Old 8th April 2011, 16:07   #1
wanderernomad's Avatar
Thanked: 786 Times
Default Indigo DICOR 3rd and 5th gears popping into Neutral automatically.
My Indigo Marina Dicor has been facing a peculiar issue for the past fortnight or so. While driving when I shift into 3rd gear and accelerate the gear pops back into neutral around 30-40 Kmph. However, if I shift into 3rd above these speeds the gear stays ok but when I shift into 5th it wont hold. There is a thak sound and the gear pops back into neutral. 5th cannot be engaged irrespective of the speeds unlike 3rd which slams itself back into neutral around 30-40 kmph. There is no noise from the transmission and all other gears work fine. What could eb the cause here, help.
wanderernomad is offline   Reply With Quote
Old 8th April 2011, 16:11   #2
Thanked: 110 Times
Default Re: Indigo DICOR 3rd and 5th gears popping into Neutral automatically.
Check the synchronizer.
vijaycool is offline   Reply With Quote
Old 8th April 2011, 17:18   #3
Thanked: 786 Times
But wont a problem with synchroniser affect operation of all gears and not just 3rd and 5th?
Old 8th April 2011, 22:27   #4
SPIKE ARRESTOR's Avatar
Thanked: 744 Times
Improper meshing of gears, worn gears, synchronizer faulty, faulty shifter mechanism / poppet ball & spring can be among the causes. Will need opening up if occurs frequently.
BTW, how many kms has your car run?
Spike
SPIKE ARRESTOR is online now   Reply With Quote
Skoda Superb Diesel DSG: Hunting for gears after 3rd searchingheaven Technical Stuff 7 28th July 2014 17:12
Scorpio MHawk-5th Gear Slips to Neutral akshay4587 Technical Stuff 15 16th December 2011 00:02
Tata Indigo XL Classic Dicor - 20,000 KMs & 3rd Service Update Bouncer Test-Drives & Initial Ownership Reports 91 30th May 2010 22:00
Santro gear shifts suddenly into neutral nura Technical Stuff 18 11th August 2008 14:21
