Old 28th February 2013, 08:44   #121
nkrishnap's Avatar
Thanked: 4,459 Times
Default Re: My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun
After the painting, is this going in to the oven? If yes, what sort of an impact is it going to have on the tyres and other mechanical parts of the car?
nkrishnap is offline   Reply With Quote
Old 28th February 2013, 12:00   #122
Nimish anthony's Avatar
Thanked: 1,670 Times
Originally Posted by cityvic View Post
The preps are looking great.
How does one put the side skirts back?Stick them with double sided tape or screw them?
The company settings have it screwed which is removed at the time of painting and the same is later screwed back after the painting is done
When the car is sent to the oven the engine room is stripped and covered, the tires dont go with it. It will not have any impact on the plastic parts if properly taken care of. Kindly note that the booth temperature will be lesser than the temperature when the car is fully revved moreover the engine is designed in a way to handle the heat. So there will not be an impact of the paint booth temperature
Nimish anthony is offline   (5) Thanks Reply With Quote
Old 28th February 2013, 12:14   #123
JayD's Avatar
Thanked: 2,008 Times
The S10 skirts have clips built in, and will hold on to the car. IIRC, there are 2 screws too, i am having trouble recollecting.
It is slow baking in the booth, not frying temperatures, so there wont be any damage to the car per se.
In any case, all the rubbers and tires etc are being changed!
JayD is offline   (2) Thanks Reply With Quote
Old 28th February 2013, 12:28   #124
swiftnfurious's Avatar
Thanked: 6,581 Times
Originally Posted by JayD View Post
...In any case, all the rubbers and tires etc are being changed!
I think the rubber is usually a long piece & NOT manufacturer / model dependent right? Do all the cars use the same spec rubber beading?
Could you tell me how much will the approximate cost of this for your car? My car had been parked in the open space / heat and how some of the beading are in bad shape.
swiftnfurious is online now   Reply With Quote
Old 28th February 2013, 12:32   #125
planet_rocker's Avatar
Thanked: 368 Times
The GTX has a layer of thin double sided adhesive tape on the black stone guards / side skirts in addition to the clips & screws.
planet_rocker is offline   Reply With Quote
Old 28th February 2013, 12:58   #126
The s10 also sports the same tapes and clips but the load goes on the screws which keeps them bonded together. The summary would be adhesive tapes, clips and then screws.
Nimish anthony is offline   (1) Thanks Reply With Quote
Old 28th February 2013, 21:01   #127
JayD's Avatar
Adding some 'Italian Seasoning'
My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun-img_0247.jpg
JayD is offline   (5) Thanks Reply With Quote
Old 1st March 2013, 05:41   #128
josejoseph's Avatar
Thanked: 319 Times
Jaydev,
Is that your SS-80 getting repainted in one of the pics?
-- Jose
josejoseph is offline   Reply With Quote
Old 1st March 2013, 11:44   #129
JayD's Avatar
Originally Posted by josejoseph View Post
Jaydev,
-- Jose
Yepp! Thats mine too! Undergoing a full resto!
JayD is offline   (1) Thanks Reply With Quote
Old 1st March 2013, 12:56   #130
josejoseph's Avatar
Thanked: 319 Times
Cool!!! I've always admired your SS 80. It's one of the most original cars I've ever seen except for the wheel caps. Many times I have spotted this car in Panampilly Nagar. Once I saw you driving around with a huge dog.
-- Jose
Old 1st March 2013, 13:06   #131
JayD's Avatar
-- Jose
Glad you like it. After im done with the resto, its going to be even better.
The wheelcaps were sorted out long ago, the black plastic ones were replaced with the original chrome ones!!
My dog loves travelling in the car, and u must have spotted me when i was taking him to the vet, at the end of panampilly nagar.
Some more updates, decided to go with the full on Italian theme for the roof and mirrors. Was initially planning on vinyl, but nothing ca match the quality of a well executed paint job.
The flag on the roof was a little tricky as we had to make sure the partitions for the different colours did not stick out like a sore thumb. It took quite a lot of effort from my painter to get it done, but the result is nothing short of phenomenal!!
My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun-img_0214.jpg
My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun-img_0213.jpg
Old 1st March 2013, 14:35   #132
anachronix's Avatar
Thanked: 1,294 Times
Happy to see the S10 getting back the much required bling! Do post more about the little SS80 too
I thought you wanted to give it a OE look, was hoping to see a brand new S10 in canary yellow. The italian seasoning is really making it more special!
Nice work
anachronix is offline   Reply With Quote
Old 1st March 2013, 14:37   #133
Thats a great job. The beginning of a new concept. Flagged roofs. Well done Jay
Nimish anthony is offline   Reply With Quote
Old 1st March 2013, 17:00   #134
JayD's Avatar
Nice work
Will post about the ss80 too. It is a fully original factory deluxe model. Resto is in the final stages now.
I was planning on the OE look, but decided instead for the OEM+ look.
Am not doing any irreversible mods to the car, and am retaining all the special bits which made it a limited edition!!
Thanks Nimish! Yeah! Its quite a difference from the black roofs which most modded cars have!!
Anyways, here is one more teaser!! When the car is so special, the rims have to equally special right??
JayD is offline   (6) Thanks Reply With Quote
Old 1st March 2013, 19:53   #135
Thanked: 66 Times
Hey, jayd, I do remember reading somewhere ,you have installed and switch for changing the exhaust note?? Can you shed some light on that mod? What upgrades have you done to brakes?
I have seen this car in Facebook page of jgarage! Your seats are also looking nice from outside, couldn't get a closer view.
streetracer_919 is offline   Reply With Quote
From a hot hatch to a HOTTER hatch : A pre-worshipped '02 Fiat Palio 1.6 GTX swiftnfurious Long-Term Ownership Reviews 74 2nd May 2018 23:35
Fiat Palio - S10 - The legend lives on ! EDIT - Now Sold karizma_devil Test-Drives & Initial Ownership Reports 88 20th November 2011 20:02
I have been invited to the CIMAMotor 2009 in China! EDIT: Report has begun! Karizma Fan Motorbikes 17 24th September 2009 12:19
My Swift ZXi...The Mods just begun!! V-16 Modifications & Accessories 227 2nd November 2008 04:04
Cars that have begun to show their age akash_m The Indian Car Scene 52 10th October 2007 01:29
