Old 5th February 2016, 10:34   #211
graaja's Avatar
Thanked: 3,547 Times
Default Re: Frankmehta's VW Polo GT TSI!
Originally Posted by frankmehta View Post
Now, a car needs headlights. AND GOOD ONES
Hey Frank,
The headlights look awesome and the cutoff is fantastic
I can feel the heartache when you have to throw out the OE headlights. But the final result I guess should compensate for the pain.
Can you share some more details of the headlights?
1. Are these from Eagle Eyes that come with halogen projectors?
2. Have you changed both low and high beams to HIDs?
3. Do the DRLs turn amber when you turn on the indicator?
4. Were you able to salvage the Morimoto FX-R projectors from the headlights?
graaja is offline   (1) Thanks Reply With Quote
Old 5th February 2016, 10:50   #212
frankmehta's Avatar
Thanked: 2,317 Times
Hey Frank,
Thanks for the kind words. I still cringe at the thought of throwing away OE equipment but I can't do anything about it now.
The final results are WAY better than they look in photos. The magical cut-off and the rainbow effect are so distinct and so clear that it actually makes be super happy to drive at night with these.
Answers:
1. These are Eagle Eyes, the genuine ones with the warranty. NOT replicas. These comes with DUAL projectors. One for the low beam, and one for the high beam.
2. The low beams have HIDs and the high beam has my original Osram Night Breaker Unlimited, since both slots house H7 lights.
3. The DRLs are of one colour. They don't change any colour, but there is a strip of Amber LEDs that light up when you switch the turn signal on. See photos. I can upload a small video if you want.
4. The Morimoto Projectors and the D2S setup are happily seated here and are doing a STELLAR JOB because the retrofit was done PERFECTLY under my supervision in Mumbai itself:
http://www.team-bhp.com/forum/test-d...ml#post3899571
frankmehta is offline   (2) Thanks Reply With Quote
Old 5th February 2016, 11:01   #213
Thanked: 122 Times
Congrats on the install Frank! I assume these are the Lumen Systems Eagle Eyes. Your GT is the exact version of how I would like my GT to be, Audiophile equipment aside. Now to wait for saving enough Vitamin M
I assume these were plug & play as well?
I just had another idea, what do you think about the potential for retrofitting the new 2016 Vento's LED headlamps? Now wouldn't that be sweet?
sidparekh is offline   (1) Thanks Reply With Quote
Old 6th February 2016, 10:40   #214
frankmehta's Avatar
The Vento's LED headlamps might not be a direct fit (changes to wiring harness, maybe) but I am sure people who want to get them installed will manage some way to do.
The Golden question here is, ARE LED HEADLIGHTS READY FOR PRIME TIME?
I don't think so! Initial reviews say that LED-Projector Combination has more or less the same light output and spread as an HID-Projector Combination.
There's a lot of potential in LED lights as Automotive Lamps, but the technology is still in quite an amateur stage, and for me HID + Projector Combination still stands as the ultimate car lighting, as of today.
frankmehta is offline   (1) Thanks Reply With Quote
Old 8th February 2016, 17:24   #215
F2005's Avatar
Thanked: 53 Times
Hi Frank, I have a question. Since the polo doesn't come with DRLs.
Should you switch on the parking lights, so that the DRLs are on ? ( I am assuming the DRLs are a replacement for the parking lights)
F2005 is offline   (1) Thanks Reply With Quote
Old 9th February 2016, 16:42   #216
Thanked: 34 Times
Frank, the headlight assembly is FANTASTIC!!
How much have you spent for the entire installation?
keeru is offline   (1) Thanks Reply With Quote
Old 9th February 2016, 16:49   #217
frankmehta's Avatar
Yes.. I haven't wired these as drls. I wanted to keep them as parking lights because these are aftermarket lights after all and I don't want to risk blowing one of the leds inside due to excessive usage or heat, since replacing them will be nigh impossible.
The headlights cost Rs. 23000 and the morimoto h7 kit cost 11k.
frankmehta is offline   (4) Thanks Reply With Quote
Old 14th February 2016, 20:38   #218
Thanked: 60 Times
Hi Frank,
About the auto headlights with sensors: Was it a DIY job or did you get someone to install it?
How has it been so far, are you happy with the end result?
nova9 is offline   (1) Thanks Reply With Quote
Old 14th March 2016, 09:24   #219
frankmehta's Avatar
Originally Posted by nova9 View Post
Hi Frank,
Auto headlight sensor and switch was a DIY job. I only used my installer's help to locate the control box inside the dash.
Old 24th March 2016, 13:40   #220
srinivasnvns's Avatar
Thanked: 81 Times
VCDS Tweaks:
1. Switched off horn while locking and unlocking.
2. Indicator Celebration ( my MOST favourite reason for buying a VCDS cable)
3. Switched time from 12 hour to 24 hours format.
4. XDS set to strong
5. Comfort Rear Wiper operation
6. Tear wipe for the front wiper
7. Lane-change indicator from 3 blinks to 4 (just for fun)
Hello frankmehta,
For the Indicator Celebration to work, did you have to modify any other setting other than the VCDS tweak? I bought my car two months before you did, so hoping the steps will be the same.
-Srinivas
srinivasnvns is offline   (1) Thanks Reply With Quote
Old 24th March 2016, 19:52   #221
graaja's Avatar
Originally Posted by srinivasnvns View Post
Hello frankmehta,
-Srinivas
Hi Srinivas,
Cluster staging is just VCDS setting. It is available under Instruments -> Adaptation setting.
Old 26th March 2016, 17:40   #222
Thanked: 81 Times
Hi Srinivas,
Thanks graaja. I got it to work this afternoon. The feature works when the key is inserted and then the ignition is turned ON. It does not work if you turn the ignition OFF and back ON. Is this expected?
Cheers,
Srinivas
Old 27th March 2016, 09:12   #223
graaja's Avatar
Yes. Cluster staging happens only when you insert the key and turn on the ignition. If you turn off,, but do not remove the key, cluster staging does not happen.
Old 11th April 2016, 14:05   #224
Car's Paradise's Avatar
Thanked: 130 Times
Also, got the OE armrest fitted. Trust me, guys, this thing took less than 10 minutes to install and is SO amazingly comfortable and practical, and also has storage inside.
Also, managed to get Torque working on the Android Head Unit. A photo and a video!
Dear Frank Sir,
Greetings!
I am looking forward to buy a universal 2 din Android 4.4.4 head-unit from the same seller you have bought.
My basic needs are to run torque and audio in the same unit.
I have a few queries regarding the product, would be thankful if you can help me out:-
1. While running torque can i play music in background?
2. Is there a provision of connecting a sub-woofer and an amplifier?
3. How is the audio quality, as compared to quality we have in our head-units?
4. How is the processing of the unit, if multiple apps are running together?
Thanks in advance.
Car's Paradise
Car's Paradise is offline   (1) Thanks Reply With Quote
Old 11th April 2016, 23:54   #225
Thanked: 12 Times
Yes, you can play music while running Torque.
Sub Out and AUX OUT is available.
Audio quality is matching the OEM unit..but you may need to use player like poweramp. For FM, I would say 90% when compare to OEM unit.
I never tested more than 3 apps.. Music, Torque and Maps. Performance is fine.
msiva75 is offline   (2) Thanks Reply With Quote
VW Polo GT 1.2L TSi: The baby TSi robimahanta Test-Drives & Initial Ownership Reports 324 7th January 2018 00:51
Scoop! VW Polo TSI spotted testing in India *UPDATE* Fresh Scoop pics on Pg.15 sarthakgupta The Indian Car Scene 441 25th April 2013 12:26
Volkswagen Jetta TSI (petrol) spotted. Could be a 1.4L TSI? Y@SH The Indian Car Scene 133 30th June 2012 15:34
VW Passat 1.8 TSI Vs Skoda Superb 1.8 TSI ivar1951 The Indian Car Scene 21 14th April 2010 19:19
