| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Of late I have been hearing a ticking noise from somewhere . It appears to come from the right front wheel or steering column. Not sure though! It sounds like knuckle cracking your fingers!! I can hear it when I turn the steering some times or running on a hump etc.. But I can not reproduce the same when I want. Initially I ignored it but now it seems to be increasing. When I showed it to Sundaram I was told it is NORMAL. Now that I have a plan for a long trip, I am hesitant to take risk with it if anything is really wrong. Can some one help identify the problem? Thanks in advance
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #2 (permalink) |
| BHPian | Drive-shafts wearing out? Actually i am getting the same sound on my wife's 800 and am too lazy to get it checked... maybe I should
__________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss |
| | #5 (permalink) | |
| BHPian | Quote:
__________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss | |
| | #6 (permalink) | |
| BHPian | Quote:
What should I expect while doing so, more noise to confirm to confirm the problem or will it give any other kind of indication?? Please help!
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! | |
| | #7 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Quote:
P.S. Remember, the wheel has to be completely locked. | |
| | #8 (permalink) |
| Team-BHP Moderator ![]() | Could be tie-rods or ball joints worn out or even worn out shocks. Does it happen when driving straight while going over bumps? Then it would probably be one of the above. If it happens when turning, then chances are its the driveshaft. It could wear out prematurly if the shaft boots has been torn (by a sharp stone etc) and the grease gets dirty from mud/dirt.
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| | #9 (permalink) |
| BHPian | Hey i had faced the same problem in my 55K kms + run esteem a year back....the problem was rectified by overhauling both the front shockups at less that 1000/- bucks by a local garage. ( some rubber bushes/bearings needed to be replaced ) try turning the steering wheel from lock to lock when the vehicle is stationary...and try to notice if you get any sounds ....this would help you diagnose the problem...also open the bonnet and try to locate the sound in the stationary car by asking somebody to turn the steering !!! ~A |
| | #10 (permalink) |
| BHPian Join Date: Mar 2005 Location: goa
| rtech is right. Most probably its the drive shaft. Test by turning in a circle either direction. This normally wears out around 60-70 k km, but if you had any accident with the protective boot around the driveshaft... Else may be a defective piece - see if warranty will cover it.
__________________ Hyundai Getz 05 Baleno Vxi 05 |
| | #11 (permalink) |
| BHPian | I think it must be the ball joints (sundaram guys will call it IBJ and OBJ... meaning Inner Ball Joint and Outer Ball Joint) as he says he gets the ticking noise only when going over humps or while accelerating. The dampers could also be defective, or simply, the mounting nuts could be loose. So take your car to a garage and check the three mounting nuts under the bonnet. If your car is a City (OHC.. I mean), then it is a very common complaint. I have been driving with this ticking noise for the last 10K KM without any issues, and the occassional wheelspins too. Sundaram guys tell me that they have to overhaul the entire front suspension and steering and it could cost anywhere around 15-20K, so I have left it out for now.
__________________ The world looks different after 5000 RPM in my rear view mirror! |
| | #12 (permalink) |
| Distinguished - BHPian ![]() | Dude if the noise appears whilst turning the steering clock to clock either left or right or even slightly if turning then ur cv joints have gone and need replacement. the problem with honda city is that if this goes on for a long time then u might need to change the entire steering rack. get an opinion from hoda as well as another garage as the honda authorised guys will only talk of replacing the entire rack which is expensive |
| | #13 (permalink) |
| BHPian | Thanks for such a good response and help.. I have tries a couple of experiments upon suggestions in this forum. 1. Turning steering lock to lock when stationary.. No, I do not hear anything odd doing this 2. Making perfect circles in steering lock position, No, I do not hear anything odd doing this 3. Check mount bolts under the hood. Found one of them slightly loose fixed it but no improvement yet 4. Diagonally approach a road bump with right wheel first. Now I hear that sound, but not every time 5. come to a smoother patch of road, after some sough one, and then try steering it any direction Now I hear that sound, but not every time BTW My car is a controversial Fiat Petra, 1.6
| | #15 (permalink) |
| BHPian | It may be the CV boot also.. the CV boot protects the CV joints.. My first car was a Mazda protege.. for which I managed to damage the RHS CV boot.. Recently my zen also has this clicking sound coming from RHS wheel when I am turning left and coming out of a high gradient Basement parking left. It reproduces everytime. I have to get it rectifid in the the next service. Some info about CV boot and CV joint: http://www.able2know.com/forums/about7814.html Also, since this is the second time it happened with me.. it looks like I have to change my driving pattern when I am turning left. Probably I have to follow the US driving rules and reduce the speed to 15kmph so that all these problems doesn't happen.
__________________ Protege |
| Thread Tools | |
Similar Threads | ||||
| A sound while turning the steering wheel. | InternetUser | Technical Stuff | 7 | 5th February 2008 16:29 |
| Sound from front wheels while turning the steering at standstill | narasimha raju | Technical Stuff | 12 | 23rd January 2008 17:40 |
| Strange sound from Alto front left wheel | mail4ajo | Technical Stuff | 12 | 27th December 2007 13:32 |
| Steering column collapse | Lukeskywalker | Technical Stuff | 12 | 13th July 2007 20:33 |
| Collapsible steering column for ALTO | dsinz | Technical Stuff | 2 | 13th September 2006 17:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
