Old 30th July 2014, 09:22   #151
adi_petrolhead's Avatar
Thanked: 1,069 Times
Originally Posted by iliketurtles View Post
Maybe the 7.5k Kms checkup isn't there for Skoda cars. Your running is more in a diesel car's territory
But 7.5K first 'inspection' is mentioned in the warranty booklet as well. Guess they didnt bother to set the reminder in the MID. Even though I am so anxious with the car all the time that i'll happily take it every 5K kms to the service station. Initial fuel pump failure leaving me stranded at a busy cross road and no reflector triangle meant a lot of cars scraped me over as I was trying to protect my car :@
Yeah, running has been high. I run the Octy at least 350 kms a week, sometimes more. Yet to go on a cross country trip though.. Again anxiety related to bad fuel on highway bunks kicks in, makes me wanna use the good ol tank of an Innova.
adi_petrolhead is offline   Reply With Quote
Old 30th July 2014, 10:07   #152
iliketurtles's Avatar
Thanked: 1,049 Times
Default Re: Back in Black! A VW Jetta Highline DSG comes home
Quite likely that they didn't find a way to program it in and left it that, or just simply forgot to. VW programmed an 'oil change' when everyone in their right mind knows that most likely won't be the case. That was their workaround. Not the best, but it got the job done.
Good to see you're putting in the miles with the Octy, it's meant to be driven and driven. You should do a trip at some point, you know it'll be a blast, guess you'll just have to check for reliable fuel points along the way!
iliketurtles is offline   Reply With Quote
Old 30th July 2014, 12:27   #153
Thanked: 43 Times
I had this concern too with my Superb. So what I do is fill up full tank when leaving city. Then on the highway start finding a pump when my tank is 1/4th full. If I find a good pump, great! Fill up completely. If the pump doesnt seem very reliable and I absolutely need to fill up, use law of averages and fill up to the point where half the fuel volume present in tank is still from the city. Later once I find a good pump, fill up completely.
Sure this cannot guarantee fuel related issues but it at least gives me some peace of mind knowing that my car is running on 50% adulterated fuel at most.
pratika is offline   Reply With Quote
Old 4th August 2014, 01:33   #154
Had my first minor concern with the car some time back. Rolled into a fuel pump and the fuel lid just wouldn't open come what may. The attendant pulled out a key to try and pry it open and I quickly stopped him. Wedging a card in worked in prying it open, but it's a minor irritant and inconvenient fix.
It's a good thing I've got a checkup scheduled this Saturday, I'll call VW in the morning and inform them about this so that it'll hopefully be fixed on Saturday itself. Let's see how that goes.
Old 4th August 2014, 02:00   #155
Amarendranath's Avatar
Thanked: 410 Times
May be it's dirt and rubble that's jamming it? Continuous rains might have caused this. Or even the grease in the hinges might have worn off.
Amarendranath is offline   Reply With Quote
Old 4th August 2014, 08:52   #156
That struck me too. In any case, I'm not touching it until VW sees it. This did happen previously in the City I had and the problem then was a faulty spring mechanism, so I'm fairly certain it's no biggie.
Old 4th August 2014, 09:23   #157
dkaile's Avatar
Thanked: 4,463 Times
Happened recently with my Superb. Similar mechanism. Problem was sorted by removing the key and locking and unlocking the car. That set the lock in motion. Needs some lubrication I presume.
dkaile is online now   Reply With Quote
Old 4th August 2014, 09:25   #158
Tried locking/unlocking the car while I was at the pump, had no luck opening it whatsoever. It was just...stuck. Hopefully it's just a lubrication issue and will be fixed quickly.
Old 7th August 2014, 21:06   #159
Hi iliketurtles, I had a similar problem somedays back in the pump. But it finally opened after recycling the ignition keys couple of time. My car is also due for the first oil change after 9 days. Am planning to go for extended warranty too, Please let me know how much you paid for it.
airforce1 is offline   Reply With Quote
Old 8th August 2014, 00:04   #160
Hiya. I tried doing that, but it refused to budge even so. Let's see what they say when I take it in. The fix might be more innocuous than I imagine!
I am planning to take the Extended Warranty next month, the price for it was Rs. 46,xxx. I'll find out the exact amount and get back to you, it's an odd figure.
Old 8th August 2014, 00:14   #161
Gannu_1's Avatar
Thanked: 10,510 Times
Could be a bad actuator as well. Sometimes the attenders at the fuel pumps can be a bit harsh and they slap the fuel lid to close it instead of giving it a gentle push. I had noticed this on several occasions and choose to close the lid myself nowadays.
Do keep us posted on how it goes.
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 8th August 2014, 00:37   #162
True that. I am a little bit (ok, more than a little bit) paranoid about the car and do stand by it at all times at the pump, even when the cover being opened/closed. Never had anyone treat the cover roughly, although that's always a possibility with careless attendants.
I'll keep in mind your point about it being the actuator and keep you guys posted on it. I've got a message from VW letting me know who'll be servicing the car so I'll give him a call tomorrow morning and bring him up to speed.
Old 8th August 2014, 01:04   #163
VW2010's Avatar
Thanked: 2,124 Times
You can check if there are some dust in the contact points. I dont know if the actuator is located at the same spot in your MK6 but it shouldnt be much different.
I am a DIY guy and i would have actually ripped open to find the root cause on one of my sweet saturdays
The best thing about (i think i can say German cars in general) jetta is that the way the car is build, its one of the easiest to work on at home. Removing things and putting it back is so well designed that you would be surprised it takes few screws to remove even the bumper. I have completely removed those truck cladding and worked on my own reverse camera and i can say removing and mounting it back is actually a piece of cake. Considering it takes twisted head and some sprain around the neck to clean a Swift air conditioner fan the Jetta is fairly simple in most of the areas.
The door panels are locked by plastic clips and minimal screws.
I am sharing this to say DIY in the TDI is one of the reason why i went after the Jetta. The web is full of DIY for the TDI and some are very complex ones as well.
VW2010 is offline   Reply With Quote
Old 8th August 2014, 09:04   #164
Thanks for the video, VW2010. I'll go take a look-see at the car when I step down in some time. Could be the actuator, could be a lack of lubrication, I really don't know at this point.
I'm not much of a DIY guy to be honest,but I have read a fair few DIY's for VW group cars, which gives an idea of how easy they can be to work on. Thanks again for the heads up, perhaps I'll be inspired to indulge in some DIY at some future point inn time
Old 9th August 2014, 16:52   #165
So I just got the car back this morning after a quick check-up from the VW guys and it was all very painless, but it's still early days in my relationship with them, so I wouldn't form an opinion of them so easily!
Nonetheless, they were very transparent and communicative at all points in time, so to that. I got an SMS about 3-4 days telling me who my service rep was, so I got in touch with him and explained the fuel lid issue, asked him to keep an actuator in stock just in case it had to be changed. He called me back after about 2 hours and confirmed that he had done just that, so that was me quite satisfied.
Turns out the spring had got jammed and so they fixed that and I was good to go. I was promised I'd get the car by 4:00, but I got it back by about 12:30 with the checkup done. In the interim, I got constant SMS' from VW about the service, including one when it was ready for delivery. They were hyper-communicative at all points of time, and that was fine by me.
The only expense on my part was the engine oil I topped up, which was Rs. 970 for a litre of Castrol Magnatec Professional. The remainder of it was given to me as a gift. How very thoughtful So all in all, a good experience at VW, but I'd much rather judge their quality during an actual service and not just during a checkup like this.
Hi! The Extended Warranty is available for Rs. 46,077, so do go for it. It is pricey, but the peace of mind is priceless.
Platinum Grey VW Jetta 2.0 TDI Highline DSG comes home graaja Test-Drives & Initial Ownership Reports 344 27th March 2018 18:28
Silver VW Jetta DSG Highline 2.0 TDI - Latest addition to our family abhilashgp Test-Drives & Initial Ownership Reports 35 25th August 2016 19:41
