Old 23rd February 2008, 17:53   #196
horsepower's Avatar
I have done 15000 kms in my swift Ldi. Maximum I have reached is 160 km/h, did not try to go beyond it. 182 km/h in swift scares me.
horsepower is offline   Reply With Quote
Old 24th February 2008, 01:26   #197
Driving at 182 knph in Indian roads is totally insane. Even in US with very good freeways, the max speed allowed is around 80 mph.
Though modern cars have good power and can reach very high speeds when pushed, we should drive responsibly keeping in mind the safety of the passengers and pedestrians on the raod.
Please drive safely.
prskumar is offline   Reply With Quote
Old 25th February 2008, 12:17   #198
blorebuddy's Avatar
Thanked: 60 Times
Completely agree.
It is quite dangerous to you, your co-passengers and the other people on the road. Indian roads are full of surprises as some one else said in some other forum. Drive safe dude.
blorebuddy is offline   Reply With Quote
Old 25th February 2008, 15:20   #199
DieselFan's Avatar
Thanked: 234 Times
Driving at high speeds >100 kmph is not only unsafe but puts undue stress on most of the car components - Engine, transmission, suspension, Tyres, brakes. These components wear out faster than usual and the FE will drop significantly. Please keep this in mind before racing away your car beyond 100 kmph.
DieselFan is offline   Reply With Quote
Old 25th February 2008, 17:19   #200
Thad E Ginathom's Avatar
Thanked: 8,372 Times
In terms of what a Japanese or European car should be able to take, 100kmph is nothing, not even a motorway cruising speed. In fact 62 MPH is easily attainable on a good 'A' road in UK (limit, if not dual carriageway, 60). Wouldn't worry about the car at all.
Of course, the roads is a different matter. It might be the Swift, it might be the roads, but it surprises me that 60Kmph actually feels quite fast here!
What you say about fuel consumption (sorry, you guys call it fuel efficiency, but I still find it hard to get to grips with that) is correct, though. Higher speeds really drink up the stuff.
Old 26th February 2008, 08:21   #201
DieselFan's Avatar
Thanked: 234 Times
On good roads there shouldn't be much of a worry. If you have potholed roads or roads with sudden speed breakers (Which you usually find in India) that require sudden braking you will put in undue stress on to your car components. The oredr of stress varies with the components tyres/brakes take a huge beating, then suspensions, finally transmission and engine.
Old 26th February 2008, 13:12   #202
I can't argue with your policy to treat a car gently
Old 30th June 2008, 08:06   #203
Gautam Misra's Avatar
Thanked: 23 Times
Guys please help me out.
My SWIFT LDi has run 2500 km and apart from minor scratches there is no problem with it. However, recently I found out that if I apply apply brakes suddenly there is a noise. It's like a low grunt. Is it anything to be really worried about?
Gautam Misra is offline   Reply With Quote
Old 30th June 2008, 15:24   #204
There is a potential problem with the disc brakes.
I hadn't noticed, but mine had been almost worn away in just a couple of thousand km. I forget now if it was just the pads that were replaced, but it was done under warranty, and as disk pads are deffinately a consumable, they wouldn't have done that if it had not been a recognised issue.
Sorry... I never managed to get to grips with what the issue was.
Old 1st July 2008, 00:41   #205
kuttapan's Avatar
Thanked: 12 Times
Discs/Drums are wet. Wait for a few days and if it does not go away, and you are still bothered with the noise, remove the wheels and get the discs cleaned. usually the front discs are the culprit, never had the problems with rear drums.
kuttapan is offline   Reply With Quote
Old 26th December 2008, 19:01   #206
SamuraiJack's Avatar
Thanked: 129 Times
Default LDI-15 KM in City after 1st service
Bull..how did you check the FE?? The only correct method is the tankful to tankful method..
I agree.. I just tested full tank to full tank on my ldi (done first service/clocked 1500 KM) and it returned 15 KM in city driving very slowly and not pushing the car more than 65 on open roads (IRR) without AC.
21 sounds unbeliveable. Can you let us know if you tested full tank to full tank? my car returned 23 KM and the guy had to fill in 1.5lts to get the tank full again.
SamuraiJack is offline   Reply With Quote
Old 27th December 2008, 11:09   #207
KSM-Vtec's Avatar
Thanked: 440 Times
@ Vishnu - now that you have done 20k it would be nice to know what your FE has been on an average?
Also how much has the increase been in the engine sound and vibrations in the car overall...
A 20k Review is due dude...
Originally Posted by vishnugs View Post
Guys, have crossed the 20000 KM mark on my Swift diesel !!!
In my recent trip from Bangalore to Chennai, I was able to clock 182 KMPH, I think it should have been one of the highest with this motor.
Infact, it accelerated pretty fast till 175, from then on, climbing up to 182 was slow, but I took my foot off from the gas pedal at 182 because of a vehicle on my way, otherwise I think it would have clocked one or two more...
Vishnu
KSM-Vtec is offline   Reply With Quote
Swift Diesel (LDi) Ownership review: 2 years and 53000 km later RufRoc Long-Term Ownership Reviews 60 13th April 2011 16:13
Help Choose: City vs Fiesta Diesel vs Verna Diesel vs Swift Diesel aseem Hatchbacks 21 11th October 2009 17:44
Swift Lxi Ownership Review after 1200 KM rupesh_mathur Test-Drives & Initial Ownership Reports 16 27th March 2007 15:08
Why shouldn't I buy Tata Indica (Diesel) for less than 600 KM/Month running skamb Hatchbacks 14 6th August 2005 08:09
