Old 17th April 2008, 18:14   #211
djay99's Avatar
Thanked: 491 Times
Originally Posted by vittalnrv View Post
I am running 205/50/R15 for over 2years on my Getz, even on full load not a slight hint of scrapping.
How is the ride quality with lower profile tires?
djay99 is offline   Reply With Quote
Old 17th April 2008, 18:23   #212
sanjayatarizona's Avatar
I guess the real drawbacks are (1) lack of ABS, Airbags (2) Iffy handling at high speeds
Guess there is an option for ABS installation.Any options for improving the handling in a quick fix fashion?
sanjayatarizona is offline   Reply With Quote
Old 17th April 2008, 18:40   #213
jkdas's Avatar
Thanked: 1,436 Times
drove one?
Better tyres will help to some extend. And a brain that understands that its a pocket rocket and hence to play safe.
How many of you will do 140kmph on a daily basis for kms and kms?
Old 17th April 2008, 18:46   #214
djay99's Avatar
Thanked: 491 Times
Not many of will do untill they know how the roads are - like on western expressway.
It handles well upto 120 on typical indian SH.
Straightline - can exceed 150+ for some moment till you see a speed breaker.
It takes around 55Mtrs for 100-0 (which is decent) if a driver is driving carefully
ABS will obviously help while braking on a corner.
Old 17th April 2008, 21:02   #215
drove one?
Yes i did drive once, but maxed out@110 kmph. Any faster on my home stretch, considering the status of my roads i would have reached high heaven. At these speeds handling is of course not an issue at all so i depend on hearsay/ quotes from those folks who have managed to drive consistently fast over extended spans.
Yes i guess tyres should help, heck they improved the handling on my Santro on highways by a long margin. ABS would definitely be great.
My question was more on the lines of anything to tweak the suspension.I guess that is not a quick fix option..
Old 17th April 2008, 21:25   #216
jassi's Avatar
Thanked: 11 Times
Smile
so getz crdi has no abs and maybe dealers can offer an option to add the abs kit from the petrol version.
Is there ebd on the getz crdi or is that also part of the abs kit??
jassi is offline   Reply With Quote
Old 17th April 2008, 21:32   #217
undead's Avatar
Thanked: 168 Times
No ABS , No EBD , No airbags for Getz D . No options available.
I cant wait to get my hands on it in another 20 days.
undead is offline   Reply With Quote
Old 17th April 2008, 21:36   #218
jassi's Avatar
Thanked: 11 Times
Lightbulb
did u check with the dealer if they can fit the petrol abs kit on your baby i am sure something can be worked out!! we are waiting for your review man
Old 17th April 2008, 21:40   #219
Good Luck Buddy drive safe and maintain the "validity" of your username
Old 17th April 2008, 21:59   #220
Good one @sanjay
Even I am planning to upgrade to either Getz CRDI or Palio Stile MJD.
The marketing executive at Trident mentioned that there is no such need to upgrade the tyres if the speed is maintained till 120KMPH. The current profile is adequate to handle this speed. Also any tyre profile upgradation would impact the fuel efficiency in negative direction. If really interested then he suggested to opt for 195/R14 profile tubeless tyres but maintain the stock steel rims instead of going for alloys.
Both the dealers mentioned that the car delivers 14kmpl mileage in Bangalore peak traffic and 15.5 to 16kmpl in normal traffic conditions.
The paid service cost would be between Rs 2800 to Rs 3000 excluding wheel alignment expenses.
girish.r is offline   Reply With Quote
Old 18th April 2008, 00:20   #221
vabs78's Avatar
Thanked: 11 Times
Petes needs better tyres? ... ... Just coz you fit Pete's doesnt make the car unstable unless you want to do 190kmph everytime.
Better tyres will be needed if one is planning to use the extra power, not for stability but for grip and handling.
Originally Posted by girish.r View Post
...I am planning to upgrade to either Getz CRDI or Palio Stile MJD.
Go for MJD man. There is no point in spending ~1L more if you are not planning to cross 120kmph. (No offense intended)
vabs78 is offline   Reply With Quote
Old 18th April 2008, 08:14   #222
undead's Avatar
Thanked: 168 Times
I will be installing Pete's after some 10000kms . That time i will be going for 195/60 R14 Michelin XM1+ or Yokohama S drives(subject to availability in my area) . I wont be able to drive around 150 or 190 kmph speed in my roads as there are heavy traffic on the highways and i can hardly reach even 120kmph. And good fuel efficiency is always in my mind , so i wont be driving that hard .
Old 18th April 2008, 08:22   #223
jerish666's Avatar
You can fix petes tuning box after the 1st service there wont be any issues.
jerish666 is offline   Reply With Quote
Old 18th April 2008, 08:47   #224
vittalnrv's Avatar
Thanked: 26 Times
Ride quality is much better, steering feels a little weighted now and I also get good confidence on high speed braking.
No sign of rattles inside the cabin. Feel this is the best up size for Getz.
On hard braking from high speeds , my stock 14incher used to lock up so bad that sometimes I will have to hit a speed breaker so hard I will have to hurt my bum but after upsizing to a broader tire the composure is very well maintained and I will definitely recommend this size mainly for the VGT Getz.
Hope this information helps all.
vittalnrv is offline   Reply With Quote
Old 18th April 2008, 10:30   #225
kpzen's Avatar
Thanked: 1,655 Times
S drives don't come in that size. U can consider BFG sport.
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30) ph03n!x Long-Term Ownership Reviews 598 6th November 2012 00:02
Hyundai Verna 1.5 CRDi Diesel Automatic Test Drive - My Views VSG12777 Test-Drives & Initial Ownership Reports 13 12th January 2011 10:43
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Getz CRDI Test Drive Report Torqueguru Test-Drives & Initial Ownership Reports 19 20th June 2008 14:37
