Old 17th October 2008, 21:39   #271
Originally Posted by gopinathann View Post
Yesterday my front right tyre got burst when I got over a sharp big stone on the manhole, however I was able to steer the vehicle without any problem and park the vehicle to the left and replaced the tyre. Today I went to MSM Chennai and they say that the tyre have to be changed since the cut was on the side wall.
Hi gopinathann,
Even i had a puncture on the side wall on my rear tyre but i had no issues till date after fixing it. I have run more than 10,000Kms after that and so far so good. Even i have been to MSM and they asked me surprisingly how the tyre did not loose pressure. Before meeting them i never know that the tyre might have to be changed if it has a sidewall puncture. Better try to fix it....if it is not working then you go for the tyre change.
DineshKanna is offline   Reply With Quote
Old 17th October 2008, 22:36   #272
gopinathann's Avatar
Thanked: 20 Times
I asked them to fix it to use it for emergency alone , but still they couldnt fix it
Originally Posted by DineshKanna View Post
Hi gopinathann,
gopinathann is offline   Reply With Quote
Old 18th October 2008, 11:05   #273
Thanked: 31 Times
The burst tyre cannot be used even as a spare.
I don't want to go for JK because of more noise, If I change to some other in the front the tyre noise can be minimized.
Gopi you said your SX4 had JK tyres but my SX4 sports bridgestone when i took the delivery
How come the difference in brand for stock tyres!!
Can they change the brand without telling the owner
aka_iitd is offline   Reply With Quote
Old 18th October 2008, 11:08   #274
DieselFan's Avatar
Thanked: 234 Times
JK tyres and bridgestone are two brands maruti puts into their cars. There is no hard and fast rule which one they use when.
DieselFan is offline   Reply With Quote
Old 18th October 2008, 11:11   #275
Thanked: 31 Times
I had the same problem initially and the belt was fixed in 1st service, again I got in 1 months time. Again they fixed it, now I don't have this issue now and the car has clocked 10000+ km now.
Gopi which belt they fix it to remove the chrrrrr sound. My car service is due
Old 18th October 2008, 11:12   #276
Thanked: 31 Times
But as per gopi
JK Tyre price - 4800
Michelin - 8700
Bridgestone - 8800
Bridgestone is almost double then JK then how maruti manages
Is it possibel to give a choice of tyres while booking also
Old 18th October 2008, 12:16   #277
Thanked: 426 Times
@ gopinathann
I feel it's best if you change all your 4 tyres. No point changing 2 tyres now and 2 later because you will always have tyres that have worn out in different degrees. Best results would be with all 4 tyres changed at the same time so they wear out evenly.
I'd say go for Michelin. I have them on my Palio and there is a world of difference between the stock Bridgestones and the Michelins. The ride and noise was dramatically transformed on my Palio. The quietness, sometimes, is eerie . I am a Michelin buyer for life. They are simply the best!
PS: Stock Bridgestones on my Palio were extremely prone to punctures. I don't why. I found Goodyear's that I had on our earlier Santro better then Bridgestones.
amit is offline   Reply With Quote
Old 18th October 2008, 12:22   #278
DieselFan's Avatar
Thanked: 234 Times
Bridgestone has different models and variation in pricing from bottom model to the top is more than 200%.
Old 18th October 2008, 12:28   #279
Akshay1234's Avatar
Thanked: 7,287 Times
from your profile pic i see you have an sx4 vxi. the vxi comes with bridgestones and the zxi comes with jks since they are the only tyres available in that size i.e. 205/60 r16.
Old 18th October 2008, 12:34   #280
Thanked: 31 Times
Yes you are right i called Maruti and they said the same though they didn't admitted that JK's are only available due to size
Old 18th October 2008, 13:39   #281
Thanked: 20 Times
It is fan belt i think. It was done twice, after that I didn't get the sound.
Bridgestone tyre is better than JK tyre.
Since it is not advisable to change 2 tyres, I plan to go for a spare tyre now and change all the 4 tyres with V type tyres after some time.
Does V thread tyres have any advantages apart from looks, Since it is to be used only on one direction I hope it must have some special feature.
Old 18th October 2008, 14:00   #282
prince85's Avatar
Thanked: 117 Times
I have changed over to V-threaded tyres for my SX4. I opted for the Goodyear Eagle F1 GSD3's in 225-55-R16 size which is broader than stock but it does not protrude outside the front fender and does not touch anywhere in the wheel-well which was a concern before i went in for the upgrade. But once they were fitted, i noticed there was a lot of room between the tyre and the liner in the inner wheel-well even with the steering on full lock. I got a good buyback on my stock 600km old JK's. I had to pay a net amount of 12k (including alignment and balancing) after the dealer bought back my stock tyres.
These tyres are a mighty big improvement over the JK's in terms of braking, grip, noise and cornering. I was set on buying the Yokohama AVS Sport or the ES100 tires which IIRC are the only other tyres in this size in the market with a V-thread pattern. But they had a manufacture date of late 2005's and i did not want tyres that old.
I am very staisfied with my choice. There were better comfort or performance tyres from Michelin and Yokohama in the market but i found the thread pattern too boring and they were more expensive than the Goodyear's by a good 2k per tyre but the cost not really a concern. The thing is i have been a great fan of the V-Thread designs and always wanted them in my car for sheer looks but they are also better than the stock JK's in almost everything (lol) which is a bonus. And i am very very happy with my choice.
Gopi, hope this post helps you!
prince85 is offline   Reply With Quote
Old 18th October 2008, 14:10   #283
Akshay1234's Avatar
i meant the only budget tyre in that size.
v thread tyres give better grip. look at yoko s-drives if available in 215/55 r16. those would be good.
Old 18th October 2008, 15:25   #284
anantnehru's Avatar
Do you think you could post a few pictures of the same? I have 215/55/16 on my SX4 with 16x7.0 rims. They definitely look alot bigger than the stock tyres, but 225/55 is something I just cant imagine.
Do the Eagle F1s only come in that size for 16inchers? Cos even I love the V design on those tyres, but I think 225 is just way too broad for my liking.
Also, another thing, any effect on efficiency as such?
Thanks!
anantnehru is offline   Reply With Quote
Old 18th October 2008, 15:34   #285
Hi prince85,
I think 225/55 R16 will look much wider. Since it is single directional deciding on the spare wheel will be a problem. May be we can go for some other choice for the spare wheel.
Can you post the pictures? Quite eager to see those tyres on SX4....
Azure Grey Maruti Suzuki SX4 ZXi (1.6 VVT) comes home!! Saanil Test-Drives & Initial Ownership Reports 37 2nd February 2014 13:09
Swift to SX4 - Booking a Black SX4 Zxi - Some queries on Pg3 joy_swift Sedans 67 28th August 2009 16:08
Suzuki SX4 1.6 ZXI Test Drive Report kunal1983 Test-Drives & Initial Ownership Reports 428 14th January 2008 01:31
Maruti SX4 Zxi - 2200 Kms report sathya_nars Long-Term Ownership Reviews 411 10th October 2007 12:24
