Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Test-Drives & Initial Ownership Reports
Test-Drives & Initial Ownership Reports What New Indian Car Test Drive have you had the privilege of? Want to post a review of your fresh new car?
Thread Tools
Old 6th February 2008, 10:38   #1 (permalink)
Default My new Fiesta TDCI and some other test drives
Hi Floks, I've been reading reviews by all of you on this site, and has helped me a lot in making informed decisions. I recently Bought the 1.4 TDCi in Dec 2007 after test driving Verna CRDI, Logan diesel, Corolla and Honda City. I have had prior experience in driving an Innova diesel, and Santro. Just thought I'll share my thoughts for all others out there trying to make decisions.
Corolla: I loved the suspension and seat comfort in the corolla, but dropped it since it was a petrol car. But the space in the corolla was extremely good. It acclerates well, although you tend to feel it perhaps has a mind of its own; Would have cetrainly gone for the car, were it to be a diesel and at the current price points. My running is upwards of 2000 km a month, hence the preferencefor diesel.
Verna Diesel: verna which has comparable power takes off like a rocket, while in the corolla there is something controlling it and preventing the rocket like take off. Perhaps good from the point of view of safety.
City: The Honda City felt similar to corolla, very noiseless engine, smooth, decent power, though not as much as the corolla, and a bit spongy in acclerating. The insides are good too, but materials are very delicate, and the car is light too. The suspension does not feel solid. Need to handle this car like a baby.
Logan: The Logan was a bit wanting in terms of interior quality, and seemed built to a cost, but the drive was not bad at all. It was certainly noisy, the suspension was good and took the undulations of the road well. But i could not drive it on real bad roads. When i opened the boot, i saw nuts and bolts sticking out, and no insulation material at all. But the sheet metal seems strong and solid. Felt very safe - like sitting in a patton tank. The space inside is massive, can easily seat 3 ppl behind. Seats are big and comfy, but could do with some contours. I found the car cost and mileage great value for money. However, i was not sure of the future of the JV renault-M&M, and hence dropped the idea after much deliberation.
The Verna had amazing pick up after a brief turbo lag, the drive was exhilarating, but i found it a bit unsteady at speeds above 130/140 kmph. The suspension was okay too, and the seats were good - The rear seat was bit hard. However, i felt it was like driving a bigger/more powerful santro. The clutch and gear changing mechanism, and unsteady nature at high speeds felt similar. To manage the car at low speeds in heavy traffic would involve a lot of clutch/break activity, just to control it within the 0-20 km speeds. Although the Fiesta was not in my buying list, i just decided to test drive it, and found the experience great. ( i test drove verna twice, and the fiesta thrice..just to be sure i felt the sameevery time). The suspension of fiesta is amongst the best in its class (leaving aside the corolla of course), minimum body roll, takes up jelly stone roads and rough roads very well, cornering/handling is great, and it is a great drivers car. On paper it gives only 68 bhp, but does not feel underpowered. It moves well in city at slow speeds, without jerks, and can reach 140 kmph on highway (it is rock steady, can even do some high speed manouveres at 80+ kmph - handles beautifully), although a bit slow in acclerating above 80+. Most city driving can be done very smoothly in the 1000-2000 rpm range. For overtaking, you need to work the gears a bit, and get into lower gears and into the 3000 rpm range. But this is not great problem, since the gear change mechanism is quick, short and precise. The engine is refined and sweet, although i found some noise above 3500 rpm (which i found in the innova too). Mileage is great so far - 15+ km/ltr with A/c in city. Although interior space is few mm less than verna, the seats are more comfortable. The rear seats are softer too. The headrests are the best, and offer best neck/head support. The boot is certainly bigger than the verna. Hence i think iFiesta TDCi is great value for money; Verna is more expensive, and you would not get all of the features you get in the ford. In the verna, you probably surely need the ABS to stop the car without skidding/locking the brakes, so it all totals to an extra Rs 70K to 90K. Besides, for me i thought, i would never fully use the 110 bhp of the verna, and wanted a different driving feeling (all hyundais feel similar) - hence settled for the ford fiesta. However, there are some irritants such as little noises here and there, which need to be set right. Cauvery Frd in bangalore did set right a minor problem with the clutch, by bleeding it. It is fine now. Later i need to check if they can respond well to the rattling noise from the door pads. The Innova never had such issues; the santro did have some such issues, but the hyundai guys are adept at detecting it and setting it right. Hope the same holds true for Ford.
1/feb: After 2200+ km: The car is much smoother,with mileage up to 18 km/ltr, I am not getting the noise above 3500 rpm that i mentioned before. It is easily able to touch and maintain speeds of 150+ kmph on NICE road in bangalore. While driving the Innova previously, i felt a bit unsure at these speeds, and breaking is certainly a problem with the innova. But no such issues with the fiesta. It is in its elements on curvy roads with bends. That is where the top class handling of the fiesta at high speeds impresses. Only, while overtaking, dont get caught in the 800 to 1500 rpm range; make sure you are above 2000 rpm while overtaking (that is where the power comes); one should have absolutely no problems. I guess this holds true for most diesel vehicles. In city traffic, just pop it to 1st gear and it can potter along at 5km/hr, no need to strain legs with ABC (acclerator/brake/clutch). Cauvery Ford has managed to set right niggling problems like rattling noise from the door panels etc. So. as of today, I’m quite pleased.
dhiramos is offline   Reply With Quote
Old 6th February 2008, 13:01   #2 (permalink)
Great decision....Hope you'll enjoy driving the car in the times to come too...
srinivasr79 is offline   Reply With Quote
Old 6th February 2008, 14:16   #3 (permalink)
vnabhi's Avatar
Great choice. I own a petrol Fiesta and agree that it has the best handling abilities in that segment. I also TD'd a diesel Verna and like it's rocket-like response. But diesel did not make sense to me as I run only 16 kms a day.
I want to TD a diesel Fiesta one day just for the heck of it.
__________________
Ford Fiesta 1.6 sxi 2007
WagonR LXi 2001
Old 6th February 2008, 14:23   #4 (permalink)
diabloo's Avatar
Infractions: 0/1 (4)
Good analysis. Well, there are people who have badly abused the city but it has taken it all with a gentleman's silence.
BTW, congrats on your Fiesta
__________________
NHC - City of Life !! - Symbol of Luxury
________________
diabloo is offline   Reply With Quote
Old 6th February 2008, 14:33   #5 (permalink)
achopraa's Avatar
Cool Congrats...
hey man...
very nice review/s and a very good choice indeed...
Though Ford claims a "5 minute mein Fida" test drive but I think you took your own sweet time and finally got FIDA....
Please also post about ICE/upgrades and the Pics of the beauty....
__________________
Main Aa Gaya....Main Chaa Gaya....
achopraa is offline   Reply With Quote
Old 6th February 2008, 14:53   #6 (permalink)
mobike008's Avatar
One of the best filtering out review in a long time. Congratulations for your new car, its a lovely car . I am sure your enjoying it completely.
When i was deciding to buy a car, i had shortlisted the Viva Crdi and Ford Fiesta TDCi. After test driving both several times, i settled for the viva, as i found it to be a much crisper handler, more fun while fast cornering and there would be no comparison for the acceleration thrill it provides. Two positive points in Fiesta, i noted was the back seat comfort is better in fiesta and rough roads are gobbled up by them much better and it certainly has a much refined engine ( NVH values). However, since i drive fast 80% of the times ( meaning i time my drives, gear changes almost always above 2.5-3K rpms, touch 100kmph-110kmph on almost daily basis in the city) the pleasure that i get more this car is indescribable. Its been over 15 months now at 20K kms at the ODO, not a single problem and i enjoy the more i drive this beauty.
Also, there was a fantastic comparison test by Overdrive between Fiesta TDCi and Viva CRDI, that finally clinched my decision towards the Viva
And, all that crazy hard driving gets me 14.5 kmpl in city driving conditions and over 18kmpl on highways
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 6th February 2008, 14:53   #7 (permalink)
revved_up's Avatar
Congrats for your car ..!!
Really nice FE figures too.
revved_up is offline   Reply With Quote
Old 6th February 2008, 15:10   #8 (permalink)
great review dhiramos,
which variance u bought? got any ICE/upgrades?
attakasa_paiyan is offline   Reply With Quote
Old 6th February 2008, 18:45   #9 (permalink)
supremeBaleno's Avatar
Location: Weekdays at DetroitOfIndia (Chennai) & Weekends at VeniceOfTheEast (Alappuzha).
You almost sound like the NHC's alter ego.
__________________
A bad worker blames his tools. Bad drivers blame the car's rattles for bad performance on track. :-)
Old 6th February 2008, 20:05   #10 (permalink)
snaronikar's Avatar
Good review and nice FE too. Enjoy the ride buddy. BTW, have you done any long trips as of now?
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 6th February 2008, 21:27   #11 (permalink)
PatienceWins's Avatar
Congrats for your car. Nice comparative review. FE you are getting is great. Enjoy!!
PatienceWins is offline   Reply With Quote
Old 6th February 2008, 21:43   #12 (permalink)
BUSA's Avatar
Congrats on getting the Fiesta. The car has a fantastic and refined engine. Good choice. Any plans for Petes?
__________________
thecarsandmore.blogspot. com
Old 6th February 2008, 22:43   #13 (permalink)
finneyp's Avatar
Nice choice pal! Congrats!
Fiesta sure is a Fun to drive Car! Enjoy driving!
__________________
Drive Safe, your loved ones need you!!!
My Passion is not driving Cars, but driving a FIAT!
Finney, Bangalore
Palio 1.2 NV - 2004
finneyp is offline   Reply With Quote
Old 6th February 2008, 23:02   #14 (permalink)
Team-BHP Moderator
normally_crazy's Avatar
Busa - seems like you have self appointed your self as Pete's marketing agent.
Will have to take a hard look at your posts now.
normally_crazy is offline   Reply With Quote
Old 6th February 2008, 23:03   #15 (permalink)
Default gr8 car
hi guyz even i own a fiesta tdci with ABS since mar 06 and have driven around 56k kms without a single problem..i luv the car and it's a gr8 handler..but be sure to go in for extended warranty it helps a lot ..recently one of the cells of my car's battery got exhausted and i just paid 840 rs. to the agency and got myself a new battery otherwise i wld have to pay arnd 3500 rs for the new battery...best car in it's price range...
braveheart_77 is online now   Reply With Quote
Thread Tools
Fiesta ZXi TDCi or Fusion TDCi ?? ajkail Sedans 20 28th August 2007 07:03
Service Costs : Fiesta TDCI navdeep The Indian Car Scene!! 19 19th September 2006 11:05
Elantra crdi or fiesta tdci ?? tanishq Sedans 9 12th June 2006 10:13
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
