Old 3rd January 2015, 18:06   #2461
im_srini's Avatar
Thanked: 394 Times
Question Re: Mathematical Comparison of Swift Petrol vs Diesel
Originally Posted by nukeblitz View Post
Results are a bit surprising but my math seems solid to me given the assumptions and the idealized nature of the numbers.
https://docs.google.com/spreadsheets...it?usp=sharing
- Air density is taken as 1.2kg/m^3.
- Drag coefficient of swift is taken as 0.32.
Congratulations on your new Swift
Just curious, how did you arrive at the frontal area for the Swift ?
Your post reminded me of a similar effort a long time ago, hence the query.
Full details here (How to deduce top speed of a car without breaking speed limit)...
im_srini is offline   Reply With Quote
Old 3rd January 2015, 19:27   #2462
Thanked: 2,374 Times
Infractions: 0/1 (4)
Default re: Review: 2nd-gen Maruti Swift (2011 - 2017)
For approximating retarding forces, measure your coastdown.
Transmissions are actually pretty efficient. Nowhere near the figures bandied about! Major loss is actually the tyres rolling resistance. Approx 1% of vehicle weight.
Wind resistance is not linear.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 3rd January 2015, 20:22   #2463
Thanked: 58 Times
Height multiplied by width. I didn't bother about ground clearance as I figured that would have been taken into account while measuring drag coefficient. I found the drag coefficient somewhere on the internet - not 100% of it's veracity. The schematic says that the ORVMs are not included in the width dimension but I figured that's negligible for the kind of accuracy I'm looking at.
Sutripta
Hmm, I suppose the only real way to measure power at wheel and transmission loss is to take it to a dyno - never done that myself. Besides the power and torque curves are crude approximations at best - especially the diesel. The low end torque is too high as I didn't account for turbo lag and there's no real way to guess it using the known points of max power and max torque, the mid range is probably a bit stronger as diesels tend to hold their peak torque for a bit, and I can't really properly plot out drop off past peak power point
Could you explain the wind resistance bit? I used this formula
Resistance = 0.5 * frontal area * drag coefficient * air density
I assumed that wind speed was 0.
What I found really interesting from my math is that the strong mid range found in the diesel swift can provide more torque to the wheels especially at low (<60 kph), when compared with the petrol even when the petrol's greater rev range, shorter gearing and more outright power are considered - enough so that it even negates the weight advantage the petrol has
PS. Fun fact, by my calculations, good shift points for the swift diesel are at 40, 70, 105 and 140 kph. Petrol? Redline it in every gear
PS2. Another Fun fact, a 75PS Multijet engine cannot have peak torque of 190Nm from 1750 to 3000 like that advertised by Tata on the Vista - 190Nm at 3000rpm is well above 75PS and, if that's true, the engine's power rating needs to be higher
Review: 2nd-gen Maruti Swift (2011 - 2017)-screenshot-20150103-202909.png
nukeblitz is offline   (1) Thanks Reply With Quote
Old 3rd January 2015, 21:31   #2464
im_srini's Avatar
Thanked: 394 Times
Question re: Review: 2nd-gen Maruti Swift (2011 - 2017)
Nowhere near the figures bandied about !
Hello Sutripta, glad you're joining the discussion.
I'm not sure where I found the following data, but 15% to 20% appear to be reasonable estimates, correct ?
Review: 2nd-gen Maruti Swift (2011 - 2017)-fiat_transloss.png
True, rolling resistance works out to ~1% of the vehicle's weight.
However it appears to be quite small compared to aero-drag, particularly as the speed increases :
The coefficient of drag is independent of frontal area.
Could you explain the wind resistance bit ?
I used this formula : Resistance = 0.5 * frontal area * drag coefficient * air density
Since drag is a function of speed squared (among other things), it's not linear with speed :
Review: 2nd-gen Maruti Swift (2011 - 2017)-alto_retardforces_graph.png
im_srini is offline   (1) Thanks Reply With Quote
Old 3rd January 2015, 23:50   #2465
Thanked: 58 Times
Hmm, that should have made more sense to me the first time around. Resistance is proportional to v^2. Thanks for clearing that up.
I'm not quite sure how to work with calculating drag. I've used the same formula in the spreadsheet and the drag coefficient is probably okay but what frontal area should I be using.
I'm getting interested in working on a better spreadsheet - but I need to know where my errors are and what and how to fix it... I already plan to add in rolling resistance.
nukeblitz is offline   Reply With Quote
Old 4th January 2015, 12:25   #2466
im_srini's Avatar
Thanked: 394 Times
Post re: Review: 2nd-gen Maruti Swift (2011 - 2017)
Frontal area is usually not mentioned in a vehicle's specifications, but this is what I did...
1) Took this image I'd gotten from somewhere :
2) Created this 'mask' so to speak :
3) Wrote a small program to count all the black pixels in the 'mask'
Using the count of pixels in the mask, the count of total pixels, & the real-world dimensions they correspond to, the frontal area was computed.
Old 4th January 2015, 20:53   #2467
You have way too much time on your hands! BTW, is that an Alto or a Swift?
My thoughts
http://www.team-bhp.com/forum/techni...ml#post2385389 (Energy loss in a vehicle)
and also elsewhere on the forum.
Gearboxes are very efficient. So much so that the amount of energy absorbed to that transmitted is so small it is difficult to measure reliably.
So that leaves the CV joints, and in case of a RWD, the hypoid.
True. Statement was made wrt tyre rolling resistance being the major component of 'Transmission Loss.'
The advertising copy normally reads something like
'between rpm1 and rpm2 xx% of peak torque (of nn Nm) is available.' Which is OK.
Easier if you first list out what your assumptions are. Clear thinking behind the assumptions is important.
Haven't gone through your spreadsheet formulas, but from the charts looks like you are doing a piecewise linear model, with two known data points, Max torque@rpm1 and Max power@rpm2. What is your assumed value for torque for the two extreme points.
Sutripta
Old 5th January 2015, 17:18   #2468
im_srini's Avatar
Thanked: 394 Times
You have way too much time on your hands !
Actually I already had code for dealing with images & masks as part of an image processing program - I just 're-purposed' it.
Is that an Alto or a Swift ?
It's an Alto.
Yay ! I found out where (All about Dynamometers + DYNO visit with GTO's Vtec!) I'd gotten the data, knew only CPH could've mentioned Seicento here
Oks, got it - so 'Rolling Resistance' should've been rolled into 'Transmission Loss' & not considered as outside of it - correct ?
Considering 0% 'Transmission Loss', there's a 7% discrepancy between the theoretical 'Maximum Speed' of the Alto (167 Kmph) & the empirical one (156 Kmph).
Review: 2nd-gen Maruti Swift (2011 - 2017)-alto_maxspeedgraph.png
Is this 7% an acceptable value for 'Transmission Loss', if yes, how does one reconcile the values mentioned by CPH ?
Old 5th January 2015, 21:32   #2469
Not to cast aspersions, but I think CPH is a tuner.
Some other people had also posted some information on transmission losses. Can't find it now. Maybe you can.
Other way round, but ignoring aero drag losses.
For these figures to have any meaning, one should have the coast down figures. And what are your views on manufacturers figures?
Sutripta
Old 7th January 2015, 13:16   #2470
Sankar's Avatar
Thanked: 4,562 Times
3rd Free Service done
Items replaced:
Oil filter - 340.61
Oil drain plug - 74.24
MGDO 5W40 Castrol - 1730.05
Screenwash - 4nos - 52.4
VAT 14.5%
Total - Rs2516/-
Old 13th January 2015, 13:12   #2471
Sridhar K's Avatar
Thanked: 192 Times
Originally Posted by Sridhar K View Post
I did my 40k service for my ZDI at Maruti service masters Chennai recently and here is the break up of the bill
10) Caliper assy grease: RS 55
I was getting the brake caliper noise (a tung tung noise when driving on broken roads, which vanishes if one press the brakes slightly) before the service and asked them to fix it. They had repacked the caliper assembly with grease but the problem did not go away after the service. I took the car back to them and they repacked the stuff again but advised me to change the caliper pin next time. However, the noise increased and it was really annoying. The mechanic also mentioned that it is a common issue in Swift/Dzire and they repack the disk at every service.
Finally got the issue fixed outside at a mytvs center whose owner suggested a solution that he used on his car i.e. they took the caliper and the pin to the lathe and added a sleeve to keep the pin from vibrating. The total cost was Rs 1.5K but he mentioned that I shouldn't worry for the next 50k kms at least.
MSM also failed to identify the link roads which were gone and I got them replaced for Rs 1.8 K (Rs. 680 X 2 rods + 400 odd labor). The vehicle was making not taking pot holes well even at low speeds and the replacement of the link rods fixed the issue.
Sridhar K is offline   Reply With Quote
Old 13th January 2015, 15:19   #2472
coolboy007's Avatar
Thanked: 1,440 Times
Did you not have extended warranty? From what i know, Maruti does cover suspension parts under warranty till 50k kms so the repair would have been covered under warranty.
What were the improvements post link ros change and call you tell the symptoms of a worn out link rod.
coolboy007 is offline   Reply With Quote
Old 17th January 2015, 21:32   #2473
Sridhar K's Avatar
Thanked: 192 Times
I initially thought (I have the extended warranty) so but was told that the link rod is not covered under warranty as it can get damaged due to hitting potholes at high speed. At least, that was told by the SA at MSM to my friend, who had come with me for 20k service of his dzire. He had recommended that the link rod in his vehicle was weak and should be changed at the next service and cost would be around 600 odd per rod.
Since I was not satisfied with MSM's work on the caliper pin and they will charge charge me for the break caliper clip, I thought I could change them at MyTVS near my home. That is when the owner suggested the sleeve option for the brake caliper pin. During the work, I asked them to check the link rods and we found that both the front rods were worn out on one side. Was wondering whether I should take it to MSM to see if they will replace them under warranty or alternatively pay 1600 odd to Mytvs and get it done there. Finally got it done at MyTVS to avoid the hassle of going to MSM the third time and I was not confident that they will agree for a warranty replacement.
As for the symptoms, the suspension was not smooth when going through pot holes or cuts in the road even at very slow speeds. The wheels would fall into the pot holes with a thud. However, they were pretty ok when going over speed humps or uneven roads. I had got used to this phenomenon and even did not realize the issue until I drove another Swift. After the link rod replacement, my vehicle just glides over potholes.
Sridhar K is offline   (1) Thanks Reply With Quote
Old 21st January 2015, 21:44   #2474
ghpk's Avatar
Thanked: 193 Times
Default How to remove the Meter Console of Maruti Swift Dzire ?
Need to take off the meter panel console of Maruti Swift Dzire (VDI)
tried finding its garage manual but unable to find it.
Need to do some custom DIY work behind the meter panel, the place I need to work on is hard to reach from foot pedal well, so best option would be to take out the speedometer console, I am assuming one can take out the meter panel itself without taking off the entire dashboard hope i am not wrong.
Please suggest.
Old 21st January 2015, 22:39   #2475
Thanked: 14,321 Times
Please suggest.
I am not sure but I guess the top panel needs to be removed but getting that out separately is doubtful. It may need a dashboard removal!
Any FNG can do it for you. Find a good quality FNG in your city (Look up the Directory on Team BHP).
a4anurag is online now   Reply With Quote
Review: 2nd-gen Hyundai Verna (2011) Zappo Test-Drives & Initial Ownership Reports 2620 21st June 2018 19:39
Review: The 2nd-gen Maruti Dzire GTO Test-Drives & Initial Ownership Reports 577 6th April 2018 09:19
Rumour: Next-gen Maruti Ritz and Swift coming in 2015 and 2017 respectively JayPrashanth The Indian Car Scene 38 12th February 2016 21:26
Spy Pics: 2017 Audi Q5 (2nd Gen) karan561 The International Automotive Scene 3 23rd December 2015 08:40
2nd Bus & Special Vehicle Expo 2011: 9-12 March 2011: Hyderabad, Andhra Pradesh Safari_Beast Commercial Vehicles 38 27th March 2011 07:07
