Old 24th January 2012, 16:50   #61
rajasitlhou's Avatar
Thanked: 16 Times
Default Re: Team-BHP's first Mahindra Scorpio LX 4WD
Congrats on your new ride! I was wondering if M&M dealers can install captain's seats and the 3rd row front facing seats at the rear from the VLX.
rajasitlhou is offline   (1) Thanks Reply With Quote
Old 20th February 2012, 15:57   #62
karizma9292's Avatar
Thanked: 210 Times
hey guys , need help . What is the grade of the coolant used in the m-hawk scopio ? Its red in colour , can i use the regular red coolant availble in shops.
karizma9292 is offline   Reply With Quote
Old 20th February 2012, 19:11   #63
cool_dube's Avatar
Thanked: 402 Times
Always go by the grades/brands mentioned in the user manual.
cool_dube is offline   (1) Thanks Reply With Quote
Old 20th February 2012, 19:21   #64
rjstyles69's Avatar
Thanked: 795 Times
sugan it's in manual with the grade. Check and use the same grade.
Old 1st March 2012, 10:32   #65
Thanked: 210 Times
Did a small mod which i guess is an important mod for a 4WD vehicle , added a pair of lambda free wheeling hubs
karizma9292 is offline   (3) Thanks Reply With Quote
Old 1st March 2012, 13:24   #66
AVR
AVR's Avatar
Thanked: 531 Times
Electronic-shift 4wd comes with auto-locking hubs? Why would you replace them so early?
AVR is offline   Reply With Quote
Old 1st March 2012, 13:49   #67
tsk1979's Avatar
Thanked: 16,420 Times
Attachment 895405
Attachment 895406
This is something even I am interested in!
I think Safari and Scorpio come with same auto locking hubs. I was looking for manual lock hubs too as these auto ones are not very durable.
Where did you get them? Whats the price.
Can you share the part number?
Old 1st March 2012, 23:05   #68
Thanked: 210 Times
i have heard auto locking hubs tend to fail , especially in water . Im not taking any chances .
Lambda makes them , if you are keen i can find out if they make for safari also . Costed me Rs.3600/-. Dont have the part number buddy.
Old 1st March 2012, 23:47   #69
tsk1979's Avatar
3600 for the pair? Thats good and cheap!
BTW auto locking hubs do not fail in water. Your transfer case will not shift to 4wd. Raise the scorpio on a lift, and cover the electronic bits with silicon gel. SS-Traveller knows what to do, drop him a PM
tsk1979 is offline   (1) Thanks Reply With Quote
Old 2nd March 2012, 09:49   #70
4x4addict's Avatar
Thanked: 2,668 Times
@Karisma: There have been extremely few complaints about the auto locking hubs from any Safari/Scorpio 4WD users that use the same hub. As tsk pointed out, it is the silly electronic transfer case that is more likely to be an issue under water. Please waterproof the connectors.
4x4addict is offline   (1) Thanks Reply With Quote
Old 2nd March 2012, 10:26   #71
Thanked: 210 Times
A friend of mine tells his thar also failed to engage to 4wd in water numerous times though it has lever type 4wd , what may be the reason ?
so he also opted for manual hubs .
As i said im not taking any chances as i would be travelling to remote areas with real bad pathways , next work as you all said is to water proof the electronic bits beneath.
Old 2nd March 2012, 10:32   #72
tsk1979's Avatar
At many Mahindra Great escapes, and OTRs, scorpios 4wds turned into 2wds of there was water.
It is because of the low sitting components in the electronic transfer case.
The auto hubs are mechanical. Water or no water does not matter. However, after deep water crossing, hub greasing must be done.
I have been using them, and they failed in totally dry terrain(some internal pin got bent). Even now, they are not working properly. Mechanical failure. Need to get them changed.
So its good you got them changed, but waterproofing the components is a must.
that said, is it 3600 a pair? Can you give me contact details of dealers in India?
Old 2nd March 2012, 10:54   #73
Thanked: 210 Times
So you mean to say it fails not because of water but due to mechanical failure , so the choice i have taken is good or not? Water proofing will be done as you advised .
Just type lambda components , bangalore in justdial you will get the contact . Yes 3600/- for pair.
Old 3rd March 2012, 16:08   #74
Thanked: 210 Times
Update : got the tail light extensions painted black , now the vehicle looks a lot better
karizma9292 is offline   (2) Thanks Reply With Quote
Old 3rd March 2012, 16:24   #75
raj_5004's Avatar
Thanked: 2,064 Times
Agreed. You have a mean looking Scorpio. Black Scorpio + black tints + chrome alloys + 4wd = killer!
raj_5004 is offline   (1) Thanks Reply With Quote
Mahindra 4WD vs Modern 4WD Samurai 4x4 Technical 137 19th February 2012 19:46
Mahindra Scorpio VLX A/T 4WD - anyone got it? SS-Traveller SUVs, MUVs & 4x4s 341 20th November 2011 23:32
Mahindra Scorpio CRDe - 2WD to 4WD conversion suhasd75 Modifications & Accessories 8 3rd November 2009 18:02
