Old 7th May 2008, 13:59   #181
nitrous's Avatar
Thanked: 285 Times
This noise comes when the rpm goes more than 1500 and till the speed is in increasing trend.When, the speed is constant,the noise is not there.
Its not noise.
Its technically called music. Music from a device called a Turbocharger.
Old 7th May 2008, 14:08   #182
madan80's Avatar
Thanked: 73 Times
and black smoke during high RPMs is normal in diesel vehicles.
madan80 is offline   Reply With Quote
Old 7th May 2008, 14:11   #183
m3_07's Avatar
Thanked: 200 Times
1ml of system D for 1 litre of normal diesel
m3_07 is offline   Reply With Quote
Old 7th May 2008, 14:14   #184
tsk1979's Avatar
Thanked: 16,422 Times
If you are getting black smoke, it may mean that engine is running rich.
There is a possibility that there is micro leakage in turbo plumbing, so the engine is not getting all the air it needs, and hissing sound is also more than necessary.
If thats not the case it could be a simple case of ECU setting the mixture too rich.
Try normal diesel for a change without any system D etc.,
Old 7th May 2008, 14:16   #185
bglsrini's Avatar
Originally Posted by nitrous View Post
Its not noise.
please its not the music from turbocharger.
Its somethingelse.Shall confirm with TASS and get back about this.
bglsrini is offline   Reply With Quote
Old 7th May 2008, 14:24   #186
simply_sunny001's Avatar
Thanked: 15 Times
Please go ahead with the service and as Tanveer mentioned use Normal Diesel at least for 2 -3 tankfuls and i'm sure the smoke problem should be gone.
you will feel slight loss of smoothness due to you using Premium diesel earlier
but this smoothness can be take care by using System D.
and i'm 100% sure that Premium diesel leads to lots of smoke in Safari so switch to normal diesel from a trusted bunk.(IOC normal diesel is good)
simply_sunny001 is offline   Reply With Quote
Old 7th May 2008, 15:05   #187
Sirjee, I beg to differ.
On the presumption that we are speaking about 2.2 VTT Premium Diesel may give other problems but not smoke.
I have been filling in Xtra Mile from IOCL (last 2 tank fulls) and I have not noticed black smoke yet.
kingshukt is offline   Reply With Quote
Old 7th May 2008, 15:25   #188
Thanked: 15 Times
my suggestions were based on practical experiences after using premium diesel for a long time and then switching to normal diesel.
Please go beyond 2000 RPMs and see how much smoke is there.
try sudden acceleration too
Old 7th May 2008, 15:39   #189
adc
adc's Avatar
Thanked: 2,103 Times
I have been using premium fuels all through my 6-1/2 months and no black smoke. Now using IOC premium wholly for the last 3 fills and fully satisfied. Heard that premium may choke the catalsyt on the long run but then the smoothness and acceleration has to be there.
Only once I filled up normal diesel, the engine noise was more .
Yes do insist on getting it totally cleared up at TASS and do sign up only when you are satisfied. The 15K service is a big one, hope you have gone through the manual regarding what needs to be done - just to be updated on your side.
adc is offline   Reply With Quote
Old 7th May 2008, 18:34   #190
bglsrini's Avatar
I will work on different options as suggested and confirm
Old 7th May 2008, 23:38   #191
bglsrini's Avatar
yes,i got the problem.Today while driving back home,I tried accelerating more and suddenly........There was no power completely and the service light was on.
I stopped the BULL for some time and was thinking and Yes,It should be a turbo leakage as suggested by tsk1979.I was rewinding my thoughts and experience with my tata sierra turbo where i once had the same kind of problem.And confirmed it myself its a turbo leakage.
Then I started my BULL again and now the service light is gone.
Good,So i called TASS(prerana) and discussed with them and they also confirmed the same.So,booked for service 15000 km tomorrow and also to attend this problem.
Old 8th May 2008, 16:35   #192
bglsrini's Avatar
Default 15000km service
OOOOOOoooo.......I Miss my BULL.
Today morning,due to my schedule , I was not able to make it for the service station.My driver took my BULL.I spoke to the service advisor over phone and explained him the problem and 15000km service to be done.Hope every thing is carried on well.
Old 8th May 2008, 23:20   #193
jkdas's Avatar
Thanked: 1,436 Times
Maybe a small issue,like a burst rubber pipe.
And you driver drives it too? Any difference in FE when he drives?
Old 9th May 2008, 13:15   #194
bglsrini's Avatar
I spoke to the prerana guy(servise advisor) to check what the problem is.He said the turbo Hose has failed. So,when we accelerate ,the hose get disconnected resulting in loss of power/noise/black smoke.So,they were trying to fix a new one and that too is not fitting properly and is getting disconnected. He said they are trying it out and they will let me know once my BULL is ready.
He says its a special case and they have never come across a problem like this.
HI JKdas,
My driver drives it rarely otherwise he is at home driving santro for my wife and kid.He knows how i like my Bull and the FE is better when he drives.
Old 11th May 2008, 11:58   #195
bglsrini's Avatar
Default 15000km service done
Yes,The Turbo problem is fixed and the 15000km service is done.My BUll has got its power back.
I took the delivery on 9th friday after the problem was fixed and the 15000km service done.
I spoke to the advisor to find out what the problem with the turbo.He then opened the front bonnet and showed a red hose inside.He said the hose was slipping.Thats when we accelerate,The hose slips and it leaks and resulting in the turboloss,loss of power and black smoke.The problem is the manufacturing defect in the hose.Now,they had fixed a new hose and the problem is solved.
the failure part no.254714605815- rubber hose(I.C to mainfold).-picture attached.
For the 15000km service:
changed - assy.fuel filter Delphi
diesel engine oil ch4 - 15w40 castrol GTX - 6.5 lts
differential oil ep - 85w140castrol - 2.2 lts
assy oil filter(fleet gaurd)
All other regular checkups done.
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Finally my Bull comes home. A TATA Safari 2.2 VTT Ex 4X2 Pearl White blackbeast Test-Drives & Initial Ownership Reports 31 15th September 2009 02:16
Tata Safari Dicor LX 4 X 2 or Safari Dicor EX 4 x 2 Digitalmafia SUVs, MUVs & 4x4s 55 1st June 2009 17:31
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
