Old 15th October 2011, 14:12   #1366
KPS
KPS's Avatar
Thanked: 4,798 Times
Default re: Review: 2nd-gen Hyundai Verna (2011)
Originally Posted by manumike View Post
I was in doubt as to whether putting the new seat cover will create an issue for the side air bags. I had a word with two dealers here in Trivandrum. While one immediately said NO and that it should not be done, the other dealer said there are no problems in doing it.
Could someone please shed some light on this? I would rather have my car dirty than hamper with the functioning of the airbags.
Please see page 5-32 of the manual which states "Use of seat covers could reduce or prevent the effectiveness of the system
KPS
KPS is offline   (1) Thanks Reply With Quote
Old 15th October 2011, 14:20   #1367
puchoo's Avatar
Thanked: 750 Times
Glad to hear that!! look forward to seeing an ownership report and some images of the car!
I have covered close to 8K kms on the car and journey has been very good so far.
puchoo is offline   Reply With Quote
Old 15th October 2011, 14:40   #1368
swiftnfurious's Avatar
Thanked: 6,527 Times
Originally Posted by Chitta Pradhan View Post
@ Swifttnfurious: No relay installed. The mechanic did not advise for it.Thanks
I suggest you consult with couple of more mechanics or the mechanics [NOT SA] in your HASS on installing relay for the higher wattage bulb. In every post that I have read about installing 100/90 bulbs, people have suggested a relay also be installed.
swiftnfurious is offline   Reply With Quote
Old 15th October 2011, 14:58   #1369
el lobo 6061's Avatar
Thanked: 986 Times
@wolfff: I did head light upgradation( philips 100/90 w) after market. The service advisor at the dealer was against it & had advised me to stick to the stock bulbs ( halonix-60/55 w).
I would advise you to get the relays installed ASAP. The 100/90W bulbs produce a lot of heat which many a time results in the wire getting burnt. Have faced it with my dad's Indica DLS.
Get the relays installed of either Bosch or PMP. Dont settle for anything less. Road side mechanics want you always keep coming to them for some or the other work which could have been done in the first place.
My 2p.
el lobo 6061 is offline   Reply With Quote
Old 16th October 2011, 19:10   #1370
Thanked: 93 Times
Can some one explain me how a relay will be helpful & what is it's function?? With the relay installed, can I go for still powerful bulbs eg. Philips 135/130 or so.
Today returned from another long drive-520 km to & fro with almost nil city driving. FE 19.2 TFM, 100% AC, speed 120 kmph when ever the road permitted. I think FE can be 20+, if a speed of 90-100 kmph is maitained. Next time I will surely give it a try.
Chitta Pradhan is online now   Reply With Quote
Old 16th October 2011, 20:03   #1371
Found this thread while searching.
http://www.team-bhp.com/forum/techni...att-lamps.html (Why relay for high watt lamps)
It's mainly to prevent the bulb getting fused and also to prevent wire burn out I guess.
I would say anything beyond a 100/90 is an overkill. With the extra wattage, you also get extra heat & load on the battery. There are high chances you will damage the reflectors too when you use such high power bulbs. If you run long during night, its also suggested that you use ceramic holders which can handle more heat from these bulbs.
Old 18th October 2011, 21:48   #1372
Thanked: 93 Times
Today my car's rear parking sensor has malfunctioned. When reverse gear is put, it beeps continously even when there is nothing behind the car. What could be the problem? Any ideas plz.
Old 18th October 2011, 21:56   #1373
Tassem's Avatar
Thanked: 435 Times
This happened to me once. Only thing I noticed was that the car was exceptionally dirty. Gave it a thorough wash and it fixed the beep issue. I'm guessing the sensors act up when they're dirty. Sounds weird, but I have no other explanation.
Try hosing down the sensors and see if they still beep.
Another thing is that sometimes when I engage reverse, the sensor beeps thrice instead of the usual single beep with pause. To be precise instead of the beep pause beep, its beep-beep-beep pause beep-beep-beep. And its not the same as the one when you get closer to an obstacle.
Tassem is offline   (1) Thanks Reply With Quote
Old 19th October 2011, 11:05   #1374
Thanked: 60 Times
Hyundai is offering stiffer suspension upgrade in Russia to address vernas high speed handling problem free of cost,after all around criticism in Russian press.Wonder when we get that?
drchernish is offline   Reply With Quote
Old 19th October 2011, 11:16   #1375
Thanked: 93 Times
@Tassem- I will do a thorough rear wash & then see if the problem persists. Thanks for your advice. Without proper working of the rear sensors, it is very difficult to park the car in a tight spot.
Old 19th October 2011, 11:44   #1376
If washing doesn't solve the issue, one of the sensors would have conked off! I have had this problem in my Swift too. Tried washing & all and it still kept beeping. Finally checked at MASS & found out that 1 of 4 sensors is damaged. You probably should be able to source a single sensor & rectify the issue.
Old 19th October 2011, 16:07   #1377
puchoo's Avatar
Thanked: 750 Times
What would be the cost for a single sensor?
Old 19th October 2011, 16:11   #1378
Guess I was quoted a 250/- odd for some local stuff. Not sure how much is Hyundai charging for theirs - Should be around 500/- at the max is my assumption.
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 19th October 2011, 18:52   #1379
Thanked: 93 Times
Even after washing & cleaning of all the sensors, the problem continues. I think I have to replace the faulty sensor. Doubt that whether new sensors are available at the service station or not? Does sensor of any other Hyundai car fits in? I believe, this should be covered under warranty. Service station is 60 km from my place. Tomorrow I will talk to the service manager & then will decide what to do.
Old 19th October 2011, 19:04   #1380
Tassem's Avatar
Thanked: 435 Times
It should be covered under warranty. Though I doubt if they'll have individual sensors.
Tassem is offline   Reply With Quote
The 5th-Gen Hyundai Verna: 1st Ownership Review RaghuChn Test-Drives & Initial Ownership Reports 133 19th February 2018 11:17
Review: 2nd-gen Honda Jazz GTO Test-Drives & Initial Ownership Reports 2331 14th February 2018 13:42
Review: The 2nd-gen Maruti Dzire GTO Test-Drives & Initial Ownership Reports 575 8th December 2017 10:18
Hyundai Verna (2nd gen.) : Tyre & wheel upgrade thread Tassem Tyre & Alloy wheel Section 35 21st April 2017 10:59
2nd Bus & Special Vehicle Expo 2011: 9-12 March 2011: Hyderabad, Andhra Pradesh Safari_Beast Commercial Vehicles 38 27th March 2011 07:07
