Old 12th April 2011, 20:24   #16
WhiteKnight's Avatar
Thanked: 73 Times
Default Re: New generation cars : Pushing to start ineffective when battery is flat?
Originally Posted by allajunaki View Post
In The end I turned the Car OFF, in about 2 minutes, simply because
A. ECU was not responding to throttle, and battery shown no sign of coming back to life.
B. I was worried that Car was not producing enough to start the Radiator fan, so I might overheat the Engine.
I guess you missed a opportunity. You should have trusted the ECU to do the things. The ECU was functioning obviously, after all it is not a device that eats power like, say the pump. My hypothesis is that it would have activated full functions once battery is charged sufficiently (say 10 min of idling). Anyway, no way to test it now.
As long as ECU is working, you could never get the engine over heated, it was already in limp mode.
WhiteKnight is offline   Reply With Quote
Old 13th April 2011, 10:56   #17
Thanked: 16 Times
GTO, Is there anything special, that needs to be taken care for AT versions?
When should one start worrying about battery change?
In the cars that I have driven (one AT and one geared version). I have gone by the service advisors requests for change of battery. Any points to watch out for?
There are jump starters with some battery available in the market which will allow you to jump start the car. Kind of a mini battery and a jump starter.
anupamsinha is offline   Reply With Quote
Swift VXI : Flat battery. Push start didn't work? amitk2kin Technical Stuff 29 28th May 2011 14:33
i10 Kappa refuses to start. Battery flat? jango Technical Stuff 39 21st May 2009 13:28
Pushing one's luck... doomsday Street Experiences 27 5th September 2007 08:52
pushing the carb zen. heavy_foot Technical Stuff 12 2nd November 2005 16:37
