Old 12th April 2017, 11:44   #16
sujithsidhardha's Avatar
Thanked: 87 Times
Default Re: Hand brake jammed up in my Alto
Originally Posted by Cruiser_D View Post
Sujith, I think it is better to get it diassesmbled and lubricated if you have already faced this couple of times. The point is, slight jams might get unnoticed while driving, but could potentially lead to other parts failure like wheel cylinder.
Jack up the car and try rotating tyres. If there is resistance, then better to get it checked thoroughly.
Thanks for the advice.
I faced the issue for a maximum of three or four times only in 15 years! All after washing (heavy wash process with plenty of water) or when the car was left in heavy rain after a drive. Note that, in all these conditions, i used the hand brake. Anyway, the car had regular periodic maintenance and i could find break overhaul was done in regular periods as well. Hope there won't be anything serious here.
sujithsidhardha is offline   Reply With Quote
Rear wheel jammed after car stationary for a couple of days ! Shakensoul Technical Stuff 58 23rd September 2016 16:39
Fiat Palio 1.2 2002 Gears Jammed (Is it the clutch master cylinder?) genesis Technical Stuff 35 13th May 2015 19:16
Wheel JAMMED..... ~ H O N D A ~ Technical Stuff 8 16th July 2006 00:09
