Old 19th November 2012, 22:19   #211
Thanked: 45 Times
Default re: Frankmehta's Practical Workhorse: Honda Civic AT CNG. EDIT: Sold!
Originally Posted by jatinpatel View Post
how can you do wheelspin in a civic auto which has a poor low end ?
Unless you hold onto the brake rev it till 3k and just dumb the brakes, and damaging the tranny.
Ah jatinpatel, that my friend is the orgasmic story behind an i-VTEC with PADDLE SHIFTERS.
Sir Frankmehta if you may guide others - how an AT becomes an MT in the Civic. I think there is a triptronic manual mode / Sports mode button if I'm not wrong.
spinfreak is offline   (1) Thanks Reply With Quote
Old 19th November 2012, 23:26   #212
gomzi's Avatar
Thanked: 125 Times
There's an entire thread (old one) on the civic paddle shifters, essential reading for anyone interested in civics or stuck in a civic vs corolla decision. I can't seem to figure out how to link to the thread on the tbhp android app tho, a quick search will unearth it.
gomzi is offline   (1) Thanks Reply With Quote
Old 20th November 2012, 23:47   #213
jatinpatel's Avatar
Thanked: 191 Times
I have a Civic AT myself!
and it can happen in 1st gear but very very very rarely in 2nd.
jatinpatel is offline   (2) Thanks Reply With Quote
Old 21st November 2012, 00:01   #214
sarathlal's Avatar
Thanked: 2,184 Times
Are these the ones?
http://www.team-bhp.com/forum/techni...dle-shift.html (about civic paddle shift)
http://www.team-bhp.com/forum/indian...will-work.html (Paddle shifts on Indian cars - will it work?)
sarathlal is offline   (1) Thanks Reply With Quote
Old 21st November 2012, 11:45   #215
Thanked: 45 Times
Pedal to Metal red line in S mode 1st gear, and up-shift! Yes, true it happens rarely only, maybe on lower than normal grip conditions, eg newly laid roads, or dusty, or wet road.
Thanks. All I was wondering was the CNG response at higher rpms, which can only be forced through paddle-shifts or S mode. I got a satisfactory answer to that.
i-VTEC after all is a gem of a motor. Lots of articles on friction saving technologies implemented by Honda on it. If inferior motors, some 3-pot, can handle CNG fuel well, why not the i-VTEC.
Old 21st November 2012, 11:54   #216
frankmehta's Avatar
Thanked: 2,334 Times
Going in for a suspension check up guys. The rear shocks seem to have become slightly stiff, maybe. On bumps at full load, I hear a characteristic thudding sound (of the shocks and springs reaching their limits) which means I need to wheel her into a garage and have her thoroughly checked.
Any pointers for a good suspension specialist in Mumbai??
Old 21st November 2012, 12:02   #217
KSM-Vtec's Avatar
Thanked: 440 Times
This is very common to all the Civics...what you need is this..nothing else will help in the long run.
http://www.team-bhp.com/forum/techni...ension-24.html (Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspension?)
KSM-Vtec is offline   (1) Thanks Reply With Quote
Old 21st November 2012, 21:19   #218
gomzi's Avatar
Thanked: 125 Times
I'e heard good things about Mr. Shanbagh's garage in Dadar even from non-tbhp friends and I think he might be located closer to you.
Its a known feature of the civic suspension that it hits the rear bump stops under full load on bumpy roads (which ones in Mumbai aren't?). Its happened with my car as well and only under full load at high speed, its been well behaved when at normal city speeds (<60 kmph). My cars rear suspension's been checked out as ok by Honda so nothing to worry about.
I'm seriously thinking of checking out the Coil Spring Adjusters though, at Automech, just can't find the time for it
Originally Posted by sarathlal View Post
Are these the ones?
http://www.team-bhp.com/forum/test-d...dle-shift.html (about civic paddle shift)
http://www.team-bhp.com/forum/test-d...will-work.html (Paddle shifts on Indian cars - will it work?)
Yes, the first thread. It starts out innocuously enough but a few of the later posts describe the Civic paddle shifters in detail. I believe the city paddle shifters work slightly differently.
Not necessarily. The Civic ECU manages gear changes as per throttle inputs (unlike in a corolla AT), so i've been able to rev her till 6k rpm even in D mode with aggressive throttle inputs. Overall I find the response ~20% less in CNG mode than on petrol - need to get the kit checked out and serviced fully.
Old 22nd November 2012, 21:45   #219
frankmehta's Avatar
I understand this suspension bottoming out issue is a common one. I shall still go to get it checked at some local suspension specialist and ascertain if there is any wear and tear. Also, have contacted Darryl for the coil spring adjustment rubber, but he seems to be in the UK hence will get in touch with him via email.
As for the car, she's doing great. Due to the holiday season, haven't had many work related jaunts so she's been driven expressly in the city and in heavy traffic she costs anything between 3 and 4 rupees a km (with AC and with NO highway driving) Still a healthy figure, owing to the crazy traffic in Mumbai sometimes and the abysmal (moon surface rivaling) road surface.
There IS a problem, though, and that's the rattling which just makes me gnash my teeth in anger when there is no music playing in the car. I guess one has to make some compromises when it comes to buying a used car, and mine is the excessive no. of squeaks and rattles.
Old 22nd November 2012, 22:25   #220
sumeethaldankar's Avatar
Thanked: 1,154 Times
The Coil spring adjusters are also available with Automech at Lower Parel.
sumeethaldankar is online now   (1) Thanks Reply With Quote
Old 22nd November 2012, 22:25   #221
frankmehta's Avatar
How much do they cost? More than Auto Runner?
Old 22nd November 2012, 22:29   #222
I think they keep the same brand.You can call or visit them and find out the price which should be same as per other seller.
Edit: 4500 for all fours was the price in April 2011.
http://www.team-bhp.com/forum/techni...ml#post2301225 (Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspension?)
Old 22nd November 2012, 23:19   #223
frankmehta's Avatar
Might drive down to Automech and just get them installed in this week. ONLY the rears.
Old 23rd November 2012, 00:52   #224
jatinpatel's Avatar
Thanked: 191 Times
I would strongly advice you against the coil spring adjusters, for sanity of the rear suspension geometry to be maintained and the car to handle the same way as it should.
Get the REAR shocks checked.
Coil spring adjuster would be putting cutting the bump stop rate but at the same time putting undue stresses on the spring whenever the spring compresses completely since the adjuster is an add on thing and its not taken into account in the spring design.
The Proper Way would be getting
1-Rear suspension check if required change the shocks.
2-Get better suspension which will make difference in the way the car rides as well as handles.
DO NOT got for the coil spring adjusters or the Autorunners.
Its an advice...
jatinpatel is offline   (1) Thanks Reply With Quote
Old 23rd November 2012, 17:15   #225
frankmehta's Avatar
Taken an appointment at Oberai Suspension for tomorrow afternoon. Will drop by and take an idea from him, and then post here.
2012 Maruti Ritz VDI - Our new family workhorse! **EDIT: Now sold!** RavenAvi Test-Drives & Initial Ownership Reports 123 26th February 2014 15:36
Frankmehta's workhorse : Black Maruti Swift ZDi. EDIT, now with RD Box frankmehta Test-Drives & Initial Ownership Reports 70 7th January 2014 17:58
Company Workhorse : New Eeco 5 seater CNG or Used Dzire + CNG kit? NMM What Car? 2 4th February 2013 19:29
The Makings of a Practical Workhorse: An Automatic Civic with CNG & more frankmehta Modifications & Accessories 33 25th September 2012 00:52
Honda Civic CNG now sold in USA giri The International Automotive Scene 0 2nd February 2007 12:38
