Old 2nd June 2016, 19:56   #106
Dr.Naren's Avatar
Thanked: 6,326 Times
Default Re: Above the Ordinary : My Crossover, the Maruti S-Cross
Originally Posted by Sree73 View Post
0W40 is a fully synthetic oil and hence the higher price. Maruti does not recommend fully synthetic oils for their cars.
Maruti recommends fully synthetic 5W40 engine oil for all cars with 1.3 multijet engine. I think for Baleno/S-Cross it's 5W30 though.
It was 5W40 fully synthetic oil for my SX4. Later Maruti sent a circular to dealers saying even mineral oil can be used based on customer demand. Recently my service manager told Maruti is back to fully synthetic oils for all new cars.
Dr.Naren is online now   (1) Thanks Reply With Quote
Old 2nd June 2016, 22:35   #107
Thanked: 13,389 Times
Originally Posted by Suz View Post
Considering that Kalyani NEXA SA is saying they will use the 0W40 oil which with the filter change will cost me around 4300 Rs, do you think its worth it
Originally Posted by Dr.Naren View Post
It was 5W40 fully synthetic oil for my SX4. Recently my service manager told Maruti is back to fully synthetic oils for all new cars.
All Maruti cars come filled with synthetic oil from factory.
Recommended grade for my Swift is actually 5W30 but all ASC's here fill 5W40 which is fully synthetic. So it should be similar for all DDiS200 engines.
Maruti has tied up with Mobil to cater synthetic oil for Maruti petrol and diesel engines at a cheaper rate to have control on ownership costs.
For diesel it is Mobil Super - 5W40 (MGDO) which costs 558 per litre and for petrol engine it is 0W20 (MGO) that costs 450 per litre.
a4anurag is offline   (4) Thanks Reply With Quote
Old 4th June 2016, 12:45   #108
An unexpected update, courtesy - Service campaign!
Since the campaign announced had received 3 calls informing of the parts availability and to do the same at with prior appointment.
Well today had decided to go for the same. Reached the service center at 9:30 and completed the task by 11:00 am
Jobs completed - Service campaign and Smartplay software upgrade for carplay!
Understood from SA the following on the campaign.
1. All cars affected will have the caliper assembly replaced ( rear)
2. The new ones are of higher brake pressure
3. No problem as such with the old ones, a few cases low brake pressure reported (
warning light on)
4. The old parts are couriered back to Maruti Suzuki
Hi Volkman,
The recall was only for the caplier Kit or anything else, asking because a friend who is not in this forum has a SCross and they changed his break pad and also adjusted his suspension, though the car is smooth now but he feels they have done something more than required and charged him too saying there was wear and tear because of his driving condition which he felt might be the case as he drives every weekend from Bangalore to Kerala and has already done close to 8000 kn in 2 months
Last edited by manson : 4th June 2016 at 13:17. Reason: Mod Note: Please quote ONLY the relevant bits of a post. Quoting a full, long post inconveniences our mobile readers. Thanks.
kondath is offline   Reply With Quote
Old 4th June 2016, 17:18   #109
volkman10's Avatar
Thanked: 16,321 Times
Originally Posted by kondath View Post
Hi Volkman,
The recall is only for the rear caliper assembly.
What you have described is the wear pattern on the pads based on the driving conditions.
volkman10 is offline   (1) Thanks Reply With Quote
Old 4th June 2016, 22:48   #110
@volkman : could you elaborate on the update on the Apple CarPlay system. Any major improvements that you notice after the upgrade?
arnath is offline   Reply With Quote
Old 5th June 2016, 09:09   #111
Sree73's Avatar
Thanked: 744 Times
Hi Volkman,
The recall was for the brake caliper kit. But, please note: In the process, if they notice, any other issue to the vehicle, MASS will definitely address that. How a responsible Service personnel can ignore an issue they noticed during the process. Charging / Not charging for the parts depends upon the warranty.
But, replacing the brake pad for wear and tear for 8K KMs is beyond normal circumstances and if that's the case, it should have been covered under warranty.
Sree73 is offline   Reply With Quote
Old 7th June 2016, 21:43   #112
anycatd's Avatar
Thanked: 143 Times
5w30 fully synthetic is not easily available in the market. Maruti must have recommended this to prevent customers from opting outside their service centers. I would liked to try Liqui Moly but its not available in 5w30, would email their distributor to provide the same.
anycatd is offline   Reply With Quote
Old 21st June 2016, 21:16   #113
volkman10's Avatar
Third Service update at 9540 Km
Taken an early service than the normal 10k km as will be outstation for a few weeks and did not risk an overshoot of the km reading.
Appointment fixed at 9:00 am, car delivered back at 1:00 pm.
No any complaints( window vibration when not fully closed still exist) hence the work associated was only to the service checklist.
Nice part was unlike service centers like VW, we are allowed to be with the car and oversee the job being done
Step by Step service work in Pictures,
Mileage is consistent at 20+km/l, Odometer reading at time of service.
Above the Ordinary : My Crossover, the Maruti S-Cross-20160618_082338.jpg
Tyres being removed
Above the Ordinary : My Crossover, the Maruti S-Cross-2a.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2b.jpg
S Cross in air for under body inspection,
Above the Ordinary : My Crossover, the Maruti S-Cross-1.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2c.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2d.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2f.jpg
Light scratch- not surprising due to the road conditions/traffic here,
Above the Ordinary : My Crossover, the Maruti S-Cross-2h.jpg
Engine oil being drained
Above the Ordinary : My Crossover, the Maruti S-Cross-2g.jpg
Tightening of bolts- suspension/shocks
Above the Ordinary : My Crossover, the Maruti S-Cross-2i.jpg
Drain plug - new
Above the Ordinary : My Crossover, the Maruti S-Cross-2j.jpg
Oil Filer replacement
Above the Ordinary : My Crossover, the Maruti S-Cross-2k.jpg
05W30 oil fill, Coolant and wiper wash -topping of fluids
Above the Ordinary : My Crossover, the Maruti S-Cross-2m.jpg
Air filter element - cleaning and replacement
Above the Ordinary : My Crossover, the Maruti S-Cross-2n.jpg
More Nexa cars in queue,
Above the Ordinary : My Crossover, the Maruti S-Cross-2o.jpg
Battery check
Above the Ordinary : My Crossover, the Maruti S-Cross-2p.jpg
Cabin filter removal and replaced with a new element,
Above the Ordinary : My Crossover, the Maruti S-Cross-2s.jpg
Old filter element
Above the Ordinary : My Crossover, the Maruti S-Cross-2t.jpg
Wheel Balancing
Above the Ordinary : My Crossover, the Maruti S-Cross-2q.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2r.jpg
Wheel alignment
Above the Ordinary : My Crossover, the Maruti S-Cross-2u.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2v.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2w.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-2y.jpg
Final wash and drying at Service center
Above the Ordinary : My Crossover, the Maruti S-Cross-050.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-20160618_104813.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-20160618_105508.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-20160618_112429.jpg
Wheel alignment report and Final bill (INR 4843)
A very satisfying 3rd service and great environment to be in with very friendly SA and workers!
Above the Ordinary : My Crossover, the Maruti S-Cross-20160618_133523.jpg
Above the Ordinary : My Crossover, the Maruti S-Cross-20160618_133625.jpg
volkman10 is offline   (4) Thanks Reply With Quote
Old 21st June 2016, 21:20   #114
volkman10's Avatar
Tire inspection after rotation done at service- intact as new,
Above the Ordinary : My Crossover, the Maruti S-Cross-20160621_070717.jpg
The S Cross
Above the Ordinary : My Crossover, the Maruti S-Cross-20160620_070744.jpg
Continues to deliver the amazing FE after~100 km after 3rd Service!
Above the Ordinary : My Crossover, the Maruti S-Cross-20160621_164843.jpg
volkman10 is offline   (5) Thanks Reply With Quote
Old 21st June 2016, 21:32   #115
Vik0728's Avatar
Thanked: 2,181 Times
The S Cross
Attachment 1519988
Woah volkman10, I don't know if its the angle bro, but for a second I thought you have picked up a Brezza now!!
IMHO, one of the best set of rims on S-Cross and arguably on our forum man. The only downer I see is the cleaning bit. So many spokes can be cleaned only with some sort of pressure wash or a cart load of patience if done manually.
Brilliant FE only adds to the experience. Drive safe.
Vik0728 is offline   (1) Thanks Reply With Quote
Old 22nd June 2016, 11:33   #116
volkman10's Avatar
I would put it as, no bugs noticed as of now.
volkman10 is offline   Reply With Quote
Old 22nd June 2016, 11:39   #117
rakesh_r's Avatar
Thanked: 703 Times
Volkman, which brand of engine oil did they use?
PS- Good to see them using a drain bolt. It's a royal pain to unscrew once the head gets damaged. I always used to install a new drain bolt for my old Swift Diesel.
rakesh_r is offline   Reply With Quote
Old 22nd June 2016, 12:17   #118
volkman10's Avatar
Castrol Edge -5W-30
Oil change done at 5k and 10k km.
IMO, now all manufacturers ( seen it at VW) will replace the drain plug when oil is changed.
Old 22nd June 2016, 14:32   #119
GSMINC's Avatar
Thanked: 106 Times
My guess is that your car went to Bimal Maruti Mahadevpura Whitefield Road for service
Am I right..?
GSMINC is offline   Reply With Quote
Old 22nd June 2016, 14:43   #120
volkman10's Avatar
Originally Posted by GSMINC View Post
Am I right..?
I go to the Bimal service center either at old airport road or their Mahadevpura outlet.
Yes, these pics are from the Whitefield service center
Fiat Avventura vs VW Cross Polo vs Toyota Etios Cross vs Ford EcoSport a4anurag Hatchbacks 14 16th July 2015 10:22
CUV Wars: EcoSport vs Avventura vs Cross Polo vs Liva Cross vs Premier Rio devarshi84 What Car? 19 4th December 2014 03:25
No Ordinary Seizure - Only 11 Supercars Brabus E V12 The International Automotive Scene 30 17th July 2013 20:47
From ordinary BHP to Team-BHP bullet-tooth Introduce yourself 8 2nd September 2012 02:05
Diffrence between an ordinary cold air intake and a ram air intake?? Vys De BlUR Technical Stuff 24 1st April 2008 12:59
