Old 15th April 2008, 23:29   #181
jerish666's Avatar
Thanks KpZen.Someone please confirm the handling of GetzD.I heard it is not that good.GetzD owners please confirm it.
jerish666 is offline   Reply With Quote
Old 15th April 2008, 23:48   #182
iraghava's Avatar
Thanked: 156 Times
I had a TD too but it was very short & that too on a customer car so no definitive conclusions. But from I could gather, suspension seems to be much better than the Verna with none of the funny pogo movements like the Verna & the steering also is more feelsome & natural.
If I get to test another piece for a lomger duration, will update this thread.
Old 16th April 2008, 13:03   #183
djay99's Avatar
Thanked: 491 Times
Can Getz D hold 6J alloys without touching wheel arch?
I beleive it handles like a dream on 205/60-14 michelin xm1+/pp2. What do others say?
djay99 is offline   Reply With Quote
Old 16th April 2008, 13:32   #184
kpzen's Avatar
Thanked: 1,655 Times
6j alloys isn't gonna be the problem but the 205/60-14 will scrape with the wheel wells.
205/60-14 is too tall for Getz. 195/60-14 or 195/50-15 would be a better option.
Old 16th April 2008, 14:40   #185
Thanked: 103,378 Times
Yup, its not as balanced as the petrol Getz. Reason? That heavy engine in the front.
Old 16th April 2008, 14:43   #186
PatienceWins's Avatar
Thanked: 284 Times
That makes sense.
Is handling better than Verna CRDi? If not, considering the price difference and features, Verna is a better option.
PatienceWins is offline   Reply With Quote
Old 16th April 2008, 14:50   #187
jerish666's Avatar
That means its not bad.
Originally Posted by PatienceWins View Post
That makes sense.
please confrim this.I hope GetzD is better handling than verna.
Old 16th April 2008, 14:50   #188
kpzen's Avatar
Petrol and diesel have different suspension.
Its much better than the speed boat, Verna.
Old 16th April 2008, 15:08   #189
vabs78's Avatar
Thanked: 11 Times
BSM had a comparision between GetZ Crdi and Swift DDiS. Following is an extract from the article:
The Swift diesel just has no answer to the Getz's onslaught in a straight line. But around corners it can keep up with the Getz. Despite all that prodigious power, the Getz can't make the lithe Swift disappear from its rear-view mirrors. Unlike the Swift, the Getz's mechanical pump steering takes longer to respond to inputs with the initial response being near-dead before loading up rather uncharacteristically. It also lacks ABS, so you plan your entry into corners with caution. Unlike the lighter front-end of the Swift, the Getz is a bit more reluctant to play ball. Overdo it on the Swift and it'll start to lose its tail and the Getz will disappear into the distance once again. Despite a bit more understeer, there is also more grip on the Getz. The 165/80 tyres aren't just up to the job to take anything beyond a point on the Swift, while the Getz's 175/65 tyres stick better. The Getz also has a wider front track that makes it more planted around corners, but despite this, the Swift is more up to the task of planting a smile on your face.
Source: Tests - Comeback kid - Business Standard Motoring
The review can best be termed as 'confused'.
vabs78 is offline   Reply With Quote
Old 16th April 2008, 15:37   #190
djay99's Avatar
Thanked: 491 Times
Finally Getz Crdi is the winner cheers:
Old 16th April 2008, 15:38   #191
djay99's Avatar
Thanked: 491 Times
Recently saw a new Getz D in showroom with 205 tires. 205/?-14 you recommend?
Old 16th April 2008, 16:19   #192
razor4077's Avatar
Thanked: 258 Times
You mean Hyundai are selling the Getz D with 205 mm tyres? Or is that a one-off? Site still advertises the skinny tyres...
razor4077 is offline   Reply With Quote
Old 16th April 2008, 16:49   #193
jassi's Avatar
Thanked: 11 Times
Smile
djay - did you see this in the advaith hyundai bangy showroom - they are known for kitting santros and getz and putting them on display
jassi is offline   Reply With Quote
Old 16th April 2008, 17:09   #194
djay99's Avatar
Thanked: 491 Times
razor and jassi,
I saw it in Advaith, outer ring road belonging to a customer. Getz had 205/14 inch yokos on Hyundai branded alloys. It was a white Getz. Was looking awesome
Old 16th April 2008, 17:23   #195
nkapoor777's Avatar
Thanked: 91 Times
I read somewhere on the forum that one can get ABS kitted before taking delivery of Getz D. Can someone confirm this?
This one is on the top of my list. Get a Pete's and it should zoom. Although, Prajesh has confirmed that the braking is decent, ABS is definitely a plus. I only want to hold off for the Punto, if it comes with a bigger MJT than the puny 1.3.
nkapoor777 is offline   Reply With Quote
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30) ph03n!x Long-Term Ownership Reviews 598 6th November 2012 00:02
Hyundai Verna 1.5 CRDi Diesel Automatic Test Drive - My Views VSG12777 Test-Drives & Initial Ownership Reports 13 12th January 2011 10:43
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Getz CRDI Test Drive Report Torqueguru Test-Drives & Initial Ownership Reports 19 20th June 2008 14:37
