Old 3rd July 2008, 15:59   #211
Thanked: 426 Times
wat I noticed is when I start from stand Still the rpm drops a little bit and then rises. This results in a little jerk. Is this normal or it needs to be addressed.
I think Its the problem with the right proportaion of clutch and accelerator being released, will need some more practice to get used to it. Wat do u think??
I am having this same problem with my car and S.K.Maruti have told me that they need to replace the front axles and engine mountings as per Maruti's circular. This is definately not a problem of sychronisation between clutch and accelarator.
amit is offline   Reply With Quote
Old 4th July 2008, 14:54   #212
Thanked: 25 Times
Thanks Amit, skbharat and OMishra.
My car is very new.just got it 1 month back.do u think it also requires the front axles and engine mountings changed.
Wat exactly shud I ask Maruti dealers so that they get this thing rectified.
Have already told Rana Motors Guys that I am feeling vibrations when car is moved from standstill/1st gear. They have called me tomorrow (Saturday) for checking the problem.
Is there anything else I need to tell Rana Guys????
W@nnaR@ce is offline   Reply With Quote
Old 4th July 2008, 23:20   #213
Thanked: 426 Times
Tell your service guys that you want the front axles and engine mountings changed as per Maruti's circular to solve this problem. Make sure you say that there is a circular from Maruti about this issue so they know that you are an informed customer.
Old 4th July 2008, 23:30   #214
hi amit . will changing the front axles and engine mounts solve the problem of shuddering sound while engaging the car in 1st gear ?
man_1 is offline   Reply With Quote
Old 5th July 2008, 10:16   #215
Thanked: 426 Times
Since there is a circular from Maruti about this, it should solve the problem. The problem in my car is not yet solved since S.K.Maruti didn't have the redesigned axles and mountings in stock. They asked me to wait for about 10-12 days till they get the new parts in stock with them.
If the axles and mountings don't solve the problem then, I guess, you can ask the dealer to check the throttle body as per the reports of other SX4 owners here.
Old 4th August 2008, 18:55   #216
Thanked: 426 Times
On Thursday, I was driving to work and the windscreen cracked! The crack has gotten bigger in these few days. Maruti toll free tells me the part is covered under warranty if it's a manufacturing defect. This will be decided by the service workshop. Have a 9.45 appointment at S.K.Wheels tomorrow for the same.
Meanwhile, S.K. told me that my axles and mountings have still not come. The order for my car was specifically placed on July 5 but the parts are still awaited. Will call Ratan tomorrow for the same.
Old 4th August 2008, 22:34   #217
Eddy's Avatar
Thanked: 5,159 Times
Windscreen cracked. I think they might avoid covering it under warranty by saying that it was a pebble hit or something.
Eddy is offline   Reply With Quote
Old 5th August 2008, 11:50   #218
vnabhi's Avatar
Thanked: 1,343 Times
Yeah, it could not have cracked on its own, unless you parked your car in the hot sun, with the widows rolled up all the way.
Anyways, I am sorry that it happened to your car.
Old 5th August 2008, 13:11   #219
Thanked: 426 Times
Just back from S.K.Wheels. Service advisor refused to acknowledge it as manufacturing defect, referred it to the service manage who said the same thing. I insisted it was a defect and no stone hit the windscreen. Service manage calls the Maruti engineer who says the replacement will be done under warranty. Car has been called back for the replacement on Monday.
Maruti-Suzuki SX4 Zxi: Running Report-050808_0913.jpg
Maruti-Suzuki SX4 Zxi: Running Report-050808_0912.jpg
Old 5th August 2008, 14:40   #220
tsk1979's Avatar
Thanked: 16,459 Times
This is good on the part of Maruti to acknowledge it as a manufacturing defect.
Old 5th August 2008, 16:14   #221
Eddy's Avatar
+1.
Thats great. And that too without much badgering. Hope the other issues are sorted out too.
Old 7th August 2008, 11:43   #222
Thanked: 426 Times
I wouldn't say it happened without much badgering. There was badgering that happened but definately less then what I would have to do with some other brand. Let's see how things go on Monday. I also asked them about the engine mountings and axles and I was told they would follow it up with Maruti. It's been one month since the order for the redesigned mountings and axles was placed. Wonder whats going on.
Old 18th August 2008, 12:11   #223
My windshield also has a crack, it started from top so I dont think it is from a pebble. Is there any issue with windshields, a manufacturing defect or car bady is transferring stress on glass?
strips007 is offline   Reply With Quote
Old 19th August 2008, 17:04   #224
Thanked: 31 Times
How old your car is? Mine is just 2 months old and till now no cracks on windshield i check 5 mins back.. is it because it is standing in direct sunlight or as said transferring stress on glass. Is there any circular on the same
aka_iitd is offline   Reply With Quote
Old 20th August 2008, 23:44   #225
Guess cracking of the windshield has something to do with the rain and putting on the airconditioning...Around 2 years back, a friend of mine and I were driving in his new Accent. All of a sudden we noticed a crack on the windshield and within seconds it started spreading in circular shape. We took it to Hyundai workshop who refused to do anything. We contacted the company and they sent us to a different dealership and the windshield was reaplaced under warranty.
Moral of the story, this being the monsoon season, may be there is a corelation between rain and windshield cracking while the a/c is put on. Two - defects like these need to be taken to the company for rectification
iMakk is offline   Reply With Quote
Azure Grey Maruti Suzuki SX4 ZXi (1.6 VVT) comes home!! Saanil Test-Drives & Initial Ownership Reports 37 2nd February 2014 13:09
Swift to SX4 - Booking a Black SX4 Zxi - Some queries on Pg3 joy_swift Sedans 67 28th August 2009 16:08
Suzuki SX4 1.6 ZXI Test Drive Report kunal1983 Test-Drives & Initial Ownership Reports 428 14th January 2008 01:31
Maruti SX4 Zxi - 2200 Kms report sathya_nars Long-Term Ownership Reviews 411 10th October 2007 12:24
