Old 1st August 2012, 23:06   #46
infotech58's Avatar
Thanked: 217 Times
Default re: My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun
Originally Posted by JayD View Post
All i wanted to do is to literally 'Ignite" it and the garage. Together.
very sad to hear the incident. what is the plan now? are you taking it back to the same person for fixing it or have found a trusted and knowledgable place?
i never ever leave my Vtec with a mechanic and i make sure all the work is done while i am watching it.
infotech58 is offline   Reply With Quote
Old 7th August 2012, 14:54   #47
JayD's Avatar
Thanked: 2,008 Times
With the help of some autowallahs, i push sharted the car somehow, and started moving. Itwas raining badly, and had got dark. I had no headlights or wipers. No idle, and no real clutch to speak of. And i had to drive 35kms, in peak traffic. I somehow managed it. I must say, my worst drive ever.
The next day, i went to ignite again and gave Raghav a piece if my mind.
1)He opened the bonnet, and started the car, again, it was very jerky and stalled after sometime. I told him its the timing, but he said, its 'automatically set'. Again!!!
2)Regarding the dead battery, i asked him why it died inspite of the recharge, he replied, "you asked to charge it only. The battery is leaking, it needs to be changed".
Why was it not informed? Well, you asked for a charge only, not to check the condition!!
3)I was charged an insane amount for ' Brake checking'. Despite that, i noticed that one wheel was very hot while running, and i suspected a jammed wheel cylinder. He said, he has to open it and check. When questioned about the 'Brake Checking', he replied, "i checked the condition of the pads only"
He wanted to change the plugs, and i asked for NGK. He told he has the one for the palio is stock(Shocking!!!) and removed the old plugs. They were not in the best of shape, so i thought the jerkiness must be due to them. New plugs were put in, but no use. the car still was undrivable.
He then commented, Sir, the car is a bad one. Common complaint with MH Reg cars, especially palios, most cars are abused. This one's engine is gone. We will have to open the head, overhaul, grind the valves........ and the list went on, but i stopped listening a long while back. And he gave me an estimate of 50k!!
I was heartbroken to say the least, did not say much, closed the bonnet and started to drive away. I did not want my car in that place any more. He told me , that the engine was gonna blow, and that i should not drive it. I didnt bother.
I drove the limping car back home. It was horrible. The engine was still making wailing noises, was jerking, no idle, no proper clutch, nothing. I somehow drove home, and parked the car.
The next day, i got a new battery for it. Amaron. Cost some 5500/- or so. The starting issue was solved. But the car still wouldn't run.
To be honest, i had enough. Here I was, after blowing over 25k in repairs, to Chennai's TOP Garage, left with an undrivable car. And nobody to fix it.
JayD is offline   (7) Thanks Reply With Quote
Old 7th August 2012, 14:59   #48
JayD's Avatar
Very sorry to hear about ordeal. Its very frustrating indeed. Its not just raghav, most of the mechanics are like that. They want money but won't solve the problems you tell them . And most of the time if they screw up something they don't bother to set it right and argue on their stand . I just feel like thrashing those fellows when they do such things. Get the car back to them and make them set it right! And don't visit them ever again.
Once popularity gets into their heads the mechanics as well as the owners become very sobbish. This is not the first bad experience I have heard about that raghav and his garage. There are many more bad experiences about him on this very forum!
Unfortunately, yeah, thats the state with most mechs these days. But Raghav was recommended by everyone on most forums. Also, some of my friends cars were also maintained by him. So i thought i would get good service. Later we found that those cars were also screwed up!
Originally Posted by rock18 View Post
After reading a lot of good things about ignite and raghav,I also decided to visit him for the timing belt change.I asked him to drive my car and tell me what all i can do to make the car drive better.
He said everything including suspension is good and regarding the timing belt change.
He asked me why on earth would you want to change timing belt at 20k? i said its a 9yr old car.He said that does not matter.
that is the end of Raghav and ignite for me. When i went there i thought he should be the ultimate solution for all my problems.
Thank your lucky stars that you ran away. I would make me cry to see a 14k done car getting 'Ignited'
I think after my episode, he has become careful in dealing with fiats!
The rest of the story is unfolding, and some very interesting changes too!
Old 7th August 2012, 16:40   #49
planet_rocker's Avatar
Thanked: 368 Times
a bit off-topic: All Hyundai DOHC engines are 'Interference type', same as in Palio DOHC. They have cam'-locking tools.
JayD - need bigger updates and make them come faster
This car had battery draining issues. Rain water drain holes in the rear doors were blocked , which were later cleared. Fuel Pump Relay had oxidization problem which was changed to a new relay / cleaned. apart from this - the car was running fine when it was with Varun. So whatever Ignite mentioned about a bad engine was totally their way of cleaning their hands of the mess they made. take care.
Cam Locking Tool for Fiat 1.6 16V: Cam Locking KIT.pdf
planet_rocker is offline   (1) Thanks Reply With Quote
Old 7th August 2012, 17:19   #50
JayD's Avatar
Cam Locking Tool for Fiat 1.6 16V: Attachment 966642
Yes, i know about the issues, and they were all taken care of before i got the car. I was driving it around too. The bad engine as you rightly told was just Ignites way of washing their hands off, as they knew for sure that they had messed it up.
The best tools are rendered useless in the hands of a fool! What else to say! Hehe!
And the updates wil be faster now, was traveling. The interesting part is coming up!
JayD is offline   (1) Thanks Reply With Quote
Old 7th August 2012, 21:02   #51
Thanked: 175 Times
Extremely sad to see what these useless mechanics so to vehicles we cherish and love so much! The exact same thing happened to my RE Thunderbird. Bought it in good condition, and ruthlessly spoiled and abused by an idiot of a mechanic recommended by lots of friends and BHPians! Guy called Pawar here in Pune. I hate these fiends!!
Hope your amazing S10 comes back to pristine health asap and you get to enjoy her for long time to come! Keep us posted man! Cheers
thumpingheart is offline   Reply With Quote
Old 7th August 2012, 22:07   #52
Thanked: 157 Times
Hey, hope you find someone more reliable than that Guy and hope your steed is back on its feet soon. I hope your posts enlighten those who have been extolling that gent's virtues
fiestarry is offline   Reply With Quote
Old 8th August 2012, 11:39   #53
JayD's Avatar
To be honest, i was fed up. I had spent all my time, money and effort on this car, but it still wouldn't run, and there was nobody to fix it.
In the meantime, i got very busy with work, and had no time to run after garages. I parked the s10 in one corner of the parking and left it there for sometime.
This looked like the end of my S10 adventures for a while. But then again, this turned out to be only the beginning!!
4460, during happier times
My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun-20111105-13.20.33003.jpg
JayD is offline   (5) Thanks Reply With Quote
Old 8th August 2012, 13:23   #54
rjstyles69's Avatar
Thanked: 795 Times
jay congrats first, I can understand your predicament at this hour man.I wonder how you managed to stay composed all thru the fiasco with this so called Ignite Garage and its owner ?
Finding a pristine car is a herculean task these days and then having found one, some moron deciding to screw it up takes it to a whole new level of frustration.what next did you open up the head as said by that incompetent mech ?
Old 8th August 2012, 13:57   #55
JayD's Avatar
Thanks guys. All i can say is wait for the happy ending!
Old 8th August 2012, 14:34   #56
esteem_lover's Avatar
Thanked: 451 Times
I don't understand something here. You were charged 17k and you paid up and took delivery of the car even though the car did not feel good ? Why would anyone do that ? Before you pay anything, shouldn't we be satisfied that the job is done to your satisfaction ? And 17k is not small change.
I would suggest you back to him and give him another opportunity to sort it out.
I don't see anything wrong in that statement unless you own an Indica/Indigo diesel.
esteem_lover is offline   (1) Thanks Reply With Quote
Old 8th August 2012, 16:34   #57
Thanked: 95 Times
Not paying him is a better option. Going back to the same person who messed it up is not very sane.
zoombiee is offline   Reply With Quote
Old 8th August 2012, 16:40   #58
Thanked: 451 Times
Not paying option is exhausted since he has already made the payment which is why I suggested that he take it back there and get it done to his satisfaction (17k worth).
I know this can be a very depressing feeling after you spend so much money and the car has such silly problems like not idling and not starting etc.
Old 8th August 2012, 16:42   #59
Thanked: 95 Times
There is no guarantee that he is not going to mess it up more. Atleast I would not go back to him. Better to cut losses than reccur them.
Old 8th August 2012, 17:25   #60
JayD's Avatar
The moment i took the car initially itself i knew it was not right. He told me that it just needs to run, and will be ok by the time i reach the city. I dunno why i bought his story then, but somehow, i did.
Also, having read all the reviews about him online, and i had gone there with references from many people, so the last thing on my mind was that i would be ripped off.
I did go a second time to resolve the issues na, that's when he told me about opening the head and blah blah.
to be very honest, i thought it would be better to count my losses and move on, rather that letting him experiment and ruin the car more, maybe even rendering it useless.
The same has happened to 2 other s10's in chennai, which i know personally. One car was scrapped a while back at pudupet, for the same reason, the other car awaits scrappage.
The timing belt is an extremely complicated operation on the s10. Also, ive personally seen the state of a 28k kms done s10 recently, and it was scary. If it was not changed, the car would have seized.
Personally, i feel, all rubber belts etc should be replaced by age, if the running is low.
Exactly!
Tell me about it. Heartbreaking is an understatement to describe this situation.
My point exactly.
From a hot hatch to a HOTTER hatch : A pre-worshipped '02 Fiat Palio 1.6 GTX swiftnfurious Long-Term Ownership Reviews 74 2nd May 2018 23:35
Fiat Palio - S10 - The legend lives on ! EDIT - Now Sold karizma_devil Test-Drives & Initial Ownership Reports 88 20th November 2011 20:02
I have been invited to the CIMAMotor 2009 in China! EDIT: Report has begun! Karizma Fan Motorbikes 17 24th September 2009 12:19
My Swift ZXi...The Mods just begun!! V-16 Modifications & Accessories 227 2nd November 2008 04:04
Cars that have begun to show their age akash_m The Indian Car Scene 52 10th October 2007 01:29
