Old 25th October 2007, 14:45   #931
VBV
Originally Posted by mtnrajdeep View Post
In adition, the manual also advises against running in higher gears at low speeds, though I've noticed that the car pulls even from around 600 rpm in 5th...
AFAIK, Driving at higher gears in lower speeds/rpms is what is lugging a car.
VBV
VBV is offline   Reply With Quote
Old 25th October 2007, 15:36   #932
mtnrajdeep's Avatar
Thanked: 101 Times
VBV
I didnt quite understand what this means..
mtnrajdeep is offline   Reply With Quote
Old 25th October 2007, 15:43   #933
Akshay1234's Avatar
Thanked: 7,243 Times
it means if you drive in 5th gear at 40 or so when the rpm is around 1000 or so you are putting excess strain on the engine. that is lugging.
Old 25th October 2007, 17:07   #934
Venkatesh.C's Avatar
Thanked: 30 Times
So it looks having a speed limit is not just the only way of getting a good run-in.VBV
Agreed. Its about the RPMs. I was coz 100 would take the car about 2500 rpm which is the unofficial upper limit . At the end of the day i guess doing it one off time wont hurt. Its only when we do this repeatedly the engine gets thrashed.
Mating is a, has to be a gentle process anywhichwhere until things settle down ...
Venkatesh.C is offline   Reply With Quote
Old 25th October 2007, 18:07   #935
mtnrajdeep's Avatar
Thanked: 101 Times
Originally Posted by kaykay View Post
  1. Reverse gear sometimes refuses to engage. Gear shift is still notchy specially 1st gear.
Though my car has done only about 250 km till now, I am facing this problem too!
Old 25th October 2007, 18:36   #936
sathya_nars's Avatar
Thanked: 52 Times
Regarding reverse gear not engaging sometimes, I am not noticing it nowadays. I guess if you keep clutch **fully** pressed you shouldn't notice. I use reverse gear extensively while taking my car out and getting in every day, I hardly notice it nowadays.
sathya_nars is offline   Reply With Quote
Old 25th October 2007, 19:09   #937
Thanked: 30 Times
Reverse gear 'problem' is a design / known issue and its coz its not a synchromesh gear. When facing a problem engaging the reverse just engage 2nd / 3rd and then try engaging the reverse it always works. Its an easier alternative to pumping the clutch
Old 25th October 2007, 19:09   #938
deuce-deuce's Avatar
Hey I don't know if anyone has noticed this but according to suzuki uk website the ground clearance of the SX4 hatch is 205 mm-Identical to the SX4 sedan sold in india,but the clearance of the SX4 sport sedan in the U.S. has a clearance of 160 mm.
I don't know why Maruti hasn't changed the suspension settings to lower the car a little in India,considering the Hatch has some offroading pretensions because of the 4 wheel drive and the clearance is justified in that application.
IMO,lowering the car by 30 mm or even 20 mm would greatly improve it's stance and handling without affecting it's ability to sail over bad roads too much.
deuce-deuce is offline   Reply With Quote
Old 25th October 2007, 19:20   #939
Congrats sathya, thats pretty cool
ravi23 is offline   Reply With Quote
Old 25th October 2007, 19:55   #940
guys maruti has given all the bells and whistels in this car but maruti will remain maruti, i.e. lack of refinement, poor quality interiors and fit and finish, stiff suspension. SX4 is a good car for its price in terms of features but sill doesnt have that upmarket/ premium feel. the build quality lacks, the gear shift is still notchy.
sanchits is offline   Reply With Quote
Old 25th October 2007, 19:59   #941
i own a swift zxi and civic, swift has the same gear problems but even honda civic has a non-synchromesh reverse gear and not even once i have faced problem engaging any gear. there is a flaw with swift/sx4 gears. i also drive my uncle's alto, no problem in engaging the reverse gear, then why so many problems in SX4/swift gears.
Old 25th October 2007, 22:28   #942
Thanked: 30 Times
I agree that Alto , 800 do not have this problem. But as a fundamental concept Non synchro gears do not engage sometimes. and yes it occurs more frequently than it should in the Swift/SX4.. maybe someone more knowledgeable can answer why..
Let me start a new thread with your views and ask the junta .
Old 26th October 2007, 11:58   #943
saabasheer's Avatar
Thanked: 12 Times
Cool
Before SX4 i had Honda city and i enjoyed the gearshifts. But in SX4 initially i had some problems, but after maruthi's clutch replacement and running 2000 kms the things are completely changed. Now i am having no issues in shifting gears and feel butter smoothness now.
No reverse gear Problem at all now.
saabasheer is offline   Reply With Quote
Old 26th October 2007, 12:44   #944
iTNerd's Avatar
Thanked: 505 Times
Even me.. though my car was not one of the initial lots with the clutch problem..but initially, the gear (especially reverse) was not smooth and found in situtation where the gear didn't engaged properly..That's a different story now with 2600 kms done .. its smooth..
iTNerd is offline   Reply With Quote
Old 26th October 2007, 17:43   #945
Thanked: 37 Times
Default Gear shift! Its very smooth now
Originally Posted by omishra View Post
No that is not the case but it is very tight for first 300 kms. Really hard that I felt pain in left hand but improved with time and now very very smooth. Just push it holding by fingures.
I already mentioned that its very smooth.
omishra is offline   Reply With Quote
Took the delivery of FORTUNER & Accent!!! caroholic1 Test-Drives & Initial Ownership Reports 35 31st August 2009 23:38
TATA Safari GX Delivery period/should I chuck it? (EDIT: Now post delivery issues!) vivek.singh.73 The Indian Car Scene 108 27th July 2009 22:09
i10 took delivery and upgraded with new tyres and alloys jango Tyre & Alloy wheel Section 60 17th April 2009 18:35
Took delivery of my Verna CRDi and enjoying it, 300 km report diffsoft Test-Drives & Initial Ownership Reports 25 5th March 2008 23:10
sx4 delivery issues sathya_nars Indian Car Dealerships 32 25th September 2007 12:59
