Old 2nd January 2015, 15:50   #76
Default Re: Toyota Innova: My Pre-worshipped Black Workhorse
Originally Posted by Buffetfan View Post
if you want to try fuel efficient driving, try coasting - i.e. gliding along without propulsion as much as possible. Coasting dissipates stored energy (kinetic energy and gravitational potential energy) against aerodynamic drag and rolling resistance which must always be overcome by the vehicle during travel. If coasting uphill, stored energy is also expended by grade resistance, but this energy is not dissipated since it becomes stored as gravitational potential energy which might be used later on. Using stored energy (via coasting) for these purposes is obviously more efficient than dissipating it in friction braking. When coasting with the engine running and manual transmission clutch depressed (Note: in neutral coasting is against law in some US States, unaware of status in India), there will still be some fuel consumption due to the engine needing to maintain idle engine speed.
Normally I get 10-11 kmpl in city and similar on highways. Now see the results I obtained with Innova VX 2009, in gear coasting on 200+ Kilometer trip, averaged for both ways (to cancel out gradient, wind etc)
How reliable is the Average mileage indicator in the Innova. Mine always hovers around 11 but i have seen my tank full to tank full go down to 10 as well.
alexgv is offline   Reply With Quote
Old 2nd January 2015, 15:59   #77
Shanksta's Avatar
Thanked: 1,610 Times
Congrats on brilliant example you've got there.
Mileage is something you shouldn't expect in the innova. The maximum I have got till date in my innova is 13.65kmpl that was because of state highway where a speed of 80kmph was the maximum possible. My average in the city is always consistently in the range of 10.5-11.5kmpl (Chennai). The worst FE that I have got till date was 9.7kmpl where the car was driven at 120-140kmph due to free roads on the way to Kodaikanal from Chennai. Except this one off instance we always maintain speeds in the range of 90-110kmph and get about 12.5 kmpl on an average during highway drives. But let me tell you every time this car comes back from service you will have a huge grin on your face cause the cost is very low for a car costing so much, only every 40k kms the bill is in the range of 8-12k rupees since it is a major service. This has been said time and again but nevertheless I shall say it once more the reliability of the Innova is unparalleled!!! Enjoy the workhorse!
Shanksta
Shanksta is offline   (1) Thanks Reply With Quote
Old 2nd January 2015, 17:11   #78
SHAHBAAZ's Avatar
Thanked: 109 Times
Shanksta,
I agree with your numbers. I have once recieved 9.8kmpl in only city driving conditions and it was taken during my first usage of 450kms in city with AC on. Later once I was accustomed to innova, it started to give between 11.4 to 12.1. All these averages are for city with AC on and tank full to tank full. On my long run to Ahmadabad 2 months ago and my this weeks Ajmer trip, it gave me 11.8 to 12.15kmpl at a steady driving of 120-130kmph with occasionally going to 140kmph. The car had 4 adults and a kid with good amount of luggage.
In another recent trip to Pune-Aurangabad-Pune with 15% city driving, I achieved 13.56kmpl where the speed ranged between 90-105kmph.
Whatever 7040kms, I have clogged in last 3 months is with AC on. I am so loving my Innova that the kms speak whereas my Palio and Bullet stand idle..
SHAHBAAZ is offline   (1) Thanks Reply With Quote
Old 2nd January 2015, 17:57   #79
bbhavan's Avatar
Thanked: 78 Times
Friends, I have one query regarding the ideal tyre pressure to be maintained in the Innova.
For Highway rides, I usually inflate the tyres to 35/37 psi, +2,3 psi more than the recommended pressures.
I feel your expectation of +14 mileage is difficult to attain. Even for very long highway ride, with almost sedate driving, 13kmpl is the usual outcome.
Enjoy your trip
bbhavan is offline   (1) Thanks Reply With Quote
Old 2nd January 2015, 18:12   #80
AutoIndian's Avatar
Thanked: 3,875 Times
Isn't there a tyre on the drivers side door which gives the specific tyre pressures to be maintained under different load conditions?
If the recommended cold tyre pressures are 33 psi all round, then maintain +2 psi if the air filing point is a bit far from your residence as tyres get warn by the time you'll reach there.
Good hint there Anurag. I need to have a close look on the drivers side door to check the specific tyre pressures for the Innova. I always check the tyre pressure early in the morning with my pressure gauge "Accurate" make and top it up with my old trusty foot pump. I have long stopped going to the tyre shop to check the tyre pressure.
Originally Posted by mroptimist View Post
Toyota recommended Tyre pressure for not fully loaded is 33PSI all around. For fully loaded it is 33PSI front and 36PSI rear wheals. Slightly higher Tyre pressures would reduce the chances of tyres getting punctured or burst at the cost of ride quality. Deterioration in ride quality though is negligible.
Thank you for those inputs mroptimist. I will inflate the rear tyres to 36 psi for the trip planned for tomorrow.
Sorry for not congratulating you earlier. Wish you many safe, comfortable and fun filled miles on your latest acquisition, the black Innova.:thumbup:
No worries mate. Good that at least you stumbled upon this thread. Keep your comments coming in. I hope all the (existing and previous) Innova owners contribute to this thread as much as possible.
Originally Posted by SHAHBAAZ View Post
AutoIndian, I am maintaining the pressure to 35psi on all four tyres and would reccomend you the same.
Previously I too had various people saying 33/35 for front and rear, few recommended 34 for all four for better ride. But my tyre shoppe person recommends 35 in all four even if its a city use.
Thanks for those inputs SHAHBAAZ. Now onwards I will to maintain 35-36 psi all round.
I Returned yesterday from Ajmer Shareef(Rajasthan) after clogging 2360kms in 4 & 1/2 days with total journey of around 5 & 1/2 days. The ride was awesome and comfortable except for two punctures on same tyre in a span of 250kms. Finally had to insert a tube in my tubeless Tyre to have the remaining ride without any further hiccups.
Congratulations on completing yet another successful trip and feel sorry about those 2 unwanted punctures. Any particular reason for the 2 punctures on the same tyre? What was the object that punctured the tyre (nail, sharpnel, screw etc)?
Thank you Shanksta for your wishes
I totally agree with you. Now I have corrected my expectations from Innova on mileage front, 12 kmpl seems to the average all across, anything around 13 is great and breaching the 14 kmpl mark would be super-duper.
As I mentioned earlier 80 kmph seems to be the sweet spot for the Innova (or for any other car for that matter) as far as mileage is concerned.
I agree the low service bills and the bullet proof reliability are the biggest USPs of the Innova and these two made me fall for it.
That is some serious running that you have done in the last 3 months. For me in the last month and a half, I have done around 2.7K kms. A majority of this can be attributed to my daily office commutes and only 400 kms was due to a long trip to Nasik that I did last Monday-Tuesday. Same is the case with me. My Indica has hardly hit the road after the Innova took over the mantle from it. My bike and scooter are facing the same fate.
AutoIndian is offline   Reply With Quote
Old 2nd January 2015, 18:54   #81
Shanksta's Avatar
You're welcome! The mileage figures are with AC always on.
Haha! The fate of your other vehicles I can relate to it.
Old 2nd January 2015, 19:36   #82
dean5545's Avatar
Thanked: 801 Times
I feel the sweet spot of the engine is at 5th gear 2500rpm. The speed is around 95kmph. The car is extremely silent too at that speed at least in my car I feel like that. Try being at that rpm and let me know.
dean5545 is offline   (1) Thanks Reply With Quote
Old 2nd January 2015, 19:38   #83
Thanked: 14,603 Times
The recommended pressures is F = 31 psi and R = 29 psi. What I have been doing is F = 33 psi and R = 31 psi.
Good that you fill in air yourself and not the fuel station fillers. Will PM you add i need details on the foot pump as I am in the market for one. I have a pressure gauge already.
Don't worry, I am very very confident that the Innova will make you clock more miles even though you wouldn't want to. This car is an addiction.
a4anurag is online now   (1) Thanks Reply With Quote
Old 3rd January 2015, 22:44   #84
AutoIndian's Avatar
Just now returning back from the one day trip to holy place called Gondavale (Satara District). We were 6 adults and 2 kids. Started @ 07:45am. Took the route Hadapsar - Saswad - Jejuri - Nira - Lonand - Phaltan - Dahivadi - Gondavale (167 kms one way). Total distance covered 337 kms
I forgot to carry my point and shoot camera and had to rely on my phone camera to capture some moments. Sharing some snaps taken during the trip.
A huge Banyan tree enroute
Toyota Innova: My Pre-worshipped Black Workhorse-huge-banyan-tree-enroute.jpg
My BW with the Banyan tree in the backdrop
Toyota Innova: My Pre-worshipped Black Workhorse-my-bw-banyan-tree-backdrop.jpg
One of the many wild flowers enroute
Toyota Innova: My Pre-worshipped Black Workhorse-one-many-wild-flowers-enroute.jpg
Another set of wild flowers enroute popularly known as Tantani in Marathi
Toyota Innova: My Pre-worshipped Black Workhorse-another-set-wild-flowers-enroute-popularly-known-tantani-marathi.jpg
Ascend of the Mograle Ghat
Toyota Innova: My Pre-worshipped Black Workhorse-ascend-mograle-ghat.jpg
BW looking down the valley on Mograle Ghat
Toyota Innova: My Pre-worshipped Black Workhorse-bw-looking-down-valley-mograle-ghat.jpg
A State Transport bus passing by
Toyota Innova: My Pre-worshipped Black Workhorse-state-transport-bus-passing-.jpg
BW getting the bird's eye-view in Mograle Ghat
Toyota Innova: My Pre-worshipped Black Workhorse-bw-getting-birds-eyeview-mograle-ghat.jpg
AutoIndian is offline   (1) Thanks Reply With Quote
Old 3rd January 2015, 22:58   #85
AutoIndian's Avatar
Some pictures from the holy place "Gondavale"
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale1.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale2.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale3.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale4.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale5.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale6.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale7.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale8.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale9.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-some-pictures-holy-place-gondavale10.jpg
AutoIndian is offline   (2) Thanks Reply With Quote
Old 3rd January 2015, 23:14   #86
AutoIndian's Avatar
Main Samadhi Temple - Exterior
Toyota Innova: My Pre-worshipped Black Workhorse-main-samadhi-temple-exterior.jpg
Main Samadhi Temple - Interior
Toyota Innova: My Pre-worshipped Black Workhorse-main-samadhi-temple-interior.jpg
My kid wondering why there is a cut in the tyre sidewall
Toyota Innova: My Pre-worshipped Black Workhorse-my-kid-wondering-why-there-cut-tyre-sidewall.jpg
My kid enjoying the flowers around
Toyota Innova: My Pre-worshipped Black Workhorse-my-kid-enjoying-flowers-around.jpg
Kid enjoying a walk in the temple complex
Toyota Innova: My Pre-worshipped Black Workhorse-kid-enjoying-walk-temple-complex.jpg
Some shots below depicting the memorial of Nimbalkar Raje just besides the main road near Phaltan
Toyota Innova: My Pre-worshipped Black Workhorse-memorial-nimbalkar-raje-near-lonand1.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-memorial-nimbalkar-raje-near-lonand2.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-memorial-nimbalkar-raje-near-lonand3.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-memorial-nimbalkar-raje-near-lonand4.jpg
Old 3rd January 2015, 23:27   #87
AutoIndian's Avatar
On the way back, just beyond Jejuri we halted at a hotel called "Madhuban". This was a good find. Not only the food/ snacks quality was good, but the ambiance was very pleasing. Some snaps taken in and around this hotel.
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-1.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-2.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-3.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-4.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-5.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-6.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-7.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-8.jpg
Toyota Innova: My Pre-worshipped Black Workhorse-madhuban-9.jpg
Old 4th January 2015, 21:01   #88
AutoIndian's Avatar
Dean5545, just wanted to share with you that during my trip yesterday, on four lane stretches I could maintain 2500 rpm in 5th gear, which corresponded to a speed of 95 kmph and with you completely that this is the sweetest spot for the engine. Car was cruising so effortlessly with minimum noise as you have rightly mentioned. Now onwards will try to maintain this speed on open roads whenever possible.
Old 5th January 2015, 11:47   #89
Thanked: 219 Times
I check tyre pressure before starting for 34/36.
Gauges (even digital) at petrol pumps are highly suspect for accurate reading. So i've invested in a Michelin digital gague and just y'day got Slime twin cylinder inflator.
DwarkaDelhiWala is offline   (1) Thanks Reply With Quote
Old 7th January 2015, 16:13   #90
AutoIndian's Avatar
Friends, finally I have achieved it . A mileage of 14.09 kmpl in today's tankfull. Today while coming to office I did a tank full (the same bunk from which I had filled on 3 earlier occasions). Tank gulped in 43.08 litres of diesel (actually 1-2 litres extra after the auto-stop mechanism cut off the fuel) and the car had run for 607 kms since the last tank full, giving me a mileage of 14.09 kmpl. This is the best ever mileage I have got in my last two months of ownership (and 7 tankfulls). Finally getting a hang of how to drive the Innova to extract the best FE figures.
Out of the 607 kms, 340 kms were done on an outstation trip (to and fro) with 6 adults and 2 kids (speeds ranging between 80-100 kmph on open stretches) and the balance 267 odd kms were done for my daily office commutes (single occupant). AC ON most of the times. Only during 2-3 late night return trips from office to home (due to very cold weather) AC was switched off. Also for outstation trip I had increased the tyre pressures to 34 and 35 psi (front and rear). I believe this might have contributed a bit to the increased mileage.
The previous owner of my car had not fitted any mud flaps due to which the sides steps were getting dirty quite often. Today I fitted a set of 4 fibre mud flaps for Rs 350/-
Our family workhorse: Pre-owned Maruti WagonR asit.kulkarni93 Test-Drives & Initial Ownership Reports 27 16th October 2015 21:17
My 1st ever Toyota - A pre-worshipped Corolla H2 crazyleediamond Test-Drives & Initial Ownership Reports 13 22nd May 2015 20:13
Frankmehta's workhorse : Black Maruti Swift ZDi. EDIT, now with RD Box frankmehta Test-Drives & Initial Ownership Reports 70 7th January 2014 17:58
Bought a Pre-worshipped, Pre-team bhped Cedia-My journey from one Sport to another carfreak Test-Drives & Initial Ownership Reports 50 18th January 2012 18:37
