Old 5th May 2008, 19:25   #166
adc
adc's Avatar
Thanked: 2,103 Times
Originally Posted by m3_07 View Post
I remember someone mentioning this last time too, as when you drive over 100Kmph, you will hear the sound of wind (i dunno where it gets in & out). I have been experiencing this pretty badly. Any of you have similar experiences please??
Here is a video [taken with Canon S3 IS digital camera in movie mode] that I had with driving speeds between 120-140 kph. The wind noise is a definite intrusion at such speeds.
The wind noise seems to come through the front doors at the curves [better front door rubber beads???], but again did not feel any wind flow as such. We have find a solution to this noise at 140 kph.
adc is offline   Reply With Quote
Old 5th May 2008, 19:41   #167
simply_sunny001's Avatar
Thanked: 15 Times
nice roads ADC,you are making most of the beast.
and in 1.5 yr+ of ownership i'm yet to cross 130
highways in my area suck
simply_sunny001 is offline   Reply With Quote
Old 5th May 2008, 20:09   #168
adc
adc's Avatar
This is NH60 from Kharaghpur and is the road one takes for going towards bhubaneshwar and chennai and onwards. And about 150 km from my house.
But no doubt with have minimum traffic and the concrete surface with well engineered turns, easily 120-160 kph can be done for an extended period of time - a all time favourite highway road for me.
Old 5th May 2008, 23:04   #169
bglsrini's Avatar
nice roads......yes the wind noise is bad and we really have to find a solution.
But the noise what,I addressed is different.Planning to check it out when i give my BULL for 15000km service.
bglsrini is offline   Reply With Quote
Old 6th May 2008, 16:08   #170
m3_07's Avatar
Thanked: 200 Times
I am facing another problem....this time it is the aliens!!!
"Rats enter the cabin & spend their nights & GOD knows what else goes on??". TASS did not believe it at first. When they saw their "famous droppings", they did not have much choice though. I have sent the car to TASS to analyze the problem & have also told TM that this is just not acceptable. Let us see what they can do about it.
You are right on spot ADC!!
TASS guys mentioned that it happens in all "SUVs". Can someone confirm this please??? This could be minimized, if not rectified totally, by adjusting the gap in the front doors. The "gap" is intentionally maintained to reduce the rattling effect at higher speeds they claim!!
m3_07 is offline   Reply With Quote
Old 6th May 2008, 16:19   #171
bglsrini's Avatar
oops Rats in the cabin? I have to check it out too.....Please let us know what TM says about this.
Old 6th May 2008, 16:58   #172
hmishra83's Avatar
OMG...The last time I heard this happenning to a TATA was the case of an Indica. The rats made their way up into some part of the AC and then died there or something. Not really sure how this happened though!
hmishra83 is offline   Reply With Quote
Old 7th May 2008, 11:40   #173
bglsrini's Avatar
I was very eager to check what noise is that.So,I was scanning my BUll when i was driving........ oooo I can see black smoke comming out of the exhaust from rear through the side mirror only when the noise is comming....... I dont know whats happening.
Need advise.
Old 7th May 2008, 11:52   #174
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by bglsrini View Post
Need advise.
Thats under fast acceleration? The smoke due to the extra fuel ?
I tried to take a video but I could differentiate the sound when I played the video.
Old 7th May 2008, 11:52   #175
m3_07's Avatar
Thanked: 200 Times
enri srini???
I thought I scared guys around with noise/ rats...now you are scaring us with "black smoke"!!
I presume that it would be time for the exhaust clean up.
Old 7th May 2008, 12:06   #176
nitrous's Avatar
Thanked: 285 Times
Guys, do the 3.0L dicor and the 2.2 use the same oil filter?
Old 7th May 2008, 12:43   #177
bglsrini's Avatar
Yes its under fast acceleration.I dont feel the noise and smoke in normal/steady acceleration
m3_07
May be its time for exhaust clean up tooo.....let me check it up in that angle also.
Old 7th May 2008, 12:51   #178
Thanked: 15 Times
Regarding Smoke
Which fuel you are using ?
Regarding Noise
Is this noise is kind of Engine Knocking ? Make sure you havnt filled adulterated fuel.
Usually for smoke problem,you can get your catcon cleaned and start using normal Diesel+System D if not already using.
Old 7th May 2008, 13:45   #179
Yes it is the same oil filter..by part number.
kingshukt is offline   Reply With Quote
Old 7th May 2008, 13:55   #180
bglsrini's Avatar
Regarding Smoke
Regarding Noise
Iam using HP Speed.
no,the noise is a hissing noise comming when the the acceleration is given.This noise comes when the rpm goes more than 1500 and till the speed is in increasing trend.When, the speed is constant,the noise is not there.Same way the smoke too.I can also feel the loss of power then.
can u please advise the ratio of normal diesel and system D to be used?
My vechile is also going to be due for 15k service.
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Finally my Bull comes home. A TATA Safari 2.2 VTT Ex 4X2 Pearl White blackbeast Test-Drives & Initial Ownership Reports 31 15th September 2009 02:16
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
