Old 11th April 2011, 13:56   #16
dhanushs's Avatar
Thanked: 4,507 Times
Default Re: How often should the transmission oil be changed?
Originally Posted by SPIKE ARRESTOR View Post
I presume you are pointing to Viscosity of the lubricant, am I correct?
Spike
ahh.. yes. Correct!.
You know my vocabulary.
Old 11th April 2011, 18:05   #17
Thanked: 103,700 Times
Guys, everyone is talking about kms only. Remember, oil can also go bad with time. The max that I would use the same transmission oil is 2 years.
Link to related thread (Maintain the car yourself. A service checklist)
Old 29th November 2013, 12:33   #18
heysac's Avatar
Thanked: 13 Times
My swift manual recommends 75w90 but it is not available in the market. Even though mine is run only 6700 km, it us close to completing 4 years so I need to change it. I am at the service station so any recommendation would be helpful.
heysac is offline   Reply With Quote
How often should we change gear oil? zaks Technical Stuff 156 12th January 2016 16:31
How often should I check my tyre pressures? rajesh1868 Tyre & Alloy wheel Section 73 10th August 2015 19:13
Mercedes Benz 300D (W123 series): Manual Transmission to Automatic Transmission. wartikars Post-War 5 3rd January 2014 12:39
Corsa Engine swap. 1.4 to 1.6 . Should ECU/M be changed too ? vdiatech Modifications & Accessories 13 14th August 2010 10:04
