Old 25th August 2011, 08:13   #241
dinu2506's Avatar
Thanked: 276 Times
Default Re: Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspensio
No updates is usually a good thing . 5 months up and no issues to report at all. Product working as promised. Did a recent trip to Mahabaleshwar with 5 onboard + luggage + no scraping.
If I were you, I'd start with the rear only. That's where Indian manufacturers usually soften things.
It absolutely will. Suggested change is at 50,000 kms, though I doubt they'll last that long. Guess only time will tell. I'm not concerned as the rear set cost me less than a tank of fuel.
I will second GTO, its 5 months on my Civic and its just performing really well. The Civic needs it at just the rear. I drive over most speedbreakers without the thought of the grinding sound coming. Quite unlikely in a Civic, right?
By the way I did not know the new Verna had a bottom scraping issue. I have the older Verna and this used to be one of its strongest points. It never used to scrape even on a full load.
dinu2506 is offline   (1) Thanks Reply With Quote
Old 25th August 2011, 17:13   #242
Tassem's Avatar
Thanked: 413 Times
It does and its ugly. However it scrapes only on full load and only on certain humps. Not all. You know how every now and then we come across a hump that is one row short of being a wall?
Thanks for the chiming in Dinu. I'm sold on this product. Do you know any place in bangalore that stocks it? I read earlier that A1 may have stock but that they're exorbitant when it comes to pricing. Any pointers?
Update: Placed a call to A1 @ 080 26577438. He said that he will get stocks on monday and that it will cost me Rs.1200 for a pair. I double checked if he knew what I was asking for and mentioned Autorunner. He said yes its the same thing. Has there been a drop in price?
Tassem is offline   Reply With Quote
Old 25th August 2011, 19:04   #243
dinu2506's Avatar
Thanked: 276 Times
I suggest you give Daryll a call and double check couple of things
1) What is the ideal size for the new Verna?
2) What is the price?
Rs 1200/- for a pair sure sounds like a steal (If I remember right, I paid around Rs 2500/- for a pair). They might charge extra for installation though.
dinu2506 is offline   Reply With Quote
Old 25th August 2011, 19:20   #244
Tassem's Avatar
Thanked: 413 Times
I was thinking I'll stick to the 1" variant. You wouldn't have Daryll's number on you, would you? To be honest I was expecting the prices to have gone up and was surprised when the fellow said its 1200 a pair. Unless of course the guy on the phone was talking about something else..
Old 25th August 2011, 19:31   #245
Thanked: 7 Times
I just called up A1. I felt he is not referring to the same autorunner. He told he has in metal as well as rubber. He will check my car suspension and then advice on what to use. No idea what he meant by metal autorunner.
denomathew is offline   (1) Thanks Reply With Quote
Old 25th August 2011, 19:37   #246
dinu2506's Avatar
Thanked: 276 Times
Its good to speak to Darryl and get the details. I have PMed you his contact number now.
dinu2506 is offline   (2) Thanks Reply With Quote
Old 25th August 2011, 20:29   #247
Tassem's Avatar
Thanked: 413 Times
I just got off the phone with Darryl. Very helpful guy I must add. I will be checking the gap between the suspension coils and letting him know so that he can send me the right size.
The price is Rs.4300 for a set of four including courier to Bangalore. And 2300 for a set of two, again including courier. Installation instructions while not needed, will still be included.
Old 25th August 2011, 23:51   #248
Thanked: 7 Times
Dinu, Can you please PM me Darryl's contact number ? I wanted to order B2 size for fiesta.
denomathew is offline   Reply With Quote
Old 26th August 2011, 08:14   #249
dinu2506's Avatar
Thanked: 276 Times
I think thats the price I paid as well. I wonder what was A1 referring to? Installation is something you can possibly do yourself.
I have Pmed you the contact number. Fiesta too needs this? I guess manufacturers should start offering this as OE for all their India models
Edit: I just tried sending you the PM. There was a message saying denomathew has chosen not to receive private messages from anyone. Maybe something to do with your setting. By the way Post#20 has got his number
Old 26th August 2011, 11:14   #250
sushrutha's Avatar
Thanked: 318 Times
I'm sure he's referring to something else. Probably a rubber spacer which is put to increase the height of a car.
Probably something like this (5th pic ) which is made from rubber
http://www.team-bhp.com/forum/tyre-a...ml#post2481733
Last time when I enquired he had quoted 2500Rs to get the Autorunners from Bombay. And bloody 1000Rs for the installation(my blood boild hearing this labour price).
I'm sure he(Fiaz of A1) gets the assisters from Daryll only.
Agree.
@Tassem ..If you don't have a garage or place to lift the wheels... then better take it to a workshop, who will do this installation for 100Rs (I paid this much, though I have a pvt garage took it to workshop ).
Last edited by sushrutha : 26th August 2011 at 11:21. Reason: provided the link for spacer
Old 30th August 2011, 15:45   #251
Thanked: 7 Times
Got B2 size for my fiesta(petrol 1.4 EXI, 5years old now) from Darryl. Total cost including shipping :2300Rs(for a pair)
Darryl was very helpful in explaining the fitting procedure in detail and how I can get different comfort levels.
Got it fitted in a local mechanic shop for 250Rs. They had to remove the tyre and disconnect the damper to let the spring expand fully. So its not DIY job on fiesta.
Immediate observation:
Car feels better going over the speed braker. Road near my apartment is in a mess after the drainage work. My car use to rock like a ship while going over this bad patch. After fitting autorunner it went over the same patch without much of a rocking movement.
Above observation is only from 2-3km drive. Need to test its performance with 5people and luggage.
Old 30th August 2011, 15:56   #252
Tassem's Avatar
Thanked: 413 Times
This is good news. I'm looking forward to getting this installed. Unfortunately I haven't had time to take the measurements for my car yet. This weekend for sure..
Old 2nd September 2011, 12:43   #253
junkishya's Avatar
Thanked: 37 Times
Hi Tassem,
In case you are able to figure out the gap between the coils, please let me know too .. I'm interested in buying it for my Fluidic ..
junkishya is offline   Reply With Quote
Old 13th September 2011, 16:00   #254
Sudhindra's Avatar
Thanked: 25 Times
Guys, can i get this installed for my contessa? I have been facing issues like bounciness, scrapping the ground when passing over a speed breaker on full load. Also, facing uncomfortable while maneuvering around the corners.
Any pointers & specifications that i should look out for is appreciated.
Sudhindra is offline   Reply With Quote
Old 14th September 2011, 11:12   #255
sushrutha's Avatar
Thanked: 318 Times
You can get it installed to any car as long as it has Coil springs.
Why not check with Daryll for the Assisters size of Contessa ?
Assisters will only help in reducing the sagging(To a small extent) of the car when on load and also scraping of the underbelly.
Assisters will not effect(increase) the handling of car.
For cornering, you need stiff suspension & a well designed Stabilizer bar/Anti roll bar
Soft Suspension in the Honda City Piyush_Vroom Technical Stuff 18 11th June 2015 07:55
Diaphragm v/s Coil spring Clutch for the KMT90 satish.rpr 4x4 Technical 14 16th November 2012 09:40
Spring spacer & Spring rate question Sankar Technical Stuff 15 23rd January 2011 20:21
Are VFM cars really VFM? - Cabs are wrong examples? WindRide The Indian Car Scene 5 21st March 2010 20:35
Mahindra Classic Soft Top With Soft Doors Sankar 4x4 Vehicles 7 28th January 2010 18:29
