Old 19th July 2011, 16:02   #16
grkannah's Avatar
Default Re: About the Matador F-305 engine
Originally Posted by dmaheshkumar View Post
I have used F305 engines in my ambassador for more than 12 years.That too its an engine which has done more the 2,50,000 Kms.
My friends and some of my relatives still using the same engine in Ambassador,It was a very fine engine.Starting problems will only creep up in the engines which was not maintained and done more than 1.5 lakhs kms.
If you overhaul,Surely you will not face the starting troubles.My uncle fitted A/C, power steering for it and still it was a trouble free engine.
Almost more then 80% of the Ambassadors has fitted this engines.First Engine change was done by CAG,coimbatore.They are the first to replace the petrol to diesel engines. (F305 engines).
Hi i have a used ambassador with matador engine. I bought it for my dad who is a fan of ambassador's. I am planning on completely overhauling the whole vehicle, from shell painting, interiors, engine upgrade to isuzu G1 diesel. Since you have already done these, could you please help me out?
grkannah is offline   Reply With Quote
Old 19th July 2011, 16:34   #17
dmaheshkumar's Avatar
Thanked: 18 Times
Ya sure...Working with Amby alws great.
Since you are in chennai you can get G1 engines very easily...Pudhupetai is the main area.
There are 2 types of G1 engines.Old one will have a bit big naussil tube...
When your process get start,kindly open a new post from your end and update the process.
dmaheshkumar is offline   Reply With Quote
Old 14th April 2012, 18:26   #18
Thanked: 19 Times
Default F 305 matador DI engine
I came across this engine while looking for a gen set in the local scrap market.It has the F305 block with direct injection head and the F stamping on the tappet cover.The inlet manifold is also different from the normal IDI F305 engine.It is coupled to a Greaves 15 kw alternator running at 3000 rpm.The set has been removed from sound proof canopy.I asked the dealer for the engine alone for a jeep,but he will only sell the complete set for which the price was 85000/-.The pics are attached.
hps aulakh is offline   Reply With Quote
Old 14th April 2012, 19:58   #19
Frankenstein's Avatar
Thanked: 300 Times
Default Re: F 305 matador DI engine
Not worth it. ITs not worth more than 10k .
Frankenstein is offline   (1) Thanks Reply With Quote
Old 14th April 2012, 22:48   #20
Thanked: 19 Times
Do you know if these ever came in any Force Motors vehicles.The year of manufacture is 2005.I was just wanting to experiment by trying it in a Jeep.
Old 14th April 2012, 23:21   #21
rajeev k's Avatar
Thanked: 1,750 Times
The engine, perhaps, was made by Force for Greaves gen sets with a 3000RPM speed governor. This engines may be developed from the one used in cars. If could be similar to engines once installed in many Ambassadors in the early 90s. If yes one can get a better engine with an Ambassador car for less than Rs 50K
rajeev k is offline   Reply With Quote
Old 16th April 2012, 11:01   #22
Thanked: 19 Times
What is surprising is why Force Motors did not introduce this engine in the market for repowering of different vehicles.Could any member check if this engine is available as brand new with the company.Because weight wise this should be very light,and had a good record earlier.
Old 17th April 2012, 23:23   #23
Thanked: 825 Times
Originally Posted by hps aulakh View Post
can any body give the specifications for both the f305 and the om616 engines including their weight.
Something is on bhp only & that might help you .
Check this ( My posts # 44 & 45 ) & the whole thread too
http://www.team-bhp.com/forum/commer...ml#post2586705
Sudarshan
P.S. allow me some time to find more on the OM 616 I think I have something -- need to dig deep in the Library .
Sudarshan is offline   Reply With Quote
Old 17th April 2012, 23:30   #24
rajeev k's Avatar
As per the name plate the engine develops only 22.5 BHP which is way too less.
The engine was available as new in those yester-years. Regarding the present, perhaps, TBhpian Skyline GT-R could throw light here as he is with Force Motors.
Old 24th April 2012, 14:18   #25
Thanked: 19 Times
The original F-305 was an indirect injection with a diaphragm FIP,while this is a direct injection engine with a mechanical FIP.I want the info regarding this engine and not the older model.DI engines do not have the starting problems which the older engines had. Hope Skyline GT-R can help out with this.
Old 18th November 2012, 19:27   #26
hi i have a 1966 willys jeep looking for a five speed gear box for the hurricane petrol engine request our senior bhpians to comment
pints12 is offline   Reply With Quote
Bajaj Tempo Matador F305,F307 and R307 vans ashwanth Commercial Vehicles 60 19th June 2017 21:03
Remembrance - Bajaj Tempo Matador's sibling, the Viking rajeev k Post-War 9 17th April 2011 13:29
Mahindra 4wd jeep swap with matador engine vipinmohan 4x4 Vehicles 4 24th January 2010 09:26
1959 Willys - Is Matador diesel suitable? jenz SUVs, MUVs & 4x4s 11 6th December 2009 07:54
305 MPH(Limited) Mosler MT900 GTR XX Twin Turbo Land Shark!! AyAn! The International Automotive Scene 17 12th May 2009 14:29
