Old 16th April 2008, 17:32   #196
kpzen's Avatar
Thanked: 1,655 Times
Originally Posted by djay99 View Post
Recently saw a new Getz D in showroom with 205 tires. 205/?-14 you recommend?
Correct size should be 205/55-14.
Old 16th April 2008, 18:30   #197
vabs78's Avatar
Thanked: 11 Times
razor and jassi,
I saw it in Advaith, outer ring road belonging to a customer. Getz had 205/14 inch yokos on Hyundai branded alloys. It was a white Getz. Was looking awesome
Can you post a pic?
Will it scrape with the wheel wells?
vabs78 is offline   Reply With Quote
Old 16th April 2008, 19:06   #198
djay99's Avatar
Thanked: 491 Times
Originally Posted by vabs78 View Post
Can you post a pic?
Sorry vabs. I donot have a pic.
I dont think 205/55 will scrape because side wall height is 112.75mm
and stock tires have side wall height of 113.75 which is within range.
GC will be reduced by 1mm if we get 205/55-14 tires. Am i right kp?
djay99 is offline   Reply With Quote
Old 16th April 2008, 19:39   #199
djay99's Avatar
Thanked: 491 Times
Yup, its not as balanced as the petrol Getz. Reason? That heavy engine in the front.
IMO Centre of gravity changes as weight increases due to heavy diesel engine in the front. Result - reduced handling characteristic compared to 995KG petrol.
Old 16th April 2008, 19:56   #200
vabs78's Avatar
Thanked: 11 Times
But, I think the scrapping problem happens due to the width of tyre while turning.
KP, What will be correct upsize in 15" rims?
Old 16th April 2008, 20:05   #201
djay99's Avatar
Thanked: 491 Times
As i have seen Getz with 205 tires, no scrapping while turning.
Visit TYRESAVE: Tyre Size Calculator and calculate right tire size yourself.
Old 16th April 2008, 20:17   #202
sanjayatarizona's Avatar
Originally Posted by nkapoor777 View Post
I read somewhere on the forum that one can get ABS kitted before taking delivery of Getz D. Can someone confirm this?
This looks like good news, anything concrete though? I am hell bent on the Getz D as the 3rd car at home when on vacations, but cannot muster enough courage due to lack of ABS and Airbags.
sanjayatarizona is offline   Reply With Quote
Old 16th April 2008, 20:26   #203
iraghava's Avatar
Thanked: 156 Times
Vabs - 185/55 & 195/50 R15 are correct upsizes. 205's I suspect will touch at the rear under load.
Old 16th April 2008, 20:31   #204
jassi's Avatar
Thanked: 11 Times
Thumbs up
yes please i am guessing dealers should be able to offer abs kit if hyundai can't - i mean seriously if getz petrol can have abs why not getz diesel - the same kit should work
jassi is offline   Reply With Quote
Old 16th April 2008, 20:37   #205
vabs78's Avatar
Thanked: 11 Times
thanks iraghava,
I will be going for Pete's after some time if I go for Getz D. Will 195s be sutable for such power?
Old 16th April 2008, 20:41   #206
iraghava's Avatar
Thanked: 156 Times
Yeah should cope as long as you're not ham-fisted with the throttle! And if you find them inadequate then get a set of Advan Neova's, they are now available through Yoko India.
Old 16th April 2008, 22:29   #207
nkapoor777's Avatar
Thanked: 91 Times
I am already saving for them.
nkapoor777 is offline   Reply With Quote
Old 16th April 2008, 22:39   #208
vittalnrv's Avatar
Thanked: 27 Times
I am running 205/50/R15 for over 2years on my Getz, even on full load not a slight hint of scrapping.
vittalnrv is offline   Reply With Quote
Old 17th April 2008, 15:56   #209
vabs78's Avatar
Thanked: 11 Times
vittalnrv, how is the ride comfert?
Old 17th April 2008, 16:58   #210
jkdas's Avatar
Thanked: 1,436 Times
thanks iraghava,
Petes needs better tyres? All Pete's does in makes things happen faster, ie, kill few seconds off than you had prior to it. Just coz you fit Pete's doesnt make the car unstable unless you want to do 190kmph everytime.
Advan's will be too soft right? Heard they see that the car is glued to the road.
I think he wants to know more about its road holding ability!
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30) ph03n!x Long-Term Ownership Reviews 598 6th November 2012 00:02
Hyundai Verna 1.5 CRDi Diesel Automatic Test Drive - My Views VSG12777 Test-Drives & Initial Ownership Reports 13 12th January 2011 10:43
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Getz CRDI Test Drive Report Torqueguru Test-Drives & Initial Ownership Reports 19 20th June 2008 14:37
