Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Test-Drives & Initial Ownership Reports
Test-Drives & Initial Ownership Reports What New Indian Car Test Drive have you had the privilege of? Want to post a review of your fresh new car?
Thread Tools
Old 25th July 2007, 15:12   #16 (permalink)
VBV
One more thing:
Try to go for a TD with all kind of turns. my first TD of SX4 was a short one I went around Lavelle road in Bangalore. It so happened I had turned left throughout. Now that eclipsed the right side blind spot during TD.
A few things I try:
- Go at higher speeds and quickly turn the steering back and forth; and observe the response time for wheels.
- Take a longish curve and see if you need to correct the steering after the initial turn. It will tell you whether it has a oversteer or an understeer.
- Try the ergonomics test:
5tests-web
VBV is offline   Reply With Quote
Old 25th July 2007, 15:22   #17 (permalink)
I think, few other things to check:
1. Sit in the rear-seat & ask someone else to drive the car. Experience the rear seat feeling, just for the sake of your family members.
2. Check how easy is it to get-in & get-out of the car, both from driver seat & from rear-seat.
3. With the driver seat adjusted to your comfortable driving position, check the leg room at the rear. This is very important, as otherwise, you will hear the backseat people asking you "to move little forward". This will definitely affect your driving comfort.
Indian is offline   Reply With Quote
Old 25th July 2007, 15:26   #18 (permalink)
rks
rks's Avatar
I agree, tyre pressures should be set 1-2 psi higher when tyres are hot. What I am concerned about is that the dealer may have neglected tyre pressures altogether and may not have checked for a long time. So it would be wise to take the pains to check tyre pressures before test-driving.
Old 25th July 2007, 16:06   #19 (permalink)
vid6639's Avatar
Check air in the tyres during a test drive.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 25th July 2007, 16:14   #20 (permalink)
rks
rks's Avatar
If you are going to do some of the things listed like throwing the car into corners, check the ride on bad roads, check the steering/handling at high speeds and so on, tyre pressures should be correctly set; otherwise you may get a wrong impression.
Old 5th August 2007, 10:28   #21 (permalink)
thefreak's Avatar
Another thing that people may like to do is to schedule test drives of several cars on the same day. I know that this may mean that the test drives become a full day phenomena but if you have decided on your cars well and have short listed say 3-4 cars that you might want to test it is best to go in for the test drive on the same day. It will allow you to better compare the cars. Comparing something that you have test driven today with something that you test drove a week ago may not produce accurate results. "Telescoping effect" in the management jargon.
thefreak is offline   Reply With Quote
Old 5th August 2007, 11:10   #22 (permalink)
thefreak's Avatar
Wow! two things i posted (repititive) but none of them show! I wonder why..
Note from Mod : Please do take the time to read the announcements section. Especially the rules. Also your answer is in this thread
Old 5th August 2007, 21:05   #23 (permalink)
Superb thread, I wish this was there around when I made my choice about a month and half back.
Originally Posted by Eddy View Post
Is it possible that the dealers tune the demo cars for maximum performance caring very little about the fuel efficiency ? This way the car "seems" pwerful and responsive during the TD at the cost of FE and the driver is impressed.
I dont know if this happens but I might be tempted to do this if I am the dealer . If it does happen, any way that this can be detected during TD ?
Telling you from my own experience. I bought the AVEO UVA in June 07. The TD car had a butter smooth gear shift. But in the one I own, the gear shift is notchy.
When I posed this Q to fellow Tbhp-ians, they said, there are 2 reasons possible:
1. Since, the TD vehicle had clocked over 6K kms, and so the shift became smoother over use
2. My car has clocked only 500km and after the service it'll smoothen out.
Not sure whats the actual reason though!
- EMD
EatMyDust is offline   Reply With Quote
Old 6th August 2007, 18:46   #24 (permalink)
sathya_nars's Avatar
@MODS: Why not park this thread? Or are you planning to come up with article clubbing all replies?
While I was newbie to TDs, I really felt such tips would help me make my search better.
sathya_nars is offline   Reply With Quote
Old 7th August 2007, 14:46   #25 (permalink)
diabloo's Avatar
Infractions: 0/1 (4)
LHD Controls VS RHD Controls:
Cars from Ford, GM have indicators on left hand side. But cars from Maruti, Honda, Toyota, Hyundai have it on right hand side. Adjust from one to another takes very little time. While TDing, be aware of this. Dont reject the car based on this criteria alone.
diabloo is offline   Reply With Quote
Old 8th August 2007, 04:03   #26 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Great thread sathya_nars,
I have parked it. If we do decide to compile either an article or a template using this information we will replace this with that when the time comes, and give all the contributors due credit.
Thanks,
R
Rehaan is online now   Reply With Quote
Old 14th August 2007, 22:21   #27 (permalink)
I think that's a good point - sometimes, the test drive cars may deceive or may not reflect the true good potential. When I got a toyota corolla for test drive, the car they brought first was so lousy - hard cluch, rumbling brake, etc..- when I gave my dissatisfaction, he brought a brand new car the next day, that was far better...In case of SX4, the test drive car had hard gear shifts & poor stereo - but the new one that I bought, both were quite good..l guess test drive plus some judgement helps....
- EMD
nssrini is offline   Reply With Quote
Old 23rd August 2007, 22:29   #28 (permalink)
skandyhere's Avatar
here's a queer query that might look out of place, yet i place it here.
i wonder how everyone here keeps test driving every new model all the time.
supposing there are dealers of 5 different manufacturers in the city, you can go for test drive visits only ONCE to each of these showrooms.
the second time you visit the same showroom to test drive a model just introduced, and you are obviously unwelcome there. how can one justify test-driving every new entrant without the intention of buying it unless you're close to the manager or someone like that?
well???
__________________
Sometimes you're the windshield, sometimes you're the bug...
skandyhere is offline   Reply With Quote
Old 24th August 2007, 10:38   #29 (permalink)
You can say that you are yet to check various controls of car and previous test drive didn't allow you to do that since that was very short trip.
I TDd many cars many times with same dealer, he never questioned me.
BTW, you can't decide just with one time TD whether to buy it or not, so even if they decline to TD many times (they won't do it anyway), go to other dealers and try out.
End of the day, you should be convinced enough to buy it or not, forwhich you have to TD many times.
Old 24th August 2007, 11:40   #30 (permalink)
CrAzY dRiVeR's Avatar
Thats not the case everytime.
Am 20 year old, and still in college. Some showroom guys dont seem to appreciate the fact that college kids are walking around for TDs.
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
CrAzY dRiVeR is online now   Reply With Quote
Thread Tools
Why cant test-drive cars be better? GTO The Indian Car Scene!! 34 26th June 2008 23:46
Hyundai Verna(VGT) test drive(torture drive) tsk1979 Test-Drives & Initial Ownership Reports 65 31st October 2006 08:45
Test Drive cars Floyd de Souza The Indian Car Scene!! 31 10th February 2006 18:42
Looking for Hyundai dealer with crdi cars for test drive tsk1979 Indian Car Dealerships 0 6th June 2005 10:27
Test Drive of the 350Z rgowani Super-Cars & Imports in India 67 13th June 2004 12:55
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
