Old 31st July 2013, 12:18   #526
Thanked: 648 Times
Default re: 1st-gen Hyundai i20 (2008 - 2014) : Review
Originally Posted by prithviq8 View Post
Picked up this beauty today. It's an i20 Asta Crdi (Maharaja Red). Bought the car after much confusion on taking a new car or a used one. The features of this model just made me go for it. On road price was 8.68L. Got a 10k cash discount with the basic accessories (mud flaps, door mats and a body cover). Main reason for taking the car was for school runs (Civic demanded too much petrol). Drove it for about 10kms today so wont be able to comment too much on the car. Attaching a few pictures.
So in chennai, the OTR price for Top end ASTA Diesel costs only 8.68L? Surprised to know because, when i checked the bangalore price when igen i20 was launched, it was close to 9.5L !!! Close to a lac less now between two cities. Did Hyundai reduce Diesel Asta prices, because of Amaze effect? Any idea?
-Ravi
ravib is online now   Reply With Quote
Old 3rd August 2013, 12:05   #527
prithviq8's Avatar
Thanked: 50 Times
Originally Posted by h@r$h@l View Post
Discovered a new feature in my i20 ASTA Crdi 2012. While the car is in motion and if u unlock from driver door, only driver door gets unlocked & all doors get unlocked only when car is stationery. Last night we were just nearing a friends place and i unlocked the doors only to realise that only driver door got unlocked and rest of the 3 doors were in locked position only.
Well noticed! Checked it on my car as well. Until 15kmph all the doors are unlocked but after 15kmph only the driver door is unlocked (all checked from driver side controls).
-Ravi
I'm not sure if it's because of the Honda Amaze, but the dealer did tell me their i20 sales had dropped not only in their showroom but across Chennai. This was the reason for their discounts.
prithviq8 is offline   (1) Thanks Reply With Quote
Old 8th August 2013, 16:47   #528
Ok,faced first major problem with my Nov 2009 i20 petrol Magna,milage 15000KM
While returning back from dinner yesterday night,the clutch became stiff,I pumped it a couple of times since the car is not used very frequenltly.
For time being it became normal but taking a substantial time to return to original position,kind of getting 'sticky'.
Finally at a traffic signal it got completely stuck and refused to move.With the help of few guys I managed to pull it along the side of the road.Called the SA and they told it could be clutch failure which I refused to believe but since no other choice and wife with me, dint took any risk and got it towed to the SA.Sanjay Hyundai charged me 2100 for towing the car 35 Kms
The mechanic called me today to confirm the clutch is ok but the slave/master cylinder has gone kaput.They will replace the slave cylinder & see if it works else replace master cylinder as well, cost ~3K
I told them to put it on hold till I visit SA tomorrow.Searching on the forum led me to believe its a manufacturing defect in the earlier i20's (2009 & 2010) Sadly car is out of warranty so everything would be from my pocket.
Will update once I visit SA tomorrow.
kratos11 is offline   Reply With Quote
Old 10th August 2013, 12:31   #529
skanchan95's Avatar
Thanked: 746 Times
Do ask them to do clutch bleeding as well. Even after replacing the muster cylinder in my 2009 i20 Asta(1.2), I faced the hard clutch issue.
skanchan95 is offline   Reply With Quote
Old 10th August 2013, 20:42   #530
vidyanand's Avatar
Thanked: 43 Times
Originally Posted by arvind71181 View Post
My Ipod classic works fine when I connect it to the USB port but my itouch does not. I guess certain generations do not work with the HU and I have resigned to not be able to use my itouch with the HU. Let me know if the SA has anything positive to say when you talk to him
I finally got it checked. The SA said the iTouch can be connected and music can be controlled only if we use the ipod usb-aux composite cable. This has the ipod connector at one end and an USB as well as 3.5 mm aux on the other end. This is supplied with Elantra but not with other models. He got one and showed it working when both USB and Aux were connected.
It also works with iPhone.
vidyanand is offline   Reply With Quote
Old 17th August 2013, 15:43   #531
So the master & the slave cylinders have been replaced.It is due to normal wear & tear and also due to driving in bumper to bumper traffic.
I had extended warranty for only 3rd year hence paid 7K including labour for this work.
I would suggest everyone to buy 4th year extended warranty as well since these types of problems occur mostly after 3 years of usage.
Old 17th August 2013, 15:50   #532
DRIV3R's Avatar
Thanked: 1,078 Times
Master and slave cylinder change due to wear and tear? That's not true.
Clutch plates can wear due to b2b traffic. Not the master or slave cylinders that too at 15k kms.
DRIV3R is offline   Reply With Quote
Old 30th August 2013, 11:14   #533
9thsphinx's Avatar
Thanked: 438 Times
Can anyone confirm if installing spacers help lower the boat-like feeling at the rear? The i20 wallows a lot - the suspension being on the softer side, but if someone has successfully managed to install spacers (I've done this on our Civic), apart from increasing ground clearance a bit, does it help the i20 be more stable on potholed roads?
Has anyone done this on their i20's yet? BTW, does installing spacers affect the warranty?
9thsphinx is offline   Reply With Quote
Old 30th August 2013, 11:53   #534
CARDEEP's Avatar
Thanked: 1,483 Times
I do not have a i20, but, a Santro Xing, with rubber spacers at the rear. IMO the suspension is harder from what it was earlier & thus helps me take corners faster. However, I am not sure how would it affect your warranty ('cause I remember your car as being new & still under warranty), & if its got ABS, do check with experts if the spacers affect ABS working (I have already read that you have got spacers on Civic as well, & so has GTO on his, but still want to be sure since this concerns electronics & rubber in shocker springs may interfere with the signals).
CARDEEP is offline   (1) Thanks Reply With Quote
Old 13th September 2013, 22:53   #535
RavenAvi's Avatar
Thanked: 26,144 Times
My good friend and fellow Team-BHPian libranof1987's parents took delivery of their new i20 Sportz earlier today. (He's in the US right now)
Maharajah Red color, 1.2 petrol. Just mud flaps and floor mats as freebies.
Final OTR was 5.01 L, including total discounts of 1.2L. They exchanged their 2005 Zen LXi at the dealership.
1st-gen Hyundai i20 (2008 - 2014) : Review-1232800_10153235951925137_2036794305_n.jpg
RavenAvi is offline   (3) Thanks Reply With Quote
Old 15th September 2013, 14:54   #536
Thanked: 74 Times
How much was given for the Zen in exchange ?. I checked out with V3 Hyundai for the i20 Sports/Asta and they offered 10K cash discount and free covers & mats. I'm not eligible for their corporate discounts. Their quoted On-road price was 686,992 without extended warranty, under chassis painting.
vivriti is offline   Reply With Quote
Old 15th September 2013, 15:19   #537
RavenAvi's Avatar
90K for the Zen, 20K Exchange Bonus and 10K Cash Discount.
The Zen could have fetched a bit more in the open market but too much hassle and haggle involved, plus the paperwork. This way the dealer takes care of all that. Goodwill and relationship takes priority here, and it's worth that 10-15K difference.
Still, we thought the dealer got the Zen for a steal.
RavenAvi is offline   (1) Thanks Reply With Quote
Old 15th September 2013, 17:12   #538
Thanked: 74 Times
Adding the discounts of 1.2 lakhs brings the on road price to 6.3. The dealer is quoting 6.86. Looks like I am missing something. Which dealer was it ?.
Old 15th September 2013, 19:11   #539
RavenAvi's Avatar
Gurgaon dealership. I am guessing you quoted Chennai prices?
Maybe libran himself can clarify better here.
RavenAvi is offline   Reply With Quote
Old 16th September 2013, 09:00   #540
libranof1987's Avatar
Thanked: 2,589 Times
Thanks for posting this, Avi!
The Zen was evaluated at 90k and a further 20k as exchange bonus.
Oh btw, the 5.01 includes extended warranty.
+1
Add to it, the hassle of out-of-state registration (the Zen is MH-reg.). Working with individual buyers can be a very time-consuming and frustrating process.
The car has been bought in Gurgaon.. low ex-showroom price and lower taxes.
libranof1987 is offline   (2) Thanks Reply With Quote
Review: 1st-gen Ford Figo (2010) GTO Test-Drives & Initial Ownership Reports 10636 25th September 2017 12:43
i20 Asta 1.2L Petrol : 1st i20 2011 model on Team-BHP Forum Suess Test-Drives & Initial Ownership Reports 30 29th May 2013 12:15
Ford Figo TDCi v/s Hyundai i20 CRDi v/s Hyundai i20 1.2 v/s Honda Jazz lamborghini Hatchbacks 24 18th December 2010 15:54
Hyundai Verna (1st gen.) : Tyre & wheel upgrade thread praveencr85 Tyre & Alloy wheel Section 17 13th November 2007 13:59
