Old 13th September 2012, 08:52   #1531
volkman10's Avatar
Thanked: 19,337 Times
Default re: Maruti Swift : Test Drive & Review
Originally Posted by iron.head View Post
I plan to get the under-body rust protection done from the ASC right after delivery. Do I really need to get it done? I am also thinking about getting some paint protection treatment? Any suggestions?
Congrtas on the owning car!
Underbody coating is not necessary to be done. Get the paint protection done by 3M and more professional and guaranteed to last.
Cheers!
volkman10 is offline   Reply With Quote
Old 13th September 2012, 08:56   #1532
arindambasu13's Avatar
Thanked: 166 Times
Originally Posted by el lobo 6061 View Post
Read this article on CarToq regarding Maruti fixes Swift braking problem! which coherently present in lower version of it. The fix is related to an ECU update.
The complaints about the Swift brakes that can be seen on this forum, including the official review of the Swift, is that the brakes themselves are weak, and have inadequate stopping power. The problem that is officially reported and being fixed by Maruti (as per this linked article) is quite different- i.e. low speed braking is inadequate, including braking while half clutching.
I have a VXI and have felt that the brakes could definitely be much better with stronger bite (though have not yet experienced the low speed braking problem).
arindambasu13 is offline   Reply With Quote
Old 13th September 2012, 11:36   #1533
itwasntme's Avatar
Thanked: 1,672 Times
Will this 'fix' benefit LDI/VDI owners as well? If I understand correctly, this idle RPM fix is only to compensate the less-than-ideal vacuum boost for the LXI and VXI. This has less to do with the braking system and more the inadequate 'brake assist' from the booster
However, will the LDI/VDI will continue to suffer from 'inadequate' braking? Don't think they suffered from inadequate vacuum strength.
Is my assumption correct?
itwasntme is online now   Reply With Quote
Old 13th September 2012, 13:38   #1534
CARDEEP's Avatar
Thanked: 1,542 Times
Infractions: 0/1 (5)
As far as I know (courtesy my friend who is facing the same life threatening problem in his new Dzire VXi) the issue is with the brake booster, which does not create the pressure enough at lower RPMs (in L & V variants) due to which the brakes do not get applied & the brake pedal becomes hard/ jammed for some moments. MS A.S.S. have recommended to maintain the car above certain RPM to make sure that the car brake booster works & car stops properly in any situation.
But, shouldn't MS recall the cars to replace the boosters which are faulty in this case.
CARDEEP is offline   Reply With Quote
Old 14th September 2012, 13:53   #1535
CARDEEP's Avatar
Seems that Maruti-Suzuki is discreetly attending the problem. Here is an article on what is being done:
http://www.cartoq.com/maruti-fixes-s...aking-problem/
For those on the forum, facing the issue, please get it rectified ASAP & update on the improved brakes for benefit of others.
CARDEEP is offline   (1) Thanks Reply With Quote
Old 14th September 2012, 15:59   #1536
fuel_addict's Avatar
Thanked: 114 Times
Good to see Maruti rectifying the brake issue at last. However, I do not support the idea of Maruti doing this discretely. There are several users who would be facing this issue but not knowing about the ECU update fix. Maruti as a responsible car manufacturer should recall all Swift owners and offer to fix this. Or atleast do this when the cars arrive for service. And not wait for customers to report the problem.
fuel_addict is offline   Reply With Quote
Old 14th September 2012, 16:17   #1537
beast_within's Avatar
Thanked: 32 Times
Originally Posted by GullwingGT View Post
I am getting a squeaky noise from the left side of my 6 months old swift zxi,it comes when we drive over rough patches and bad roads.It surfaced when the car was just 2 weeks old,when we asked the service guys to check unfortunately no noise at that time,even during my second service the same happened.
I have done 6376 km,this noise is so irritating in a new car,I feel as if its coming from left ORVM or may be from the plastic molding that covers the seat belt of the front passenger seat.Also one weird thing that I noticed is that during rain there is no noise even on the worst roads,experienced this in last two weeks.
Your inputs guys.
Originally Posted by iamahunter View Post
I have taken the delivery of my new Swift VDi in Oct' 2011. I am facing the same issue as GullwingGT, a squeaky noise from the left side of the car while going thru bad patches of the road. I feel that it is coming from somewhere near the glove-box.
The noise has just showed up for a past couple of months, after the car had completed around 14k kms. Will check with the SA in the next service interval.
Mine ZDI had developed very similar rattling noise within few weeks of ownership. Initially I thought it was due to some thing kept inside Glove Box or Left door. Actually the noise was coming from leftside of the black color plastic assembly ( where windshield washer nozzle is placed near left wiper arm). This was corrected by placing some hard sponge padding below that black cover. But lately the same noise has resurfaced.
beast_within is offline   (1) Thanks Reply With Quote
Old 14th September 2012, 16:25   #1538
GullwingGT's Avatar
Thanked: 19 Times
Last week had been to Service Centre,met the service GM and he sent a mechanic and he drove it on rough surfaces and after sometime the sound emerged,I was convinced that they will fix this time.However the GM quoted the same plastic issue and said it has been fixed,but next day itself the problem resurfaced.Have spoken to their GM and he has asked me to get the car to Service centre again,will let you guys know whether it gets solved or not.
GullwingGT is offline   Reply With Quote
Old 14th September 2012, 19:36   #1539
devil_klm's Avatar
Thanked: 190 Times
Same happened in my ZDI too. There were some rattling from front right side. SE told it was due to loose wiring from front tweeter(infarct i told him to check if that is the issue).
I took the car out two days after service and the same issue came back again. Even though it is a small noise it is irritating one for me. Some BHPians had faces rattling in steering assembly. I need to check if that is the problem. Taking the car tomorrow to service center.
devil_klm is offline   Reply With Quote
Old 19th September 2012, 10:58   #1540
KINI's Avatar
Thanked: 102 Times
Carblog India claims braking problems in Swift rectified by and ECU update
http://www.carblogindia.com/new-maru...roblem-solved/
KINI is offline   Reply With Quote
Old 19th September 2012, 21:53   #1541
Thanked: 57 Times
Need help:
Hit a pedestrian and lost the mirror on LHS RVM. Everything (electrical motor, indicator) is working fine. Just the mirror has fallen off and shattered.
Has anyone replaced this part or any idea if ONLY the mirror is available as a part or should I buy the whole assembly?
livyodream is offline   Reply With Quote
Old 19th September 2012, 22:27   #1542
swiftnfurious's Avatar
Thanked: 6,571 Times
Originally Posted by livyodream View Post
...Hit a pedestrian and lost the mirror on LHS RVM. Everything (electrical motor, indicator) is working fine. Just the mirror has fallen off and shattered.
I have the same problem. I have the prev gen Swift though. Guess the dealerships sell it as a pair. I checked with a Maruti genuine spares shop and they have the left piece alone for Rs. 1000/- [black]. I hope gen 2 also would be similarly priced. If you want to paint it, might have to shell out another 500-1000/- on it.
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 19th September 2012, 23:05   #1543
funkyp's Avatar
Thanked: 94 Times
How long is the puc valid for on the new swift? I have completed 6 months and wanted to know if I should get one or is that new cars need not have puc for one year.
funkyp is offline   Reply With Quote
Old 19th September 2012, 23:46   #1544
devil_klm's Avatar
Thanked: 190 Times
One year AFAIK.
Anyone got the ECU update to solve break issue. I checked with pratham motors last week and they were unaware of this.
Old 20th September 2012, 01:58   #1545
New cars have PUC valid for on year, from the company. After that you need to get the checking done every 6 months. I suggest you get the checks done on Jan 01 & July 01 every year. Helps you remember the schedule.
swiftnfurious is offline   Reply With Quote
Review: 2nd-gen Hyundai Verna (2011) Zappo Test-Drives & Initial Ownership Reports 2620 21st June 2018 19:39
Review: The 2nd-gen Maruti Dzire GTO Test-Drives & Initial Ownership Reports 577 6th April 2018 09:19
Rumour: Next-gen Maruti Ritz and Swift coming in 2015 and 2017 respectively JayPrashanth The Indian Car Scene 38 12th February 2016 21:26
Spy Pics: 2017 Audi Q5 (2nd Gen) karan561 The International Automotive Scene 3 23rd December 2015 08:40
2nd Bus & Special Vehicle Expo 2011: 9-12 March 2011: Hyderabad, Andhra Pradesh Safari_Beast Commercial Vehicles 38 27th March 2011 07:07
