Old 27th February 2014, 17:55   #106
sudeep.pandya's Avatar
Thanked: 299 Times
Default Re: Hyundai i20 - Tips & Tricks
Originally Posted by racer_7 View Post
Is the default setting, that is without the control, maximum brightness?
Yes, default is set to the maximum brightness.
Hey guys, any idea if we can access our mobile phone contact list from the car HU or not?
There is no provision to access contact list. However if you press the green button the last dialed call gets redialed.
Originally Posted by Zahir View Post
I have a 2013 i20. Whenever I connect my phone (Android 4.2), only the number displays in place of the name, ie John shows as +919829998299(sample, don't try calling this number, you will find no John at the other end! )
Please check if your phone is in the top priority list. In my case the contact gets displayed (IOS 6.0.1) or may be there are multiple numbers saved with the same contact name. As this kind of bug was there in Nokia symbian phones
sudeep.pandya is offline   (1) Thanks Reply With Quote
Old 23rd April 2014, 21:47   #107
joshguy's Avatar
Thanked: 92 Times
Default AC filter Cleaning
Originally Posted by wildon View Post
Here is the i20 Climate Control Air Filter removal procedure. Its also mentioned in the owners manual under maintenance section.
Thank you sooooo much , just read it few minutes back and just ran to my car,pulled it our and found lots of leaves and dust
Cleaned the filters with soap water and kept it for drying,now the next problem is that i touched the metal part (guess cooling coil dont know the technical name) after removing the filter and it was also full of dust .now need to find out how to access it or else give for a AC overhaul in some good workshop.
this is a must try DIY
joshguy is offline   Reply With Quote
Old 12th May 2014, 12:37   #108
ssjr0498's Avatar
Thanked: 120 Times
Has anybody gotten a software upgrade on their i20 Diesel, I have a June 12, i20 Crdi and I heard that their is a upgrade available for the uphill acceleration for the diesel variants.
Upon connecting the G-Scan, I did see 2 upgrades, but the service center guys apparently didn't have a password required to complete the upgrade.
Has anyone ever got a upgrade done through the G-scan, if yes can you please narrate the process?
ssjr0498 is offline   (2) Thanks Reply With Quote
Old 12th May 2014, 15:24   #109
sabsubs's Avatar
Thanked: 40 Times
I went in February this year to the service center for a scan and did not see any upgrades on G-scan. Since when these upgrades are available for i20 diesel?
sabsubs is offline   Reply With Quote
Old 12th May 2014, 15:35   #110
ssjr0498's Avatar
Thanked: 120 Times
Came to know about it recently, but it has been there for a while.
When they connected the G-Scan and went to the "ecu" section, it did show up 2 updates. However, remember its only for the 2012 cars, the 2013 cars already have this.
ssjr0498 is offline   Reply With Quote
Old 4th June 2014, 16:10   #111
tilt's Avatar
Thanked: 563 Times
I just ordered May 2014 i20 Diesel Asta (delivery Friday Jun 6). i was wondering if there are ay other owners here of this model and if there ere any tips/tricks specific to the 2014 Asta.
Thanks and cheers
tilt is offline   Reply With Quote
Old 9th June 2014, 21:27   #112
Originally Posted by tilt View Post
Thanks and cheers
Congratulations!! I have the same model. I bought the March 2014-i20 Asta CRDi model and it's awesome. I have traveled 1600 km till today all within the city in the 2nd and 3rd gears only and the 4th gear very rarely. Of this, I had traveled 350 kms on the highway and even then I was able to use the 5th gear and never the 6th gear. Must be my driving skills (or the lack of it! ) And every km was with 100% AC. I didn't want the dust to enter into my new car. I checked the Fuel consumption today and I seem to be getting 17.86 kmpl. I am working on a detailed ownership review.
I got the Amber Grey color and loving it!! Which color did you book?
Vara is offline   Reply With Quote
Old 10th June 2014, 20:35   #113
tilt's Avatar
Thanked: 563 Times
Hi Vara, I took delivery of my Ember Grey Asta on Friday Jun 6, drove down to Madras on June 8 and drove back today. I used all the gears on the highway, and got around 14.71kmpl so far. My car has done 800 kms as of this evening.
Old 11th June 2014, 22:03   #114
Cheers!! I used to get about 13 to 14 kmpl initially too. The figures I provided (17.36 kmpl) was an average of since the first fill and the latest fill. So, I probably should be getting more since it is an average I have taken of the values right from the start.
I am planning to take a trip to a nearby city and I should get to use the 6th gear on the highway....
Old 22nd June 2014, 16:25   #115
bama's Avatar
Hi Guys,
i have been a proud owner of an i20 magna opt petrol model for the last 1.5yrs
recently a pmt bus dinged the rear quarter panel of my car.
now the sa is saying that they would cutout the entire quarter panel and replace it with a new one. my apprehension in doing this the impact to the structural integrity as i am not sure they would have the same quality welding machines at the workshop as they have in the factory.
the second concern is with the procedure the sa is proposing. does he really need to remove the rear quarter panel? there are scratches and some rusting . i have attached a photo of the quarter panel for reference.
the third concern is cost. the cost quoted for replacement of quarter panel is 15k approx. with insurance i pay approx 5k and lose no claim bonus.
do let me know your thoughts
thanks
gaurav
bama is offline   Reply With Quote
Old 3rd July 2014, 10:42   #116
_raVan_'s Avatar
Thanked: 487 Times
You dont need to do any of those. I have had the same experience in Pune itself with our i20 and gave it to a private garage in here. He repaired the dent and repainted it. All in within a range of 3k to 5k.
_raVan_ is offline   Reply With Quote
Old 3rd July 2014, 11:06   #117
Kishen.padiyar's Avatar
Thanked: 433 Times
The damage looks pretty bad. I had a similar damage on my car, and gave it for repair in the HASS. The dent wasnt even as bad as yours, yet they billed me 7.5k. That's after discount, as they had to repaint the quater panel and also a part of the bumper. So its going to cost you nearly the same.
Outside will be cheaper. Its your choice now.
Kishen.padiyar is offline   Reply With Quote
Old 2nd August 2014, 23:39   #118
Lightening-Fast's Avatar
Thanked: 11 Times
I am getting my delivery of I20 Magna(O) sometime in the next 2 weeks. I quite like the DRL on the sportz variant. I understand that such a fitment for the Magna would cost me around 20K. Are there cheaper options. I am not inclined to fiddle around with the stock wiring.
Lightening-Fast is offline   Reply With Quote
Old 17th August 2014, 17:27   #119
Thanked: 80 Times
I own a 2012, iGen i20 Sportz CRDi, BS IV.
I would like to know what kind of Diesel after treatment this car has?
Is it DPF or EGR + SCR?
Thanks in advance!
Pam81 is offline   Reply With Quote
Old 22nd August 2014, 23:00   #120
LOL_FWD's Avatar
Thanked: 154 Times
Posting this query on behalf of a friend.
Introducation:
He owns a 2013 model hyundai i20 asta. Car usually shuttles between Bangalore-Mangalore as well as used as a daily drive. As every owner of this model knows, the suspension is very bouncy. It's like a carnival ride especially on our fly-overs. We did test drive the new i20 elite and the suspension in that is just perfect.
Query:
How to make the suspension more stiffer?
Can the old damper be replaced by the damper's of the new i20?
Or replace the dampers with an aftermarket one?
If aftermarket, which company's product is suitable?
Don't want the car so stiff that it feels like i'm driving a rally car on J Anand's
Should be stiff and comfortable enough, like how we say "Best of both world's!"
LOL_FWD is offline   (1) Thanks Reply With Quote
Home remedies, tips & tricks for your car. Rtech Technical Stuff 65 20th September 2016 18:24
Xbox hacks, tips and tricks needed DCEite Gadgets, Computers & Software 23 28th January 2009 01:45
Drag Racing - Tips, Tricks and Good to know info. n_aditya Indian Motorsport 40 16th December 2008 13:51
New to 4 Wheelers and hope to learn good tips and tricks to maintain my car. tango6996 Introduce yourself 3 24th March 2007 12:27
