Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Test-Drives & Initial Ownership Reports
Test-Drives & Initial Ownership Reports First hand enthusiast reviews of test-driving and owning (initial stages) an Indian car
Closed Thread
Thread Tools
Old 18th April 2007, 12:46   #91 (permalink)
I am commented on a topic where most of my knowledge is based on what I have heard/read and a lot of it is based on discussion with RRNSS on phone. Anyway I will post for benefit of others as I dont know if he has time to clarify. The real guru will obviously express it better.
There is a lot of difference between 4WD and diff lock. In standard 4wd vehicles (like all vehicles such as jeep, Sumo/Bolero/Safari), power gets distributed to 4 wheels in such a way that the wheel with least resistance gets all the power. This is useless distribution when that wheel is stuck and cannot provide traction. DL allows you to redistribute it manually to wheel that can provide traction and not waste it on wheel that is spinning free.
Two wheel is even worse because it only provides power to 2 wheels, not 4. That means the range of situations where you are stuck are higher because all you need is the wheels that are driven to be stuck and your entire vehicle is stuck. With 4wd without DL that range of stuck-able situations is narrower. With 4wd and DL it is even narrower, though NOT zero.
ggkg is offline
Old 18th April 2007, 12:54   #92 (permalink)
Samurai's Avatar
Red face
I am still unable to get the price quote for a Gama with BS-III, PS, AC and 4WD. The local dealership is saying that this configuration is only against order, so they don't know the price. They are still awaiting reply from the factory.
Regarding diff locks, the dealership sales manager very confidently replied that the 4wd version does come with differential locks.
__________________
Samurai
My CJ340 - Highway Cruiser and Mountain Goat.
Samurai is offline
Old 18th April 2007, 15:32   #93 (permalink)
The dealership in tvpm told that the price for the ac, ps model is 5.8 lacs.
swathyd is offline
Old 18th April 2007, 15:41   #94 (permalink)
Samurai's Avatar
That's BS-III? Can they still sell BS-II in tvpm?
__________________
Samurai
Samurai is offline
Old 18th April 2007, 15:44   #95 (permalink)
DL locks the differential and provides the same power the wheels. It does not give power to wheel in grip. That would be AWD systems.
srishiva is offline
Old 18th April 2007, 18:46   #96 (permalink)
Alfa_Kilo's Avatar
A 4x4 with a traditional transfer case and diff. locks at both the axles (a.k.a. Gurkha/Judo) distributes torque in such a manner that each wheel gets as much as it can do justice to, and they generally spin only when all four can't cope with the situation. The major difference between traditional 4x4s and more sophisticated systems with a central differential (in place of a transfer case) and traction control (so called AWD) is that all the wheels turn at the same speed in the case of the former.
Alfa_Kilo is offline
Old 19th April 2007, 01:10   #97 (permalink)
I apologize for my poor sentence construction. The part about the seats in my post are misleading.
The original seats that come in the gamma/judo 4x4 is absolute nonsense. Atleast the front bucket seats. When you drive down a steep decline, some thing gets unlocked and the entire driver seat slips forward pushing you against the steering wheel.
If you try to push your back against the back rest, lift your rear end up and remove your wallet from your back pocket while sitting in the seat, the seat welding simply brakes. In one sentence the company seats are phenominally bad and I am not talking about ergonomics etc. It literally breaks.
The seats in my car are made in coimbatore. That includes the frames, the springs the cushion and the seats have also been slightly repositioned.
It cost me 30000 rupees including sound proofing.
There is no basic difference between gamma and judo. except for the engine. The judo came with the Indirect injection OM616 or it's TC variant FT2400. The Gamma used to come as the base model with the DI TD2650 engine. ( similar to bolero DI and XD3PU) .
Because of emissions and fuel effeciency concerns, Force is slowly phasing out the IDI OM616 and making the DI TD2650 its standard. (72 bhp and almost 20kgm of torque).
The same gamma that used to come with the 45 HP TD2650 engine is given with A/C and P/S as gamma deluxe with teh TD2650 FTI engine with 72 BHP( which used to be Judo DLX only with the FT2400 engine ). The gamma deluxe comes with BSII/BSIII turbo charged intercooled engine.
As for water proofing, in any simple robust diesel engine you can go into the water till your air filter is above the water level. Both the gamma and Judo can ford depths of about 3 feet. So there is no basic difference.
After that even if you waterproof your air intake , your electronic fuel pump (BSIII) will malfunction under water. So the arguement that JUDO is more water proof than GAMMA or vice versa is a moot point.
Gamma comes with diff locks if you ask for it , same a judo.
Think of Gamma Deluxe 4x4 as a renamed JUDO 4x4 DLX , only the engine is the TD2650 FTI instead of FT2400. Thats it. The tires, the brakes, the rim (16 inch) , the ground clearance, dimensions, steering, linkages, suspension are all identical.
Now about the differential locks. They are marvelous. If you go to YouTube - Broadcast Yourself. and search for rrnsss , you will see a video of me using the diff locks at the nagerhole jungle. But you can also go to My SPGM gallery and see how I got stuck even with diff locks because of my own stupidity.
I owned a Bolero GLX 4x4 for about an year. At the risk of offending bolero owners, I would say that comparing a judo to a bolero is like comparing a true soldier of the Indian army who is posted in siachen to a salman khan who plays a solder in a movie about siachen.
The next time you see a bolero 4x4, just perform this experiment. Walk over to the front end of the car to the right or left weel, bend down and see the clearance between the front leaf spring and the rubber stopper that stops it. It is about 1/2 and inch. Yes, it is true. So every time you hit a pot hole with a bolero 4x4 the suspension bottoms out and you will feel like some one is punching you under your chin. It used to get so bad during my drives, I used to take my hands off the steering wheel. All that shock is transfered to the gear box because the Transfer case is mounted on the gear box and it damages the gear box. I lost the synchros in my gear box by 14000Kms.
check out these pictures of how easy it is to get stuck in a bolero
My SPGM Picture Gallery
The articulation of the axles is very limited and the wheels loose traction very quickly.
Bolero is a very good car in the 2wd version. Sadly M&M just jury-rigged a front axle and differential and called it a 4wd with out any real engineering.
If you want to learn the main advantages of a diff lock check out the page What is so great about differential locks?
Thanks for entertaing my posts
Ram
rrnsss is offline
Old 19th April 2007, 07:52   #98 (permalink)
Mpower's Avatar
OK, does the Gama have a transfer case with a 4x4 low gear. If so what is the ratio?
Also any comparison of approach angle, departure angle and breakover angle.
__________________
The difference between the men and the boys....................is the speed of their toys.
Mpower is offline
Old 19th April 2007, 08:06   #99 (permalink)
headers's Avatar
Guys, I am a little surprised. Everybody is suggesting buy anything else, but nobody is telling what's wrong with Trax Gama or Force motors.
Do Trax vehicles have a bad rap when it comes to reliability, A.S.S or spares cost? Please let's focus on that.
Yes..very much and they are prone to rust easily!! The quality of steel used is BAD!!
It does have a good engine gearbox combo though!
__________________
Performance...Redefined
headers is offline
Old 19th April 2007, 08:39   #100 (permalink)
spadival's Avatar
You'll probably need to invest atleast Rs 60k on top of the on road price to make a decent family vehicle out of it .. Seats + Alloy wheels + paint job etc.
Paint job may not be necessary, but I doubt if the ugly stickers can be removed easily without damaging the paint.
spadival is offline
Old 19th April 2007, 09:21   #101 (permalink)
May be Normal citizen likes Salman Playing the role [ ref: bolero once rated as best selling UV in India] rather than not selling soldier on 4X4.
chanapli is offline
Old 19th April 2007, 09:29   #102 (permalink)
Not really. The vehicles are now electro-phoretically painted like the Traveller and they are not as corrosion prone as before. My advice would be to buy a Force vehicle only in an area that has quite a few of them. Spares can be a pain, specially body and tinker parts like door handles, window winding mechanism, grills etc.
I have had only good experiences on my Tempo Traveller and surprisingly minimal mechanical breakdowns eeven after 1.5 lakh kms.
__________________
Live Life King Size!
jyobeb is offline
Old 19th April 2007, 11:10   #103 (permalink)
Originally Posted by Mpower View Post
OK, does the Gama have a transfer case with a 4x4 low geat. If so what is the ratio?
angle of approach = 40 deg
angle of departure = 35 deg
as per the force motors promotional vid
__________________
For all your days prepare
And meet them ever alike
When you are the anvil bear,
When you are the hammer, strike.
hell_rider is offline
Old 20th April 2007, 14:29   #104 (permalink)
Samurai's Avatar
Got an update from the local dealer.
The Bad News
Gama BSIII with PS, AC and 4WD is not available, they don't even have an order code for it. You can get BSIII with PS and AC, but not 4WD. You also get BSII with 4WD, but not AC & PS. Also, the Gama 4WD doesn't come with differential locks.
The Good News
Now the Gurkha is back in commerical production, it is available in both SWB and LWB chassis, both are called Gurkha now. The first ones of the assembly are supposed to roll out within 15-30 days. This is a fully loaded one with AC,PS,BS-III and diff locks. He told me to wait for my cousin's Gurkha delivery (delivered at same dealership) and then check it out.
__________________
Samurai
Samurai is offline
Old 20th April 2007, 14:32   #105 (permalink)
himanshugoswami's Avatar
The Bad News
The Good News
Wow! You really are convinced about the Gama/Gurkha, aren't you. Good to see such a single minded approach. All the best!
Do keep us posted when your cousin's Gurkha arrives as well as about the mods he does on it.
__________________
I asked Mom if I was a gifted child...she said they certainly wouldn't have paid for me.- Calvin
himanshugoswami is offline
Closed Thread
Thread Tools
Force Gama - A few questions H3LIOS SUVs, MUVs & 4x4s 56 4th July 2009 14:54
Trax Gurkha Test Drive on Horrible roads and Off-road too Samurai 4x4 Vehicles 245 3rd July 2009 09:33
Force Trax Toofan Test Drive H3LIOS Test-Drives & Initial Ownership Reports 18 14th February 2009 09:37
Force Tempo Traveller Test drive vid6639 Test-Drives & Initial Ownership Reports 29 3rd February 2009 19:16
Gifted!Force GAMA E-III - Internal modifications - need Advice. Alton Modifications & Accessories 10 2nd June 2008 21:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552
