Old 13th April 2011, 15:52   #1
vibhu_f430's Avatar
Thanked: 67 Times
Angry Serious issue with my Swift vdi
Hello team,
My swift has done 52k Kms , 2.6 years old. last evening i was driving around in the city when there was this huge 'thunk' noise and the steering was feeling weird . Like the front wheel was jammed . Got out and checked to find this,
Right wheel
Left wheel
The wheel is like this even when the steering is straight ,
The end of the drive shaft is cut-off ! the lock nut is missing .The service personnel have told me that they have never seen anything like this ! Right now the car is in maruti service masters since the car has been serviced there from the beginning. I have complained about the noise from the 30k service, and because of their incapability, a critical part failure has happened.
Has this happened to anyone else on the forum ?
@experts: I want to know what other parts can be damaged as a consequence of this ? Like brake pad, brake disc, wheel bearing etc ? I don't want to end up paying for their negligence .
vibhu_f430 is offline   Reply With Quote
Old 13th April 2011, 16:36   #2
Thanked: 28 Times
Default Re: Serious issue with my Swift vdi
This is bad, last week Maruti Swifts were recalled due to engine issues. We all thought that Maruti stands for reliablity. On the other hand company like, Ford has improved in its product and service. Figo is a good example. Its not only cheaper than a swift by 60K spec to spec but also has lower cost of spares.
kavesh55 is offline   Reply With Quote
Old 13th April 2011, 16:47   #3
deep_bang's Avatar
Thanked: 343 Times
well, i really dont know how can the shaft cut off. It could bend, it could crack, but such a neat cut - surprising.
Are you sure you dont have any enemies . Just kidding!
I dont think one can generalize Maruti's quality because of this issue. Any car might have had this issue. What is important is how well does Maruti handle the situation, explain why this happenned, and provide a satisfactory resolution.
If what Vibhu says about having a problem since a long time, is really linked to this, then Maruti should make sure a satisfactory solution is given free of cost (or a nominal cost).
deep_bang is offline   Reply With Quote
Old 13th April 2011, 18:06   #4
soumobakshi's Avatar
Thanked: 565 Times
I have seen this happen in a Bus (While I was on board ); and you were lucky to be able to stop the vehicle in time, else the wheels would have left your car behind!!
These MASS are known to provide a breakfix solution without doing an RCA and finding the actual cause. I have experienced the same with my Wagon R where the combination switch panel had burnt twice. And both the times they were just happy to replace the part under warranty without checking why was this happening. Only on my insistance at the 2nd instance did they feel the need for it and came back with the actual cause of a faulty power connection providing excess power to the combi switch.
The MASS involved in my case was Sagar Automobiles in Bangalore.
soumobakshi is offline   Reply With Quote
Old 13th April 2011, 18:12   #5
rangarx's Avatar
Thanked: 116 Times
Infractions: 0/1 (5)
Lucky you were mate! I just experienced worser experience in my friend's beat. That is discussed in a separate thread.
rangarx is offline   Reply With Quote
Old 13th April 2011, 18:21   #6
v&v
v&v's Avatar
Thanked: 1,099 Times
@ vibhu_f430 , you were lucky, nothing serious happened. it could have badly damaged the car.
IMO either car's lock nut was not tightened fully, there might me play or its a manufacturing defect. Did you get light vibration on steering while accelerating ?
v&v is offline   Reply With Quote
Old 13th April 2011, 18:29   #7
supremeBaleno's Avatar
Thanked: 1,711 Times
Hmm, that is bad for a less than 3-year old car. My Baleno's RHS drive-shaft failed at 5years and I thought that was bad.
In another thread a new Chevy Beat (5months old) has front suspension failure.
EDIT : Just saw that rangarx has mentioned the Beat in his post above.
Old 13th April 2011, 18:53   #8
Awaiting Email Confirmation
Thanked: 319 Times
Seeing the deep indentation on your normal right wheel on the nut as well as the lock area it is sure that they did open your main nuts to lubricate the rubber boot or to change the boot. They did this in the affected side too but over tightened the nut with a long bar and tightened it by standing on it which you will see truckers do when changing their punctured tire. The strain and stress expressed itself when in your hands.
Its an A>S>S issue and nothing else.
drpullockaran is offline   Reply With Quote
Old 13th April 2011, 20:21   #9
Jaggu's Avatar
Thanked: 8,694 Times
Really shocking to see this, i have never heard or seen such a sight in the swift. As drpullockaran mention ^^ it can be an a.s.s issue, over tightening, impact with hammer to remove a jammed axle etc or a freak failure of the cast.
Old 13th April 2011, 22:35   #10
vibhu_f430's Avatar
Thanked: 67 Times
Yeah man, saw the pics. That real bad . Whats happening now ? Is GM willing to pay for the accident damage due to their part failure ?
The thing is, there has been some problem for like 25k kms now.
>>(The vehicle is moving in gear) when i step on the gas there is a 'thunk' noise. When i get off the gas ,again there is a 'thunk' noise. I first complained in the 30k service.
The noise stops for like 3-4k kms and again starts !. They keep adjusting play in some 'yoke shaft' or say the baring has worn out or some crap .
Complained about the same problem 4 times now. 30k, 40k, 43k, 50k . The car came back from 50k service only 2 weeks back !
They changed the left front wheel bearing 2 times in 50k kms ! Is that normal ?
Even after repeated complaints they haven't done any part replacement under warranty. And my warranty expires in July !
Old 14th April 2011, 00:27   #11
SS-Traveller's Avatar
Thanked: 11,631 Times
It looks to me like there has been work done on the driveshafts earlier on - someone apparently didn't do a good job of fitting the retaining nut back on and locking it in place. Please confirm this, Vibhu, was an axle boot changed earlier, or work done on the front wheel bearings, etc.?
Old 14th April 2011, 00:54   #12
n.devdath's Avatar
Thanked: 2,154 Times
Take the issue up with Maruti directly. They are better responsive compared to many others. It is evident that this is dealer carelessness. Take a print out of your car's service history and it will surely have had its front wheels greased in the recent past or some other work done on the same lines.
Use that to prove your point. It should be taken care of under warranty.
Old 14th April 2011, 06:00   #13
MileCruncher's Avatar
Thanked: 357 Times
As already mentioned, the workmanship was not upto the mark while doing the job on driveshaft or wheel bearing. I would suggest contacting people directly in MUL with your service history. If the dealership is unable to comprehend the problem, its time to escalate!
MileCruncher is offline   Reply With Quote
Old 14th April 2011, 10:20   #14
mac187's Avatar
Thanked: 333 Times
Originally Posted by vibhu_f430 View Post
Hello team,
M.A.S.S will have a service history of all the cars regularly serviced at their workshop. The system records the complains/ parts changes etc of the car. If you had complained about the noise and it has been recorded them you have a good chance of asking them to bear the cost. It wont be easy though.
Dont you have extended warranty?
mac187 is offline   Reply With Quote
Steering assembly issue in swift vdi samy3660 Technical Stuff 22 17th February 2018 23:24
Power steering issue in my Swift VDI DieselFan Technical Stuff 23 17th May 2013 00:15
My ka Laal: Swift - Oye VDi, VDi Oye! - 12 months, 29.3k km UPDATE phamilyman Long-Term Ownership Reviews 89 7th May 2010 17:13
Why is Ritz VDi more expensive than the Swift VDi ? Tapan The Indian Car Scene 49 1st June 2009 18:19
Swift VDI or Getz GLX-6L Budget EDIT: Bought VDI agm Hatchbacks 29 11th April 2008 22:56
