Old 19th October 2015, 00:14   #151
Default Re: Hyundai i20 - Tips & Tricks
Rubber top of my i20 FOB has been broken. How do I replace it?
ukalia is offline   Reply With Quote
Old 19th October 2015, 14:07   #152
abhijeetsng's Avatar
Thanked: 130 Times
Originally Posted by ukalia View Post
All major online retailers now have blank key fobs of most of cars, including i20. Buy one and get the circuit and transponder replaced from a key maker.
Else, go the DIY route. Check out this link: http://www.team-bhp.com/forum/techni...ry-remote.html
Hope this helps!
Cheers!!
abhijeetsng is offline   (1) Thanks Reply With Quote
Old 26th May 2016, 02:20   #153
garry.brant's Avatar
Thanked: 21 Times
Post Re: Hyundai i20 - Tips & Tricks
i have two questions:
Q1. My indicator stalk will not work in Nex Gen i20. The safety hazard switch works and all indicators are working with the hazard switch. I took it to safdarjang hyundai in gurgaon but they said it would taka time to get the wiring checked. The ignition fuse was getting blown as soon as replaced (according to the SA). Has anyone come across a similar issue..?
Q2. what is the type of fog lamps in i20 nex gen.? Are they H3 ..?
garry.brant is offline   Reply With Quote
Old 26th May 2016, 02:29   #154
Thanked: 21 Times
Smile Re: Hyundai i20 - Tips & Tricks
Originally Posted by nettooran View Post
Here are some snap shots of the arm rest that I have installed
This is how it looks once the arm-rest is fixed.
Attachment 1041769
The top portion slides a little to the front
Attachment 1041770
There is a storage compartment in the arm rest.
Attachment 1041771
Rear View
Attachment 1041774
Rear View when the arm rest is folded up
Attachment 1041775
1 Litre bottle in cup holder when arm rest is pulled down
Attachment 1041772
Attachment 1041773
The red circles shows positions where I have drilled. The yellow circle shows position where I intended to drill , but could not since it needed the seats to be removed and I did not have the right sized spanner to remove the seats. At present all screws are fixed towards the rear. since there is no support at the front, I fear that a heavy weight on the from side may break the supporting panel. Shall Do it as soon as I am able to find a spanner to remove the seats.
Attachment 1041776
I recently bought a 2013 i20 and got a similar armrest installed which was beige in color, however at my request the installer changed the leather on top with Chocolate color . That suits better with the interiors of the car.
Will post pic tomorrow.
Old 31st May 2016, 23:15   #155
sanjeevgpc's Avatar
Thanked: 17 Times
As my i20 igen sports came with only one remote, my friend bought one used from ebay for me during his trip overseas. I opened the remote and found the transponder chip "pcf7936as" which obviously need to be replaced. I am getting the chip from ebay US and it costs $1.9.
Any idea, how much will Hyundai ASS charge me to program the remote and immobilizer?
sanjeevgpc is offline   Reply With Quote
Old 1st June 2016, 01:00   #156
hrbheda's Avatar
Thanked: 40 Times
I had my existing keys reprogrammed some time back. They charged me approx Rs 250 per key along with approx Rs 400 as the GDS charge. This was for a regular non-remote key with immobilizer.
The remote matching may cost slightly more but the GDS charges should be around the same.
hrbheda is offline   Reply With Quote
Old 1st June 2016, 10:16   #157
sanjeevgpc's Avatar
Thanked: 17 Times
What is GDS charge? If this is about the security code of the immobilizer, I already have the code with me.
Old 1st June 2016, 10:20   #158
hrbheda's Avatar
Thanked: 40 Times
The GDS is like a newer version of the GScan. It's the scanner they used to neutralise the SMARTRA and then complete the procedure.
Old 2nd June 2016, 12:42   #159
Thanked: 21 Times
Got the Arm Rest installed in my I20 with Chocolate Color leather, along with the seat covers. Here are the pics:
garry.brant is offline   (1) Thanks Reply With Quote
Old 2nd June 2016, 20:25   #160
Thanked: 384 Times
@garry.brant, Good to see this! how much was the total cost for fitting the add-on arm rest in i20?
ravib is online now   Reply With Quote
Old 2nd June 2016, 23:03   #161
Thanked: 21 Times
The total cost including the changed leather was 1200.
This was done in my house by gharmecar.blogspot guys.
Old 22nd July 2016, 18:40   #162
Thanked: 21 Times
Got sequential CNG kit installed in my i20 last week. Here is the break up:
BRC Sequential Gen2 Kit: 31,000
RTO Transfer for New RC: 4000
New Spark Plugs NGK: 1600
New Plug wires:1000
My first tank gave me 160 Kms for 8 Kgs of Gas.
It was done at ECO Gas Gurgaon, the installer Rizvaan did an awesome job.
The switch over from gas to petrol and vice versa can not be felt at all , I have to look at the switch to see that its done.
I asked the installer to tune the CNG for performance and not for FE.
No reduction in pickup however at very low RPMs you feel the difference , which has been the case with all CNG cars I have driven.
Finally happy with the installation.
Old 22nd July 2016, 22:40   #163
Pancham's Avatar
Thanked: 121 Times
Just out of curiosity how much does 8kg of gas cost.?
Mod Note: Please quote ONLY the relevant bits of a post. Quoting a full, long post inconveniences our mobile readers.
Pancham is offline   Reply With Quote
Old 26th July 2016, 12:11   #164
I'm getting 9-10 mileage for Hyundai 2nd Gen i20 Petrol Asta in heavy city traffic, my car is 7 months old.
Any suggestion ? Is the mileage fine ?
Shubham
shubhamneo is offline   Reply With Quote
Old 9th August 2016, 17:37   #165
Thanked: 130 Times
Yesterday evening while driving back home, it started raining very heavily. All of a sudden the airbag sign on the console lit up. It is now on continuously.
How to go about it? Help!
abhijeetsng is offline   Reply With Quote
Home remedies, tips & tricks for your car. Rtech Technical Stuff 65 20th September 2016 18:24
Xbox hacks, tips and tricks needed DCEite Gadgets, Computers & Software 23 28th January 2009 01:45
Drag Racing - Tips, Tricks and Good to know info. n_aditya Indian Motorsport 40 16th December 2008 13:51
New to 4 Wheelers and hope to learn good tips and tricks to maintain my car. tango6996 Introduce yourself 3 24th March 2007 12:27
