Old 20th March 2012, 13:42   #1081
one-77's Avatar
Thanked: 208 Times
Originally Posted by jingaboysr
Can someone confirm if there is an oil change as part of first service of 1000kms? My VIN is after the cut-off VIN in the maruti service circular posted before in this forum.
When I took the delivery, the guy who explained the car told that there is an oil change, but when I looked at the service booklet, there is nothing but some checkups during the first service. First oil change is at 10k. And the recommended oil as per the manual is 5W40, which is synthetic I wanted to go synthetic after a couple of oil changes at 1k and 10k.
My odo reads 520 now, and I am planning to a long drive of 1000 kms during the weekend. Really confused if I should drive it to touch 1000, service it and then go for the trip or come back and then give for service. If it's just some check-up that they do at first service, I don't see a point to get it done before the trip.
I hope I don't do bad to the engine by going a 1000km highway drive. I'm planning to try to vary the speed between 70-110 with numerous breaks.
The 1000km service is hardly a service. They'll only run a general checkup and clean the car.
I believe the 1000km highway drive will actually do good to the engine. You will feel it loosening up and coming to it's own by the end of your trip. Get it serviced afterwards.
(All these are just my opinions from my experience with the 1.3)
one-77 is offline   (1) Thanks Reply With Quote
Old 20th March 2012, 14:11   #1082
jingaboysr's Avatar
Thanked: 18 Times
Default re: Maruti Swift : Test Drive & Review
Thanks for the advice. Just talked to the SA at Maruthi service center. No oil change until 10000 kms. And every oil change, including oil filter will cost me Rs.3400, since the recommended oil is 5W40.
What is the average temperature that I am supposed to see in the gauge while driving? I always see that the needle reaches half way mark within 10-15 mins of starting and just stays there. Is it normal?
jingaboysr is offline   Reply With Quote
Old 20th March 2012, 14:14   #1083
fuel_addict's Avatar
Thanked: 115 Times
Originally Posted by hiren.mistry
Can anyone tell me whats the RPM at 100 kmph in 5th gear?
Approx 2300-2400 rpm.
fuel_addict is offline   (1) Thanks Reply With Quote
Old 20th March 2012, 14:39   #1084
jingaboysr's Avatar
Thanked: 18 Times
Originally Posted by fuel_addict View Post
That means atleast 2-3 years of wait for the OEM tyres to wear off. Michelin tyres are pricier. You can look at Yokos or Bridgestone. Buyback value would be around 9K for 5 tyres.
Does the paint sealant help against body scratches?
No, they don't claim any scratch resistance property for the paint sealant. It's just supposed to seal the shine.
Old 20th March 2012, 18:15   #1085
AvinashV's Avatar
Thanked: 33 Times
Just checked. It's somewhere right below 2500.
AvinashV is offline   (1) Thanks Reply With Quote
Old 20th March 2012, 20:10   #1086
Sridhar K's Avatar
Thanked: 192 Times
Just came back from Popular motors in Chennai. The official wait times for Swift and Dzires have come down drastically. It is 3 months for Swift ZDI and 2 months for Dzire ZDI. Last month, it was 6-8 months for ZDIs. Looks like Maruti was holding back the vehicle allocations for the budget announcements.
Sridhar K is offline   Reply With Quote
Old 20th March 2012, 20:16   #1087
pugram's Avatar
Thanked: 36 Times
Maybe there were holding back for the Volkswagen engine tie up. That fell apart and now its Fiat supplying the engines again .
@ jingaboysr :: Its absolutely normal for the Engine Temp needle to reach the half way mark. Its supposed to maintain that position no matter how little or how far you drive.
Last edited by pugram : 20th March 2012 at 20:18. Reason: Added reply to @jingaboysr
pugram is offline   Reply With Quote
Old 21st March 2012, 08:25   #1088
devil_klm's Avatar
Thanked: 190 Times
Jingaboysr, During your long trip, don't keep the engine RPM at a constant level. Try to travel at day time so that there will be enough traffic and you cant stick on to a constant speed/RPM.
devil_klm is offline   Reply With Quote
Old 21st March 2012, 12:47   #1089
jingaboysr's Avatar
Thanked: 18 Times
Exactly what I am planning. Planning to vary rpms betwen 1800 and 2200 while cruising for the onward journey. On the return journey, my car would have crossed 1000kms, so would give her a short introduction to higher rpms(until 2500) and speeds(until 120).
Yesterday while driving in the night, when I listened closely on a quiet road, I could hear a very faint whistling noise from the right side of the dashboard (somewhere near the fog lamp switch, I think). This comes on *only* when the ACC is switched on. Has anyone else noticed this?
Old 21st March 2012, 14:17   #1090
hiren.mistry's Avatar
Thanked: 261 Times
So its not much different to the Punto that does exact 100 kmph @ 2500 RPM.
hiren.mistry is offline   Reply With Quote
Old 21st March 2012, 14:29   #1091
AvinashV's Avatar
Thanked: 33 Times
Yeah guess in the Punto it will be slightly higher cause of the weight difference if my understanding is correct
AvinashV is offline   Reply With Quote
Old 22nd March 2012, 09:53   #1092
jingaboysr's Avatar
Thanked: 18 Times
Small correction, I noticed today that this sound is not related to ACC. It is a VERY faint sound, I need to listen carefully for it. It is not there when I start the car. Comes only after driving some time. I can hear it when the music is muted and I am waiting in a traffic signal. Something like a humming of some compressor. Is this normal?
Old 22nd March 2012, 21:17   #1093
swiftnfurious's Avatar
Thanked: 6,583 Times
Does it come when the A/C is completely switched off as well? Otherwise, when the A/C is running, usually there will be a humming noise. Also when your engine is HOT and when you idle, the fan starts working for 5-6 seconds giving that sound. You hear this sound with windows rolled up ?
swiftnfurious is offline   Reply With Quote
Old 24th March 2012, 14:10   #1094
devil_klm's Avatar
Thanked: 190 Times
Finally the wait is over.
Got our white swift delivered 2Hrs before.
Some snaps for now
Review: 2nd-gen Maruti Swift (2011 - 2017)-dsc_0854.jpg
Review: 2nd-gen Maruti Swift (2011 - 2017)-dsc_0878.jpg
devil_klm is offline   (2) Thanks Reply With Quote
Old 25th March 2012, 21:24   #1095
beast_within's Avatar
Thanked: 32 Times
Some snaps for now
Congrats for your new car. What was the OTR Price, please provide breakup of the cost. Also post ownership review and more pics, if you can spare some time off the steering wheel.
beast_within is offline   Reply With Quote
Review: 2nd-gen Hyundai Verna (2011) Zappo Test-Drives & Initial Ownership Reports 2625 11th July 2018 20:35
Review: The 2nd-gen Maruti Dzire GTO Test-Drives & Initial Ownership Reports 577 6th April 2018 09:19
Rumour: Next-gen Maruti Ritz and Swift coming in 2015 and 2017 respectively JayPrashanth The Indian Car Scene 38 12th February 2016 21:26
Spy Pics: 2017 Audi Q5 (2nd Gen) karan561 The International Automotive Scene 3 23rd December 2015 08:40
2nd Bus & Special Vehicle Expo 2011: 9-12 March 2011: Hyderabad, Andhra Pradesh Safari_Beast Commercial Vehicles 38 27th March 2011 07:07
