Old 7th July 2011, 16:10   #61
luky_13's Avatar
Thanked: 116 Times
Default Re: Skoda Laura, Ambiente 2.0 TDI DSG : Ownership Experience
Originally Posted by Santoshbhat View Post
I followed the exact instructions as you have mentioned, and I did hear the 'ting' after three seconds. But the DRLs don't seem to have come on. I presume you don't have to turn the headlight switch to any position for the DRLs to come on.
I am guessing it has to be activated first via vag-com for this.
As Akki has mentioned maybe a VAG-COM intervention is a must, sorry buddy tough luck. PM me if you want to use Mr. VAG to unlock these hidden treasures.
luky_13 is offline   (1) Thanks Reply With Quote
Old 8th July 2011, 11:45   #62
Santoshbhat's Avatar
Thanked: 3,986 Times
Thanks luky_13. But I guess I have don't have the balls right now to let Mr. Vag go inside my Laura's brain . Blame it on the Skoda effect. I will just live with stock features right now. Hopefully someday I can muster up the courage
Santoshbhat is online now   Reply With Quote
Old 12th July 2011, 18:22   #63
vinj14's Avatar
Thanked: 259 Times
True, for the DRL's to work with that maneuver Vag activation is a prerequisite.
I've noticed a couple of issues in my one week old laura 2.0 DSG elegance.
1) I have auto AC (climatronic) in my laura and within ten minutes of turning them on i get small fog clouds in the middle portion of windshield. Did anyone else face this problem? Its starting to get annoying.
2) Another doubt i had was about the brakes. I noticed a small scratching sound when i release the brakes or press them hard for that matter. Im not sure if this is a problem because i used to hear the same sound in my 2001 accord automatic (but i presumed the noise was just another sign of the car ageing). I also test drove the vento AT and heard a similar noise, but in that case i assumed that the test drive car was just poorly maintained. So is this seen in most cars with automatic transmission or is this a sign of a problem in the car? Hope i've described the problem adequately.
Awaiting your expert opinions!!
vinj14 is offline   Reply With Quote
Old 12th July 2011, 18:34   #64
.anshuman's Avatar
Thanked: 9,205 Times
This is a known issue due to air leaking towards windshield. This is common to all Lauras, i increase the temperature when front windshield starts fogging. It only happens on rainy/really humid days.
Old 12th July 2011, 21:06   #65
Ace F355's Avatar
Thanked: 1,753 Times
+1 to anshuman and the same issue is in my Civic too. The only way to reslove this is, increase the temperature a little!
Ace F355 is offline   (1) Thanks Reply With Quote
Old 12th July 2011, 21:22   #66
The windshield fogging up is common in most Lauras. Since you are from Chennai, you would be affected more than people living in drier climates. I suggest you turn the air flow knob slightly towards the feet, not all the way. I have tried this a couple of times and it has helped in reducing this effect.
Brakes have no relation to the car being AT or MT. I am guessing your car is new. Brakes need to run in. Wait till you complete about 600 ~ 700 Kms. If it still persists, have your dealer check it out. THe brakes on my Laura feel much better and progressive now after 1500 kms, than the first 500, when they were very grabby and brought the car to a sudden halt.
Santoshbhat is online now   (1) Thanks Reply With Quote
Old 12th July 2011, 23:20   #67
cedricsg's Avatar
Thanked: 24 Times
absolutely agree. Did this on my TSI & it did the trick. Another option, is just put an anti skid mat just in the centre of the dashboard near the glass.
cedricsg is offline   (2) Thanks Reply With Quote
Old 15th July 2011, 00:27   #68
Awaiting Email Confirmation
Thanked: 66 Times
both issues are common with Lauras.
1) take it to the workshop. they'll fix the air leak for good. had mine fixed within a week of buying it and no problem since the last two years.
2) brakes tend to make scratching sounds at time, i've heard its because of the moisture. not sure about this. however, this is nothing to worry about.
Akki_5 is offline   (1) Thanks Reply With Quote
Old 19th July 2011, 09:27   #69
rohitm's Avatar
Thanked: 43 Times
Hi Akki,
Do you know what does the workshop do to fix the leaks? I have a similar problem in my Laura and am sure there are more bhpians having similar issue.
rohitm is offline   Reply With Quote
Old 20th July 2011, 00:20   #70
Thanked: 66 Times
they fix the air leak from the vent right next to the windshield (the long one used to de-mist the front windshield). its supposed to be shut unless you turn it on but this seems to be a manufacturing defect Skoda hasn't corrected in the last two years.
Akki_5 is offline   Reply With Quote
Old 20th July 2011, 03:31   #71
Berj79's Avatar
All they do is seal the vent i guess..
Berj79 is offline   Reply With Quote
Old 20th July 2011, 08:20   #72
Maibaa's Avatar
Thanked: 39 Times
If they seal the vent, how can you de-mist the windshield then?
Maibaa is offline   Reply With Quote
Old 22nd July 2011, 01:00   #73
Thanked: 66 Times
They don't 'seal' the vent. They just fix the leak/ gap which lets air pass even when the vent is closed. Then when you close the vent, there is no air flow; when it's open, there is full air flow.
Akki_5 is offline   (2) Thanks Reply With Quote
Old 22nd July 2011, 13:47   #74
Berj79's Avatar
Will tell the workshop guys to do it when car goes for service.
Thanks..
Old 23rd July 2011, 10:27   #75
rohitm's Avatar
Thanked: 43 Times
I suspect they open the complete dash to do this fix. Have you noticed any rattle after this job? Are you happy with the fix as well as the dash fit post the job?
Skoda Laura Ambiente MT TDI. EDIT: A poor experience with Giriraj Motors Behemoth Test-Drives & Initial Ownership Reports 110 16th September 2017 17:10
My dream machine: Skoda Laura DSG, Ambiente .cArMaNiA Test-Drives & Initial Ownership Reports 108 19th November 2013 15:05
Skoda Laura Ambiente-cheaper Laura deuce-deuce The Indian Car Scene 94 11th July 2008 06:53
