Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Test-Drives & Initial Ownership Reports
Test-Drives & Initial Ownership Reports What New Indian Car Test Drive have you had the privilege of? Want to post a review of your fresh new car?
Thread Tools
Old 3rd November 2007, 16:08   #1 (permalink)
Default Just got new honda Vtec plus- weak brakes
Hi guys ..
just got my latest black beauty last week from Arya honda ( all my previous wer black also )
NHC vtec plus (with ABS& airbags)
im currently at 900 km (did a pune trip .will do an ownership report after 1000 and 1st service
its a absolute rocker .looks a beauty in teh night with those alloys shining.
(posted some pics in Ice section )
It rides fab and i have no issues whatsoever with it .except the brakes ..
now im used to driving the city gxi model and santro xing xg ..and i find brakes of both much better (by twice as much .they stop instantly
this one just goes on and on before it stops ..and i have to press the brake
almost all teh way .getting quite paranoid .cause car just refuses to stop at around 80- 100 .
almost hitthe car ahead couple of times .and had to use engine stops.
now all this happened on mon/tue called the showroom guy.
he tested and said that there indeed is a problem .stops way too late .
sent it to workshop at lalbaug.sent my driver with car .
they said it was ok .driver said it was not .
some workshop head calls me up and says it like that only .ABS would cause it to stop later .
i told him to cut the crap and give it to me in writing .as i said ABS shd help cut dwon braking distance ..except in extreme cases like full gravel track
then he said ok he will sort it out .then i got a call saying brake oil was less ,,and some pads were not clean .and its been done .
My driver also said its ok now..then 2 days i was not able to drive .as was not well and teh driver was doing most of it .and he was ok .
last night i toook it for a spin ..while its much better than before .its still way too weak comapred to even the santro //
now i will be giving it for 1st service on monday/tuesday ..planning to go myslef
what advice would u guys give me..has anyone faced this prob before..
what should i ask them to do
sort out/change the brake setup ..and what comes within warranty and what does not?
if anyone in mumbai wanna test this ,they can pm me thier no ,
cheers and tks for any advice
NIk
Nik9912 is offline   Reply With Quote
Old 3rd November 2007, 20:11   #2 (permalink)
diabloo's Avatar
Infractions: 0/1 (4)
Congrats !!! Great that your are happy with the car. Brakes seem to be a problem with this particular car only. I am sure the Honda guys will fix it during 1st service. Keep us updated.
__________________
NHC - City of Life !! - Symbol of Luxury
________________
diabloo is offline   Reply With Quote
Old 3rd November 2007, 22:14   #3 (permalink)
sreenivass's Avatar
I do not know about this particular model or piece. To my knowledge ABS slows down braking for sure. It really depends on how weak/ slow your car stops. If it is marginal compared to non ABS counterparts, then I do not think it is an issue.
__________________
I have one dream, Fiat with great A.S.S.
sreenivass is offline   Reply With Quote
Old 4th November 2007, 09:13   #4 (permalink)
itwasntme's Avatar
AFAIK, ABS certainly does NOT slow down braking unless on dirt tracks! Depending on the pressure on the pedal and the road grip, ABS should radically shorten braking distances. This will be all the more evident during emergency stops.
Someone correct me if I am wrong.
If you feel that your VTEC+'s brakes are 'weak', please escalate immediately and check ASAP specially if driving long distances and/or on highways!!
__________________
Into each life some rain must fall
itwasntme is online now   Reply With Quote
Old 4th November 2007, 11:01   #5 (permalink)
[quote=itwasntme;616239]AFAIK, ABS certainly does NOT slow down braking unless on dirt tracks! Depending on the pressure on the pedal and the road grip, ABS should radically shorten braking distances. This will be all the more evident during emergency stops.
QUOTE]
yep thats what i know about .its supposed to shorten (even saw some comment From GTO on that today)..and the workshop guy what gieving me some bull.
anyway ,guys any ideas on what i can tell the workshop to do..repair or replace?
tks
Nik
Old 4th November 2007, 11:12   #6 (permalink)
androdev's Avatar
without getting into technicalities.. ABS brakes perform much better than the regular ones and more confidence inspiring than the regular ones as far as regular driving goes. IMHO, ABS kicks only when the wheels are about to be locked.. i can clearly feel it when the ABS kicks in because it makes all kinda of pulsating noises. for all the anticipated stops at 30-40kmph (not sudden/emergency) it is just regular braking stuff and that too works great. (this is the case with my Skoda Laura.. but ABS is ABS!)
if vtec+ brakes are not confidence inspiring (esp compared to the cars you mentioned) you definitely have to get it fixed by the dealer. the dealers are very thick sometimes.. they think you are too excited with a new car and find all non-existent problems. good luck.
androdev is online now   Reply With Quote
Old 4th November 2007, 19:08   #7 (permalink)
sreenivass's Avatar
Hope this helps
Anti-lock braking system - Wikipedia, the free encyclopedia. Looks like it can be slower.
__________________
Old 5th November 2007, 14:40   #8 (permalink)
vnabhi's Avatar
Congrats on your new vtec!
As regards braking, it might be an error in judgement---since you now have a vtec, it has far better pick up than the GXi and the Santro. So you could be braking at speeds higher than you know. Hence the longer time for braking. I may be wrong, but do keep this in mind.
__________________
Ford Fiesta 1.6 sxi 2007
WagonR LXi 2001
vnabhi is online now   Reply With Quote
Old 5th November 2007, 15:48   #9 (permalink)
RajaTaurus's Avatar
"The purpose of this is to allow the driver to maintain steering control under heavy braking and, in some situations, to shorten braking distances (by allowing the driver to hit the brake fully without the fear of skidding or loss of control)." - Wikipedia..
Exactly. The ABS itself doesn't cut short the braking distance mechanically. Its the psychological liberty it gives to the driver to stamp on the brakes, without having to worry about burnt/locked brake-shoes or loss of control..
Also note that Disadvantages of the system include increased braking distances under certain conditions and the creation of a "false sense of security" among drivers who do not understand the operation and limitations of ABS.
Also clearly put in by, androdev, if the braking is weak, the braking IS WEAK. Get it fixed to YOUR satisfaction rather than anybody eles's judgement, coz it is a precarious condition and could result in untoward incidents.
__________________
RajaTaurus...
Friends come, Friends go, those tolerate stay...
RajaTaurus is offline   Reply With Quote
Old 5th November 2007, 21:17   #10 (permalink)
yep .tks guys
am going myself tomorrow ..lets see ..
and no Vnabhi ..it aint about error in judgement ..i drive a m8's Civic also sometimes and it dead stops each time even at speeds at excess of 120 k
cheers
Nik
Old 6th November 2007, 10:24   #11 (permalink)
itwasntme's Avatar
I stand by my post below: ABS is definitely a required 'option' on our Indian roads for 99% of drivers. The rest 1% are hopefully experts in threshold braking {and/or drive on pure dirt tracks} and will outperform a modern ABS!
IMHO, if you feel the braking is not upto scratch on your brand new car, get them checked now. Take your car to Honda and TD their demo VTEC back-to-back with yours; get their workshop guys to do the same exercise immediately after that. This should solve the doubt once and for all.
Thanks,
__________________
Old 8th November 2007, 11:53   #12 (permalink)
Update :
went myself ..wasnt in a mood to listen to any story about "ABs works like that only"
they then opened all 4 wheels up ,did whatever cleaning etc they had to .
and it became ok ..
tested it last night to the limit while coming back form poison ...and its perfect now...
Old 8th November 2007, 14:41   #13 (permalink)
Firebird's Avatar
There you go dude...with perfect car now
Good that your mood helped you get the issue fixed
__________________
Firebird
_________________
Matiz SG - 2000 Sold
Palio 1.6 Sport-2006
TEAM-BHP
LEAGUE OF ORDINARY PEOPLE
WITH
EXTRAORDINARY RIDES
Firebird is offline   Reply With Quote
Thread Tools
Does the Maruti Swift have a weak clutch tsk1979 Technical Stuff 100 19th July 2008 11:46
should i go for honda vtec fight_club Sedans 24 23rd June 2006 00:21
brakes for honda crazyhonda Modifications & Accessories 10 16th November 2005 12:37
Need help for my Honda Vtec!!! jigarmuni Modifications & Accessories 37 9th March 2005 10:19
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
