear ...for this u have to be careful not to try to accelerate suddenly ...as trying to do so with cause knocking ....instead if u acclerate slowly the car will move ahead ....but it wont pain the car if u shift into lower gears at lower speeds ![]() |
| | #10 (permalink) |
| Team-BHP Support ![]() | Always start on 1st gear, anything else you are riding the clutch. The only gear where I would half-clutch is 1st gear. That's because sometimes we are forced to drive at 1Kmph. Otherwise I never ride the clutch in any other gear. In my early days of stick shift (mid 90s), I spoilt the clutch plate within 6000Kms of driving. Those days I used to ride the clutch at any gear, that's how I was taught by the stupid instructor at Deccan Driving school. Never again.
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. |
| | #11 (permalink) |
| BHPian | I always use 1st gear when the car is at a dead stop, when it moves I immediately slot it to 2nd. When there is a climb ..... like a ramp from my underground parking to the level ground...... I use 1st again most of the way, it would be irritating to slide back and bump into someone behind you; if I am in 2nd during a climb I'll have to gun the engine to climb through. Again that depends on the laden weight; if its just me, I can slot in the 2nd quicker, if the car is laden I need to move longer on 1st gear....... ============ |
| | #12 (permalink) |
| Team-BHP Support ![]() | Always the first, though as an experiment I have tried 4th gear too. It works in tata indica with lots of difficulty. But first it is for normal because any other gear it would take ages to reach any respectable speed
__________________ Reclaiming.....! |
| | #13 (permalink) |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| I would say that 1st gear it is when I start rolling from standstill. There is that very small aberation, when I am standing on a downwards slope (even if the gradient is very less) and have to start moving I at times start straight from 2nd. At other times I prefer not to lug the engine and strain the clutch. Half clutch though a bad thing at times is inevitable. When you have to stop all of a sudden on a steep slope and then have to start moving you need to do half clutch. If you do not do so the moment you take your foot off the brake pedal the car will roll backwards and may even hit something. This is when you need to use half-clutch trick to "hold" the car for that brief period till you start pressing the accel pedal. @Ravetech, tell me about this 1st gear problem... My car never had this thing (problem?) till it came back from its 1st service last week. All of a sudden I find that if I try to shift to the 1st gear at any speed above 5kmph the lever simply refuses to budge!! I do not know what has happened. Maybe some trick they incorporated to prolong the clutch life?! I don't know. |
| | #14 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
| Thread Tools | |
Similar Threads | ||||
| TVR to move to Europe | iraghava | The International Automotive Scene | 2 | 19th October 2006 02:15 |
| AC on the move. | ballkey | Technical Stuff | 8 | 21st July 2006 13:49 |
| Move over Detroit ?? | paharino1 | The International Automotive Scene | 0 | 16th January 2006 15:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
