Old 2nd April 2011, 23:58   #16
rajivanoj's Avatar
Thanked: 45 Times
Default Re: Belt squeaking noise even after replacement
STARTING TROUBLE TROUBLES ME
The starting trouble remedy is unable to find, please help me, It takes more crank to start, not only in morning, but most times. as like clogged fuel line. and it tends to lower RPM and mostly engine dies once i take leg from accelerator to change gear (I made gymnastic by changing gear while pressing clutch and also raised accelerator and same time applied brake to not to hit others )
and when idle the RPM will be 800 , and suddenly it gets to 600 RPM and lessen than that the engine shudders and dies. I have checked fuel pump wire for loose contact, but it looks fine.
I have also noted coolant pipe which comes from thermostat coupling to fuel pump is leaking at both ends and also outlet pipes from fuel pump. I just notice today night, But will this make problem on starting and engine off?
Wierd thing is i drove around 11 + 11 kms this morning, but it was fine.
but the problem cropped up in evening just for 1 km ride that too in cold engine start. I am confused what is wrong.
rajivanoj is offline   Reply With Quote
Old 3rd April 2011, 00:14   #17
jatinpatel's Avatar
Thanked: 191 Times
There could be two logical explanations
1. the leaking hose is leaking coolant and during cold engine and cold fuel pump when the car is idling after starting its not circulating the previous hot coolant hence your fuel injection pump is not working in its optimum temprature range.
does the temprature gauge shows normal or does it go little over half mark?
2.Could be
your fuel injection pump requires servicing and re-calibration.
before going for the second solution check out the first solution.
And while at it just recheck your diesel filter again.
and please report on the situation.
jatinpatel is offline   Reply With Quote
Old 3rd April 2011, 00:18   #18
rajivanoj's Avatar
Thanked: 45 Times
temperature level remains the same, mostly 45% as before just below half mark, not more than half.
but will check filter again and report on monday
Old 4th April 2011, 21:18   #19
rajivanoj's Avatar
Thanked: 45 Times
Update: Found the fault and problem solved
Mechanic found which part does mischief of sudden low RPM and starting trouble, Its leaking fuel filter sensor, where the mechanic pumped diesel by hand through fuel filter pump, to my surprise the diesel was flowing from bottom sensor, actually the plastic thread got damaged, so the leak was. and the air was sucked in and diesel pressure was low due to leak.
replaced diesel filter and sensor
diesel filter cost - Rs.275
sensor fuel filter - Rs.1150
Labour - Rs.100
now its working fine with half crank start and normal constant RPM at idle.
To MODS : please edit title as SOLVED
Old 5th April 2011, 08:20   #20
knob's Avatar
My friend is having similar problem with his indica v2. Lets see if your technique works out.
knob is offline   Reply With Quote
Old 27th January 2014, 07:38   #21
Sandman689's Avatar
Thanked: 25 Times
Default Annoying squealing noise from timing belt. Help required.
This squealing noise cropped up ever since some stupid bloke at the service center messed around with the engine. And even after changing the timing belt couple of times or adjusting the belt tensioner, it has never really gone away. So every once in a while this problem haunts me when I start the engine. I have seen similar problem with other cars, some even worse(the noise in my case stops after a while but in some cases I have seen it to be permanent).
Isn't there any permanent solution to this problem?
Sandman689 is offline   Reply With Quote
Old 27th January 2014, 10:39   #22
arunphilip's Avatar
Thanked: 4,700 Times
Default Re: Annoying squealing noise from timing belt. Help required.
I've noticed that timing belt noise changes for a cold engine and an engine at normal operating temperature. That would explain why it goes away in your case.
Have you tried getting the cylinder head reseated with a new gasket? I suspect there's a small alignment difference causing the noise.
Have you also been able to rule out the auxillary belts/equipment as the cause of the noise? Namely, the AC compressor belt, alternator belt, and water pump?
Finally, which car, and which service center?
arunphilip is offline   Reply With Quote
Old 27th January 2014, 10:45   #23
mints21's Avatar
Thanked: 1,180 Times
You have not mentioned which car make and variant is this? What is the ODO reading?
You must also throw some light on the service centre involved in carrying out this repair. Was it an authorized service centre or you got it done from the local market?
How many times have you changed the timing belt? Has this been done under warranty is not clear from your post. Has this been done from the same service station? What is the frequency of changing this e.g. how many kilometers, how many days etc.? Frequent change of timing belt seems quite unusual.
Are these cars from the same car manufacturer. This looks like that all cars have similar issues, Have you spoken to other customers facing similar issues?
Please give complete details on the forum for the viewers to respond and suggest you a way out.
mints21 is offline   Reply With Quote
Old 27th January 2014, 10:58   #24
greenhorn's Avatar
Thanked: 1,318 Times
Question 1: is the vehicle an indica or similar?
if yes, it's normal. Get used to it.
Question 2: has the belt Pulley been changed?
Question 3: is the belt pulley aligned correctly?
Question 4: have you searched existing threads?
Apparently not. Here you go: http://www.team-bhp.com/forum/techni...placement.html (Belt squeaking noise even after replacement)
greenhorn is online now   (3) Thanks Reply With Quote
Old 28th January 2014, 06:27   #25
Sandman689's Avatar
Thanked: 25 Times
Yes. I indeed missed out a couple of details.
A new gasket?...if nothing else fixes this problem, will get to that.
Everytime the timing belt is changed, the noise magically disappears.
A Chevy Tavera from Dhulichand Motors whose service center I will never go again. Their service were terrible last time.
Yes, so here's the details:
It's a 2009 Chevy Tavera Neo3 SS
Run 51000KM up till now. The problem has been cropping up since 30000KMs. belt had been changed thrice every 10000KMs from Dhulichand Motors. Last time I went for a regular oil change and a repaint on left quarter panel to get rid of some rust. All they did was just repaint it. No anti-rust coating or anything. The rust appeared again after about a month. Furthermore what was even more annoying was that they said it will be delivered at around 3pm. But I was among the last to leave at about 5 even after some employees had left just because they had forgot to clean the interior.
I have seen another Tavera on the road with prolonged noise. And judging from the service people, they seemed to be familiar with the problem like it's common.
I haven't met any other tavera owner who has the same problem. But a driver of a shuttle tavera told me it's a common disease.
It's a bit bigger than an indica although I have seen the same problem in indicas, a santro Xinng, even an old dezire.
I never got the chance to pour water as this only lasts for a couple of seconds.
And no the pulley belt has not been changed. Will see to it that it's in good condition and also the alignment.
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Squeaking noise - What could it be? namit Technical Stuff 23 21st February 2014 11:42
My NHC clutch making a squeaking noise on release battada Technical Stuff 15 29th November 2009 20:10
Squeaking sound from the clutch satan_crazy Technical Stuff 39 7th September 2009 15:29
New Alto : Suspension squeaking! gpa Technical Stuff 0 8th August 2008 10:07
