Old 22nd October 2014, 08:50   #121
n.devdath's Avatar
Thanked: 1,219 Times
Default Re: BlackPearl goes white - Bolero LX 4x4
Originally Posted by BlackPearl View Post
Yes, that exhaust is looking ugly IMO as well. After market black side step should resolve that.
I would recommend aftermarket rock sliders fabricated by a good workshop. This will not only enhance the looks but also protect the bodywork.
n.devdath is offline   (1) Thanks Reply With Quote
Old 10th November 2014, 20:46   #122
Altocumulus's Avatar
Thanked: 340 Times
Its looking taller without the side steps and looks better in my opinion. Get the exhaust painted black, won't be so obvious then.
How about modify the exhaust and taking it out through the side
Altocumulus is offline   (2) Thanks Reply With Quote
Old 20th December 2014, 20:42   #123
ringoism's Avatar
Thanked: 1,014 Times
Looks good apart from the pipe.
You all are young enough to jump in/ out of the vehicle! If you are thinking of sidesteps, you are too old. Sedans for you then.
Now THAT's the spirit... I hope I'll still have it when (/if) I finally one day arrive at official senior-citizen status.
Good idea. All of the (albeit light) body damage incurred on the Marshal these past couple years of ownership was in the rocker panels - rest of the bodywork is normally too high to hit much of anything. Once it was a drunk driver that sideswiped us, and once my very sober and beloved - but not excessively coordinated in that case - wife who took a turn too tight and hit a high concrete curb, but anyway both damages would've been prevented by some kind of decent side rails (I do not say side"steps", because light-duty stock types always get banged up and nasty before anything else).
In my laptop back in H.P.(sorry) I've got a photo of a U.S.-based CJ with nice, clean, no-frills 2" diameter round-tube rocker panel guards, that turn in nicely at each end. Look really good and very functional, and won't mess with ground clearance much if mounted fairly high. I'd already bought the material to make them for the Marshal but ran out of time before leaving. Some guys up in H.P. mount these directly to the chassis with a u-type bolt-on bracket, and that's the way to go if you want body protection. Floor-pan mounts are comparatively weak and mess up your floor pan if they get hit.
With the Marshal's exhaust system reduced to a pathetically patched-up, convoluted, carbon-fouled mess, I actually cut out the whole front/center section and replaced it with an absolutely straight piece that runs completely inboard, directly through (above) the transmission crossmember. Tight fit with our 2" pipe (even had to trim a superficial tab off the transfer case), so guessing it'd be even tighter with your larger dia (Turbo-spec) pipe. Then again, maybe not, since I was also dealing with a mechanical clutch linkage and yours is cable-op. So might be possible with a dimple or two). Sorry no photos here, we're a couple thousand km's away from our car at the moment (can you wait till March? :-) ).
Benefits are less backpressure (IP properly re-tuned, adds power/mileage), a much neater / lighter weight setup (less broken hangers/brackets on rough tracks), and more outboard ground clearance. Ditched the resonator (that ugly outboard thing on your car) entirely. From the crossmember back, utilized an HMT-tractor-spec (3522) silencer, which is a lot less heavily baffled than the stock unit, with a much bigger ID also, but longer in length, so not as loud as I'd worried it would be. Genuine one can be bought (even in H.P.) for Rs1000 or less, which I'd call dirt cheap. Turbos run quieter at the pipe anyway, the gases having gone through a turbine already. On the MDI, it's a little raspy at just one particular higher rpm, kind of like old 60's-style glasspacks on an American V8... (the bark obviously worse than the bite in this case!) but not hard to avoid that rpm; and I kind of like the raspy note on occasion (turns a few heads ). Not recommending it in the event your RTO is an anal-retentive type and they bother about this sort of harmless (even beneficial) mod.
Anyway, the straight pipe idea might be worth a look, if the ugly resonator still offends, post addition of custom side-rails.
-Eric
P.S. re: your leaf-spring work, it looks to have raised it some vs. stock 4x4 Boleros. Friend just got a brand-new LX (MDI-TC, 4x4), and I was surprised to find it riding so hard - and yet still hitting the front stops, repeatedly bottoming out on our road in places the Marshal has NEVER bottomed even when driven at higher speed. Then I looked under the Bolero and saw the front axle was sitting only about an inch below the stops - and that the stops themselves were only about an inch thick, vs. our Marshal's roughly 2" ones. Not sure what you got done to your springs, but if my friend's car was "normal", I'm thinking such mods have got to be a top-priority upgrade to stock Bolero 4x4's.
ringoism is offline   (1) Thanks Reply With Quote
Old 22nd February 2015, 21:38   #124
BlackPearl's Avatar
Thanked: 2,700 Times
Today is the 3rd birthday of The White Tusker and celebrated with a soft roading meet with fellow tbhpians!! The current odo stands at 56971 Kms. Thanks to bhpians Himadri, Avrendu, Amin, Partha and Debjit for taking out time for the meet at a very short notice. Uploading a few pics of the meet, pictures courtesy Amin, Debjit and Partha.
BlackPearl is offline   (3) Thanks Reply With Quote
Old 25th May 2015, 19:12   #125
ringoism's Avatar
A late congratulations, Sumitro. Car's looking well-cared-for and just as appealing aesthetically (or more so) than the Thars alongside. There are times I wish I'd bought a Bolero like yours vs. messing around with the more "classic" Marshal (in terms of styling but unfortunately also maintenance demands). Basic character is similar, though: rugged, no-frills simplicity - you've got a great vehicle there.
Can see you've got new wheels (/tyres?) since your previous photos; can't recall whether they were already there when I was in Kolkata. What are they (size/brand)?
-Eric
Old 26th May 2015, 11:49   #126
BlackPearl's Avatar
-Eric
Thank you Eric for the nice words about the Bolero. Personally I like the looks of the Marshal more. Even the previous gen Bolero with those square headlights looked better. I feel Mahindra is messing up the looks with each update.
The tyres are Michelin LTX AT (235/75/R15) that I got last year before the Ladakh trip. The alloys are recent additions. These are pre-owned HRS alloys that I got from a friend at a decent price. At first I had put these on the Thar but then shifted them back to the Bolero.
BlackPearl is offline   Reply With Quote
Old 21st July 2015, 16:49   #127
AJ-got-BHP's Avatar
Thanked: 1,827 Times
Hey BlackPearl !!
Anybody not wanting to buy a Bolero shall definitely buy one after reading through this thread of your's. A live example being our very dear BHPian JKDS !! Actually, there is no reason not to as Mahindra Bolero still is India's Highest Selling SUV and you have the 4x4 Avatar of it. Cannot get better.
I personally loved the looks of the previous Bolero with the rectangular lights. Used to look fabulous !!
Some very tastefully done up Mods definitely make The White Tusker a distinguished ride amongst the others in the crowd.
Taking the opportunity to share a few Pics of your Bolero which was recently clicked by me (hope you would not mind) :
@ the TEAM BHP Monsoon Meet :
@ Sukhnopukur - The Bolero's Very Own Playground :
Keep on taking anything that comes your way with the White Tusker !! Wishing you countless miles on this one
AJ-got-BHP is offline   (3) Thanks Reply With Quote
Old 21st July 2015, 22:49   #128
4x4addict's Avatar
Thanked: 2,111 Times
Hi Blackperl, did you increase the ride height or is it just the bigger tyres that give a higher stance?
4x4addict is offline   Reply With Quote
Old 23rd July 2015, 14:23   #129
BlackPearl's Avatar
Originally Posted by AJ-got-BHP View Post
Hey BlackPearl !!
Attachment 1394067
Attachment 1394068
Thanks a lot Arav for the nice words and the pictures
It is just the bigger tyres @4x4addict
Old 22nd February 2016, 21:59   #130
BlackPearl's Avatar
Another year passed by, today was the 4th birthday of the Bolero. The current Odo stands at 68K kilometers. Nothing to report as such except posting a few pictures taken during last weeks off-roading. Pics are taken from the Kolkata off-roader thread and photo credits to Samba and AJ-Got-BHP.
Guided by the legendary UBS Sir..
BlackPearl is offline   (2) Thanks Reply With Quote
Old 14th March 2016, 14:55   #131
BlackPearl's Avatar
A pic of the Bolero from yesterdays offroading, picture credit to our very own Samba..
Old 1st May 2016, 01:19   #132
BlackPearl's Avatar
The front propeller shaft in my Bolero has got some play and making quite a bit of noise on sudden deceleration from 90 plus speed. Thanks to SS-Traveller for pointing out the issue during his recent Kolkata visit. I need to get it fixed. A free-wheeling hub would have increased the longevity of the part.
Old 20th June 2016, 15:06   #133
BlackPearl's Avatar
Default 70 Thousand kilometers update - Lamda FWH fitted
The White Tusker completed 70K kilometers a few days back. Got the Lamda Free Wheeling Hubs fitted. A big thanks to swastikviji for promptly shipping them. It reached me in less than 3 days after ordering and he had sent me the AWB number even before the money got transferred to his account. Maybe this level of trust is only for team-bhp members
Originally Posted by swastikviji View Post
Dear Offroaders Good News From Lamda components, Now They are offering Two Years warranty on all their Range of free wheel Hubs, Any issues about warranty please let me know i will solve it
It was quite easy to install the hubs. Found a person in the FNG who had previously worked on Aisin FWHs on the first generation gypsy.
Though it is too early to say anything about benefits of this install, the steering has become a lot lighter. Will keep on updating this thread. Need to meticulously remember to engage the hubs once in a while.
A few pics -
BlackPearl is offline   (1) Thanks Reply With Quote
Old 20th June 2016, 18:48   #134
ringoism's Avatar
Hey buddy, good to see you still enjoying your car. The hubs are a good addition IMO without any serious downsides. Mine are old and battered, having scraped a lot of rocks (before my time), but they still work fine.
Was wondering, if you're ever at your local M&M showroom there, if you could inquire as to whether the LX 4x4 is still available. I know these were always special order (a friend here bought one a year and a half ago), but am now told by the local showroom here that production has permanently ceased as of 3-4 months ago. Website still shows both it and the Plus 4x4 as available, so I don't know. I was looking into it on behalf of a local NGO who really needs something simple/rugged to replace an old Commander. Looks like options are steadily disappearing.
Not much going on with our Marshal. It seems to have settled out mostly and is not requiring much attention, at least for low-key local plying. Wife still wants the interior work completed of course (one of these days...).
Many Thanks,
Eric
Old 29th June 2016, 13:33   #135
Thanked: 105 Times
Default Mahindra Bolero - Wish List
This is not exactly a long term ownership review. My Bolero is 9 Years and 100000Km old and there are certain things which I wished the "more knowledgeable" Mahindra would think about and do something about. But the mighty Mahindra were busy with redesigning grills, logo projection from side mirrors, adding "Welcome to Mahindra Bolero" voice and such important stuff. Can't blame them.
So here are some things I wished they thought of in a Bolero in no particular order. No, i'm not asking for Twin Turbos or 150bhp.
1. Split / Collapsible Middle Row Seats. Rocket science?
2. Relocating the rear number plate from that MOST STUPID place to below the Rear Door handle. Rocket science?
3. Better Windshield Wiper angle / mechanism so that it doesn't leave an uncleaned "pizza slice" section on the driver's side which creates sort of a "blind spot".
4. Taller gear lever with a shorter throw.....which means "bring the fulcrum up".
5. Front wheels splash water onto the windscreen blinding the driver. Mahindra, still clueless after so many years?
6. Matching the front and rear track widths.
Just the simple and obvious stuff. I'm leaving the engine / transmission / suspension untouched. Anybody wish to add more? No twin turbos and such stuff please.
Thanks,
-- Torqy
Torqy is offline   (5) Thanks Reply With Quote
Bolero XDP Engine Vs Bolero DI Turbo Red Liner What Car? 34 30th September 2015 21:37
Blackpearl goes green - the Green Goblin (2009 Kawasaki Ninja 650R EX ) BlackPearl Superbikes & Imports 99 31st October 2011 22:56
Bolero Invader 4X2 to 4X4 Conversion inder_s1 4x4 Technical 19 29th November 2009 16:38
Mahindra Bolero Invader 4x4 - To buy or not to buy ?? Sabareesh SUVs, MUVs & 4x4s 11 3rd October 2008 11:29
