Old 7th November 2013, 17:04   #1996
Default re: Review: 2nd-gen Hyundai Verna (2011)
Originally Posted by Shome View Post
NVH stands for Noise Vibration and Harshness. Basically to do with the engine noise and the manner in which the vibrations and the harshness are felt in the vehicle while on the road.
Diesels are notorious for having a high NVH due to the high compression ratio. This is mainly controlled or muffled by using some damping material around the engine and under the hood. Certain high end vehicles also use stage wise injection which ignites the fuel in stages during the compression cycle.
Verna/Hyundai is quite good at managing the NVH in their vehicles.
Yes, this is totally correct. I agree. Even Ford is very good in maintaining a low NVH.
ryadav is offline   Reply With Quote
Old 7th November 2013, 21:38   #1997
Thanked: 91 Times
Hi All,
From yesterday, AC of my car ( 1.6 CRDI SX) has stopped working due to leakage of gas. Standard warranty is now over & I have not taken any extended warranty. Car is 26 months old & has done 39k. One thing for sure is Hyundai is still way behind in reliability front when compared to their Japanease counterparts. Took the car to local HASS today & after inspection, they concluded that there is a leakage in cooling coil. The cooling coil requires replacement. Their quote is placed below:
1. Cooling coil- Rs 4,600/-
2. Gas- Rs 900/-
3. Labour- 1800/-
TOTAL : Rs 7300/-
Is the quote ok? How come cooling coil develops leak so early? My 6 yr old Wagon-R had absolutely trouble free AC. Should I get the car inspected from some other service station? FYI, I am sure of the gas leakage as the pressure check was done in my presence.
I request for urgent inputs from BHPians.
Chitta Pradhan is offline   Reply With Quote
Old 8th November 2013, 10:20   #1998
Fusion2006's Avatar
Thanked: 23 Times
Originally Posted by revved_up View Post
What I dont like:
- Paint quality: The paint is very very delicate and a small nudge can also cause the paint to come off. On highways i have to be very careful that i am not following any behicle too close, because even a small stone causes the paint to chip.
Agreed ! Though all over TBHP the consensus seemed to be that Teflon coating is not worth it, and I did not get it done, I really wish I had. Might have saved a few chips of paint for me
Fusion2006 is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 13:39   #1999
revved_up's Avatar
Thanked: 210 Times
Come to think of it, I think it would really have been worth a try.
BTW, I have not had teflon on any of our cars and Verna is the only one which suffers from this extra delicate nature.
revved_up is offline   Reply With Quote
Old 9th November 2013, 12:03   #2000
CARDEEP's Avatar
Thanked: 1,485 Times
Originally Posted by Chitta Pradhan View Post
Hi All,
2. Gas- Rs 900/-
3. Labour- 1800/-
TOTAL : Rs 7300/-
Hi @Chitta Pradhan
Are you sure on the highlighted part or just unhappy because your car's got a problem? What other problems you have faced? Hyundai has taken giant leaps on quality & reliability fronts & matches the Japs. It the ride+handling & interiors where the European are a notch higher.
FYI, please peruse link below for the discussion I had with another TBHP-ian (@mail4ajo) re clutch problem in Jazz:
http://www.team-bhp.com/forum/offici...eview-138.html
My car's clutch is still going strong at ~85k kms & there are no other problems (off late sticky power windows) that his & few other TBHP-ians are facing, as per later posts.
Re repair of your AC, have your tried taking quote of any good car AC expert in your vicinity. Do refer TBHP Directory for the same, probably it will be of some help.
PS: Apologies to TBHP-ians whose name (s) + post (s) I have, here, referred to, without their permission.
CARDEEP is offline   (1) Thanks Reply With Quote
Old 9th November 2013, 15:21   #2001
Thanked: 91 Times
Originally Posted by CARDEEP View Post
Hi @Chitta Pradhan
Hi
The underlined portions are purely my personal experience. Before Verna, I had used three old gen Marutis, 800, old Zen & Wagon-R for approx. 12 years. Never had such unexpected faults in those old cars. Current Maruti etc. should have been still better.
Problems faced by me during my last 26 months of ownership are:
- Current AC problem.
- Rear sensor replaced three times under warranty.
- Horn relay replaced under warranty.
You can see that I had made five unscheduled visits to Hyundai service station with my Verna. I am sure this would have been less/ NIL had I taken a SX4. Just my opinion. Others may or may not agree.
Is your 85 k done car a Hyundai? Are you saying that you are still on original clutch plate? If it is so, then it is really great going. Cluth plate of a Santro of my Sister went for new clutch plate few days back at around 60K.
Old 9th November 2013, 16:28   #2002
CARDEEP's Avatar
Hi
Hmm... it seems your are facing niggles, for which even I do not know could have cropped up in a Hyundai .
However, these days there are many companies doing the warranty replacements, which is good as it builds trust of the company backing the customer in case of any problem & also conveys that the company is willing to correct any mistake or problem with the product.
Not sure, about other cars, but I'm sure you won't have been happier in a SX4, for it's got more body roll & the interiors are a notch lower than Verna.
Mine is a '03 Santro Xing, which has been primarily driven either by me or my brother. But, there have been phases when we have hired drivers for few months to have family member chauffeured around town. And yes, its most of components have never been replaced, except tyres at 44K kms, front shock absorbers at ~50k kms, fuel pump at ~62k kms & gear stick leather cover.
In fact, it was our first car straight after the driving school & now I can say that we have become proficient driving the car.
These days it runs on CNG+Petrol, & I believe I will retain the car for few more years despite increasing mileage, because of its reliability.
I am also attached to the car, because it has been a trusty companion all the 10 years, being a part of good & bad times, not complaining once. If I were to describe my experience with my car in one word, I would say it has been "brotherly", & has helped build trust & faith in brand Hyundai.
Old 11th November 2013, 21:47   #2003
revved_up's Avatar
Thanked: 210 Times
Originally Posted by Akshay.Hemmady View Post
Finally managed to get hold of this. MRP showed 1296/- though. I dont think there maybe another way to get hold of this
Was this ordered through Hyundai service centre? Can you please share the part number, a friend wants it too.
Old 14th November 2013, 19:03   #2004
h@r$h@l's Avatar
Thanked: 686 Times
Hello,
Today on way home from office i saw a fairly new RED color fluidic verna. It wasnt one of those cherry reds. It was the kinda red we see on Polo and Vento.
When did Hyundai launch a RED color for Verna? And honestly speaking, it didnt suit the car at all. Just my opinion. No offence to anyone.
h@r$h@l is offline   Reply With Quote
Old 18th November 2013, 12:03   #2005
sinharishi's Avatar
Thanked: 694 Times
Updated Verna(Again?)
- Projector headlights and integrated day-time running LED lights (DRLs), which in India will be reserved for the top-end variant, or be offered as optional equipment.
-The steering-mounted controls have been reworked for better ergonomics.
- The infotainment system, along with the audio has been updated as well.
Its India launch will coincide with the 2014 Delhi Auto Expo.
Source: http://goo.gl/hqKrUJ
sinharishi is online now   Reply With Quote
Old 18th November 2013, 15:56   #2006
Guys - Need some advise on insurance. My insurance is due for renewal next year Feb. Getting calls for Tata AIG, offering premium if Rs 22,000/- Zero % Dep. This includes 20% NCB, 40% discount and 10% commision wave off. First year insurance was for 30K. Does this sounds good? Have never dealt with Tata AIG before also. Please suggest. Thanks.
Old 27th November 2013, 10:38   #2007
madhav14's Avatar
Thanked: 117 Times
I work in the insurance department itself and deal with many insurers daily. Tata AIG is a fairly good insurer and their service is also decent and responsive. And that quote isn't bad either.
But, I recommend to get a couple of quotes from your existing insurer and other insurers like Future Generali or Bharti AXA just to compare and make sure that you got the best quote and to bargain further with them if possible.
When will they firm up their suspension?
By the way, does any body know if there are any after market suspensions for enthusiasts available for Verna Fluidic?
I totally love my verna in every aspect, except for its soft suspension. It's marvelous engine doesn't deserve that setup. Heard long backthat some guys in bangalore are preparing a TEINS street suspension for Verna.
Does anybody know about it?Can any body help me with this?
madhav14 is offline   Reply With Quote
Old 28th November 2013, 13:49   #2008
scarlet.fever's Avatar
Thanked: 25 Times
Guys I can't find any review for petrol 1.6 manual transmission.
Could somebody guide me to that ?
scarlet.fever is offline   Reply With Quote
Old 30th November 2013, 20:12   #2009
Thanked: 91 Times
Originally Posted by madhav14 View Post
I
Exactly my feelings.To me, the only problem is soft rear suspension. I am fine with the front suspension & steering feel till 140/150 kmph unlike many. I have talked to the service station for stiffer rear set up. He told me that if the rear springs will be replaced by spring of Accent's ( provided they fit into Verna), then rear can be stiffened. Approx cost of one spring is Rs 600/-. Can any one throw light on this, or any other method like spacers etc to stiffen the rear of Verna ?
Old 1st December 2013, 12:20   #2010
sagarpadaki's Avatar
Thanked: 1,256 Times
Unfortunately there are no after market suspension for Verna from any of the suspension majors. Remember Verna is called as accent in foreign markets. So if you find any suspension manufacturer having a set up for accent then it will fit Verna also.
As far as red rooster and their suspension for Verna is concerned its a joke. They said they are working on a setup for i20 as well. They give the same standard reply every time.
sagarpadaki is online now   Reply With Quote
The 5th-Gen Hyundai Verna: 1st Ownership Review RaghuChn Test-Drives & Initial Ownership Reports 126 8th December 2017 16:53
Review: The 2nd-gen Maruti Dzire GTO Test-Drives & Initial Ownership Reports 575 8th December 2017 10:18
Review: 2nd-gen Honda Jazz GTO Test-Drives & Initial Ownership Reports 2329 17th November 2017 18:05
Hyundai Verna (2nd gen.) : Tyre & wheel upgrade thread Tassem Tyre & Alloy wheel Section 35 21st April 2017 10:59
2nd Bus & Special Vehicle Expo 2011: 9-12 March 2011: Hyderabad, Andhra Pradesh Safari_Beast Commercial Vehicles 38 27th March 2011 07:07
