| Test-Drives & Initial Ownership Reports What New Indian Car Test Drive have you had the privilege of? Want to post a review of your fresh new car? |
| | Thread Tools |
| | #106 (permalink) |
| BHPian Join Date: Oct 2007 Location: Blore
| I found this info in the FAQ section of Hyundai India website, which I had read long back. Most of the times, it is the banking of the roads which makes you feel the wheels are out of alignment. Make sure you use the most flat surface to test. My car drifts to the left or to the right when I let go of the steering wheel on a straight and level road ? First, check the air pressure in all your tyres, then try driving it again. If your car drifts to the right in the right lane and to the left in the left lane, it is probably normal. Most roads are banked to allow for water runoff. Make sure both front tyres are the same size, type and brand. If not, take both front tyres and switch them side-to-side. If the car now drifts in the opposite direction, you've found your problem. If the problem is still there, you should have the wheel alignment checked. |
| | #107 (permalink) |
| BHPian Join Date: May 2006 Location: Bangalore
| I had the same problem in my old car. The car was pulling to right and the steering wheel looked not centered. I did the wheel alignment and the problem is gone, steering also became straight. Also when new tires are added or alignment done, it takes like 500KMs to get the tires settle. |
| | #108 (permalink) | |
| Senior - BHPian | Quote:
I find that hard to believe and how many kms you traveled since then?
__________________ [b][i]The nail that sticks out gets hammered !!! | |
| | #109 (permalink) |
| Senior - BHPian | Sorry, it was a typo. The balancing was done in Aug 2006, but not in the subsequent service in 2007, perhaps because I had not covered more than 5 k or 6 k kms in the intervening period.
__________________ ------------------------------------- Ford Fiesta 1.6 sxi 2007 WagonR LXi 2001 |
| | #110 (permalink) | |
| | #112 (permalink) | |
| Distinguished - BHPian ![]() Join Date: Feb 2004 Location: Mumbai
| Quote:
1.) Take your wagon R on a concrete road and leave your steering. See if the car pulls to the right when it goes over the joints on the road. My SX4 does that and so did the demo SX4 of the showroom. 2.) Stop the car on the road. Slot it into first and let the car inch ahead very slowly and then stop again. Keep your hands off the steering while you do this. Imagine your in a traffic jam and you have to keep the car in first, leave the clutch, inch ahead and stop again. See if the steering automatically turns to the right. The car should also pull to the right at that moment. Try and ensure that tyre pressure is at manufacturer's recommended level.
__________________ Some people drive cars. I drive the Palio. | |
| | #113 (permalink) |
| I reduced tyre pressure to 28psi front and rear against Maruti's recommended 32psi and the car has started going straight much better and longer then it used to! ![]()
__________________ Some people drive cars. I drive the Palio. Last edited by amit : 5th February 2008 at 12:07. |
| | #114 (permalink) |
| BHPian Join Date: Jan 2006 Location: Mumbai
| Was trying to call you last evening at around 8.30 - 9 pm or so. Could'nt get through somehow. Anyways, the reason for calling up was that I was driving my friend's Swift D and testing it for any of the symptoms that your SX4 displays. Have to say buddy, there was no problem at all. I left both my hands and started driving from a standstill, the car kept tracking straight. But it does'nt somehow give you the confidence to just leave the steering for long. You have to keep correcting the steering since even minor undulations on the road affect steering position considerably. I cannot comment about what tyre pressure though.
__________________ Possession:Palio1.6 S10 Obsession:FIAT Stilo 2.4 Abarth,Grande Punto,FIAT Bravo,Alfa Romeo 147 GTA,Alfa BRERA...all things Italian |
| | #115 (permalink) |
| BHPian | What is the ratio of the car pulling below and above 40 kmph? Is is equal or does it pull more below 40 kmph . Ideally I was thinking that since EPS cuts off after 40 ( correct me if I am wrong) the car should pull less as the assistance is cut off and in turn so would be the sensivity of the steering input to road imperfections |
| | #116 (permalink) | ||
| Quote:
By the way, the Maruti service engineer also got the alignment done on my car when it was at S.K.Wheels and they did find some settings awry but then the car has done about 6500kms so I wouldn't pin down the pulling to alignment. Still, I have to say, the car feels much better to drive after the alignment was done. The reduction of air pressure to 28psi only helped it more. But I wonder why the car drives better with air pressure lower then manufacturer recommended level?
__________________ Some people drive cars. I drive the Palio. | ||
| | #120 (permalink) | |
| BHPian Join Date: May 2007 Location: Bangalore
| Quote:
There has been another SX4 delivered with a bad alignment problem in Bangalore. Hopefully they'll atleast resolve the issue sooner. Looks like this is an issue with delivery. VBV | |
« Getz Prime 1.5 CRDi - Bright Silver 400kms Report & 8700kms 2nd Service UPDATE
Booked my Palio 1.3 MJD Today! EDIT: Got delivery now »
| Thread Tools | |
Similar Threads | ||||
| Maruti SX4 ZXi - EDIT: Updated for 9000 Kms | sathya_nars | Long-Term Ownership Reviews | 90 | 21st July 2008 10:57 |
| 1100 KM report SX4 ZXI | rajneeesh | Test-Drives & Initial Ownership Reports | 32 | 12th July 2008 16:10 |
| SX4 Zxi 10,000 KM Report | randomgyan | Long-Term Ownership Reviews | 37 | 30th April 2008 10:01 |
| Suzuki SX4 1.6 ZXI Test Drive Report | kunal1983 | Test-Drives & Initial Ownership Reports | 428 | 14th January 2008 00:31 |
| Maruti SX4 Zxi - 2200 Kms report | sathya_nars | Long-Term Ownership Reviews | 411 | 10th October 2007 12:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
