Old 30th October 2012, 14:49   #181
Thanked: 1,172 Times
Default re: Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!
@Frank,
Though in this case it may be a real misalignment, I learnt an interesting fact from my Laura's manual - the headlights are never aligned 100% straight - they are aligned slightly to the left for RHD countries and slightly to the right for LHD countries. So one should not try to achieve 100% straight line setting. (I think the idea is to have the footpath and the edge of the road always visible - for safety).
This should cool your nerves a little bit.
BTW, why are you running around garrages?
Why don't you go to Honda and get it checked?
Cheers!
anandpadhye is offline   (2) Thanks Reply With Quote
Old 31st October 2012, 01:07   #182
frankmehta's Avatar
Thanked: 2,334 Times
Originally Posted by anandpadhye View Post
@Frank,
Cheers!
Yes, that's exactly the reason why importing headlights officially from European countries (which have LHD cars) is not recommended, even though they share the same parts bin as their Indian counterparts. The light might look the same and fit flush, but it will be unsafe as beam scatter will be directed to the left, instead of the right side and hence will blind oncoming drivers, esp on Highways.
I used the lights tonight for the first time since I upgraded them and the beam looks the SAME as the 51 w bulb. The extra 30 w is not showing. I attribute it to bad focusing as well...
I will turn to Honda soon, if there's no solution outside.
Old 31st October 2012, 02:58   #183
Blue Thunder's Avatar
Thanked: 335 Times
Originally Posted by frankmehta View Post
...from European countries (which have LHD cars).... as beam scatter will be directed to the left, instead of the right side ....
For LHD vehicles, the beam scatter will be towards the right, not to the left ?
Blue Thunder is offline   (1) Thanks Reply With Quote
Old 31st October 2012, 12:16   #184
Well, I think the headlights are same, the left/right orientation is settable. At least that's what I get from the Laura manual. Skoda says if you need to drive in another country that uses different system than yours, make sure to get the headlight focus adjusted accordingly. Will go home and try to quote word to word from the manual.
Yes, I think so.
Old 31st October 2012, 13:26   #185
S_U_N's Avatar
Thanked: 383 Times
@frank: The RHS headlamp is probably a problem. Notice that the road illumination is much further ahead of the car.
You might want to try this exercise:
1. Place a thick towel on the one of the two headlamps and cover it completely. Then check the focus/ throw of the other headlamp.
There are screws/ gears for adjusting (Vertical & Horizontal). Use a socket wrench or something else more suitable for the same. Maybe the Civic thread can tell you where to locate these gears.
2. Repeat the step 1 for the other side.
This should improve the illumination for city use and buy you enough time to decide what to do next.
S_U_N is offline   (2) Thanks Reply With Quote
Old 31st October 2012, 13:45   #186
frankmehta's Avatar
I think you are correct..
Yes, I think so.
I must check my manual for that.
I think my problem has been sorted fine. But superb advice. I had planned something on the lines you have suggested.
I might be wrong about the direction of the lights. Anand and Blue Thunder, I think you'll got it right.
OK guys, MISSION ACCOMPLISHED!!!
Headlights issue sorted. Culprit: Poor fitting of bulbs on the head light housings from day one. The electrician who must have done it for the previous owner was clearly incompetent and made a mess out of the alignment of both bulbs. The headlight leveling motor itself was slipping due to poor fitting and everything was such a mess when we opened up the bumpers.
Went to Swadi automobiles who did a FABULOUS job. Thank you so much @tejas@perioimpl!
They have a Hella Leveling machine with a lux meter and a calibrated device that assists in alignment of the headlights. Apparently, the WHOLE time, the beam was facing skywards. It was pathetic, I tell you!!
Photos of the device followed by a few beauties I saw at Swadi. Have a look. I was charged Rs. 1266 as labour for opening up the bumpers and fixing the alignment. Worth it, since getting new headlights would have entailed 7000 rupees in parts and atleast Rs 1000 as labour. Money well spent!!
The beam issue is now fully sorted and when I flashed my headlights in my dimly lit parking lot, I was impressed. Will take photos of the beams at night..
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104853.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104900.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104914.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104925.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_103748.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_103812.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104027.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104109.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104116.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104835.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_104843.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_110000.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_110011.jpg
frankmehta is offline   (4) Thanks Reply With Quote
Old 31st October 2012, 13:50   #187
Wow, where is this workshop?
Cheers!
anandpadhye is offline   (1) Thanks Reply With Quote
Old 31st October 2012, 14:16   #188
Thanked: 350 Times
Cheers!
From our directory: http://www.team-bhp.com/forum/mumbai...tomobiles.html (Headlight adjustments - Swadi Automobiles)
Tel: 022 - 23877916, 23870272, 23889352
Fax: 022 - 23872013
Contact: Mr K V George
Email: swadiauto@vsnl.net
Address: Petit Compound, Nana Chowk, Near Bata Showroom, Grant Road, Mumbai - 400007
dipen is offline   (2) Thanks Reply With Quote
Old 31st October 2012, 23:10   #189
frankmehta's Avatar
Pictures speak a thousand words. I am extremely happy with the results. Here's a few pictures taken in tube light and also a few in the dark, with low beam and a dipped beam. A few of a frontal vision to see the beam scatter on the ground.
And then a couple of videos..
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204257.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204314.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204321.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204432.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204441.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204448.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204501.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204518.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204546.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204552.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204611.jpg
Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!-img_20121031_204625.jpg
frankmehta is offline   (1) Thanks Reply With Quote
Old 4th November 2012, 03:01   #190
frankmehta's Avatar
Guys. I am in dire need of someone who can just sit in the car and sort out all my rattling issues. I have about a dozen different rattles emanating from the car and I am getting unnerved with every bump on the road.
Is there ANYONE in Mumbai who actually specializes in this kind of stuff??
Old 4th November 2012, 08:42   #191
Thanked: 106 Times
You can check up Sunil Shanbag's garage "Select Auto" , they have kept my OHC Vtec rattle free till date.
saurabhkum is offline   (1) Thanks Reply With Quote
Old 5th November 2012, 15:21   #192
frankmehta's Avatar
Thanks. Have called him and waiting for an appointment. Wanted to visit him since a long time. Now I have an excuse.
I just thought i'll make a mini update here.
Done 2500 with her already. A/C, Brakes, Engine ICE performing exceptionally well. Headlights now work fine. Rattles need to be addressed, though. Going to a petrol pump tomorrow for getting the engine bay and underbody washed.
As for mileage:
Did 156 km today and filled 277 rupees of CNG
Getting an average figure of Rs. 2.2-2.8 a km. As good as FREE!
Old 7th November 2012, 23:40   #193
frankmehta's Avatar
Hey people!!! Any idea which company makes the ORIGINAL HONDA replacement Air filter elements for the Civic?? I have a SAKURA one in my car and I want to replace it with something less generic.
Old 8th November 2012, 22:36   #194
jatinpatel's Avatar
Thanked: 191 Times
Sakura is the original Honda replacement.
other might be the Purolator but didn find it good.
In my car the Air filter paper element strarted braking up within 5k kms luckily spotted it in time and replaced it.
It would had created a HAVOC if it would had entered the engine.
jatinpatel is offline   (1) Thanks Reply With Quote
Old 8th November 2012, 23:13   #195
vikram_d's Avatar
Thanked: 940 Times
Frank, why not get a k&n stock replacement filter?
vikram_d is offline   (1) Thanks Reply With Quote
2012 Maruti Ritz VDI - Our new family workhorse! **EDIT: Now sold!** RavenAvi Test-Drives & Initial Ownership Reports 123 26th February 2014 15:36
Frankmehta's workhorse : Black Maruti Swift ZDi. EDIT, now with RD Box frankmehta Test-Drives & Initial Ownership Reports 70 7th January 2014 17:58
Company Workhorse : New Eeco 5 seater CNG or Used Dzire + CNG kit? NMM What Car? 2 4th February 2013 19:29
The Makings of a Practical Workhorse: An Automatic Civic with CNG & more frankmehta Modifications & Accessories 33 25th September 2012 00:52
Honda Civic CNG now sold in USA giri The International Automotive Scene 0 2nd February 2007 12:38
