Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Test-Drives & Initial Ownership Reports
Test-Drives & Initial Ownership Reports What New Indian Car Test Drive have you had the privilege of? Want to post a review of your fresh new car?
Thread Tools
Old 14th January 2008, 09:26   #121 (permalink)
Are you a DIY guy or took help from a local garage to open up the engine cover ???
I like DIY as you can get more perfection if you do it yourself.
If you DidIY, what is the spanner number to open the engine cover nuts below ??
Originally Posted by kingshukt View Post
I had to remove the engine cover to get complete access.
OT: Any bangalore DIY guys in here ??? pls PM.
__________________
Remember, its a machine
Old 14th January 2008, 09:41   #122 (permalink)
Yes I like doing it myself. I do not remember the "spanner No". I have a complete rachet-socket set (amongst others) . I think it was a 12-13 or 14 A/F size bolt.
By engine cover - I mean the bottom guard (which is a sort of cardboard)
Not to be seen as singing my praise - I had changed the alternator and the power steeing pump on my earlier Sierra myself.
Yes doing it yourself or being present when the mechanics do it does give you a better insight in-to the mechanics of the car.
I am now in search for the Service manual for the 2.2. I understand that TM have still not printed the same - can somebody reconfirm ?
kingshukt is offline   Reply With Quote
Old 14th January 2008, 11:28   #123 (permalink)
Me too, the splash guard is made of 2mm thick metal plate and not cardboard
Can you please recheck and confirm, I will buy a ring spanner for the same (I need to know the exact number).
There are two of them, one which covers the engine from below and the other extends till under the end of front seat.
Do you need to remove both ?? as a common set of bolts holds them in the center ?? or are they the sliding type, loosen the bolt and a bit and slide them out from the central holding nuts.
Let me know if you can find one, I need one too.
I searched for now, but couldnt find it.
__________________
Old 14th January 2008, 12:34   #124 (permalink)
There are 2 guards(actually there are three - if you consider the guard below the radiator - I have analysed how to remove it)
1. The 1st one below the engine / Engine oil sump. - This is made of cardboard type of material with sides and middle reinforced with PE / PU foam. This reinforcement gives it stability and ensures - amongst other things, that it does not flutter due to air pushed from below the car . ( I would liked it to be of metal because engine washes wit water / kerosene over a period of time will degenerate this guard. and TM being what is is does not have this in spares - This is similar to 3L Dicor also - hence spares position is confirmed).
2. The 2nd is below the gearbox and is of metal. I have not opened this one even for the under-body coating - so do not know the bolt sizes. You have to go under from the sides to reach this area quickly.
I have taken off only the 1st cover (cardboard one). It is by 8 bolts(or is it 7 ??) - 4 in the back and 4 (+ve about this 4) in the front. I will inform the A/F size tomorrow. (Will go under today evening)
This cover once removed gives access to the torsion bar suspension, steering linkages, the oil sump etc.
The service station manual is in its 1st draft in TM. Do not know when the same will be finalised and printed.
Old 14th January 2008, 12:44   #125 (permalink)
Erratum:
Please read the 1st line as:
There are 2 guards(actually there are three - if you consider the guard below the radiator - I have NOT analysed how to remove it).
I forgot the all important word "NOT".
Old 15th January 2008, 07:43   #126 (permalink)
Dadu:
The spanner size is 13. There are 8 bolts which you must remove to remove the cover.
Old 15th January 2008, 19:00   #127 (permalink)
I collected my RC book but realised that a print number "1" was missing inbetween, from the chasis number, which has been corrected by adding it manually by black pen, amongst the computer printed chasis number.
Will go back the dealer and clarify, if its the RTO who did that and is this normal. The RTO has used a DMP for the print. Stamp and sign are only at the bottom of the page.
Other bangaloreans, is it common for the RTO to correct like this in the RC book.
__________________
Old 15th January 2008, 20:37   #128 (permalink)
...Other bangaloreans, is it common for the RTO to correct like this in the RC book.
no way... is there any kind of sign or seal on top of that correction - the kind of one where one does to validate a correction. but AFAIK, editing a document makes it invalid!
please do check. not something that you want to put off till a need arises. do sort it out / or get it validated from the RTO asap.
HappyWheels is offline   Reply With Quote
Old 16th January 2008, 08:02   #129 (permalink)
RTO-Pune have started issue of "Smart-Card"s in place of RC / TC book. I have checked out the Chassis nos on this card with that written on the owner's manual (on the inside of the cover page where the dealer writes down the details of the owner and the car details). The Chassis no. is correct (Thank God!)
However the RTO has made a mistake on the CC of the car. they have written the CC same as that of the 3L Dicor. All the Smart cards of other 2.2 dicors also have the same mistake. However they have given the description of the car as 2.2 VTT Dicor. The dealer says - forget it - will not be a problem.
I ask other 2.2 owners from Pune to check and confirm from their Smart cards.
Old 16th January 2008, 08:42   #130 (permalink)
suman's Avatar
Do not take a chance, get a fresh copy, you will have trouble later. I remember the Haryana RTO had made a mistake with my Fiesta RC, the dealer sent it right back & applied for a fresh one. There was a delay but at least I had the correct document.
You will have problems selling the vehicle, not to mention occasional harrassment if you are ever stopped on the roads by the cops.
__________________
Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4
Old 16th January 2008, 09:24   #131 (permalink)
gowda79's Avatar
Default @dadu
not seen something like that still today, better to get it changed now rather fighting it later.
__________________
Raghu
Suzuki Shogun
Suzuki Samurai
Indian Mercedes - Maruti Esteem Vxi
The King - Tata Safari Vx 2.2 VTT
gowda79 is offline   Reply With Quote
Old 16th January 2008, 17:09   #132 (permalink)
m3_07's Avatar
Hi....need help...i'm getting the seat covers made for the safari...incidentally, i am unable to find the right design for the "map pocket" on the rear of front seats. Can you friends help me with any pics...the pockets need to be exclusive.
m3_07 is offline   Reply With Quote
Old 17th January 2008, 08:36   #133 (permalink)
It should be easily done, did you check with g-sport ??
__________________
Old 17th January 2008, 08:40   #134 (permalink)
Thanks Happy, kingshuk, Suman and gowda.
I gave the RC back to dealer, will now take 2 days to manually put the correct chasis number and then endorse it with a RTO seal and sign. The RTO's computerized record will also be corrected.
Kingshuk, you should get the "cc" corrected as it might pose a problem later, you dont want to sell a 2.2l as a 3.0l later.
__________________
Old 17th January 2008, 13:33   #135 (permalink)
Dadu, You are right. the best thing would be to give it back to the RTO and ask them to correct. I was disturbed when I recd the Card. I spend athe better part of 30 minutes going thro other 2.2L Dicors cards (which the owners had not yet collected) to recheck.
I will ask the guys at the Pune meet tomorrow (incase somebody with a 2.2 turns up) as to what is printed on their card.
Going to RTO with a correction is something none of us want to do
Thread Tools
Upgrade 4x2 Safari Dicor to 4x4 - Possible? biswajit Modifications & Accessories 22 30th September 2008 14:33
My New Safari Dicor EX 3.0L 4x2 LTR Thread reachmash Long-Term Ownership Reviews 57 9th September 2008 10:34
New Tata Safari 2.2 VTT EX 4X2 EDIT 5000kms service done harjeev Test-Drives & Initial Ownership Reports 299 7th August 2008 18:30
New Tata Safari 2.2 VTT 4X2 EX Artic Silver HULK JUDA Test-Drives & Initial Ownership Reports 83 24th June 2008 19:45
For Sale: Tata Safari DICOR VX 4X2 speedmiester Shifting gears 10 12th October 2007 16:35
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
